Motors · Bosch
Bosch · Performance Line CX (Smart System)
Performance Line CX Gen 5
Bosch's fifth-generation Performance Line CX is the quiet, controlled benchmark of the full-power class — and after two free firmware upgrades it now claims 120 Nm and 750 W, answering DJI's Avinox on refinement if not raw watts, without changing a single bolt.
Performance Line CX Gen 5 eMTB motor
The Performance Line CX Gen 5 — same 85 Nm hardware as Gen 4 in a lighter, far quieter magnesium housing.
0250500750406080100120140685 Wcadence (rpm) →power (W)
On Velomotion's dyno, power ramps in from around 50 rpm, plateaus near 60 rpm at the ~685 W measured peak, then holds remarkably flat — little fluctuation right out to 140 rpm rather than the early roll-off of rivals.
The verdict
Bosch Performance Line CX Gen 5 arrived in September 2024 as a surprise: same 85 Nm and 600 W on paper as the Gen 4 it replaced, but wrapped in a 100 g-lighter magnesium housing, a new two-bolt mount and a gearbox that finally killed the old motor's descending clatter. On Velomotion's PTLabs dyno the new BDU38 and the old BDU37 traced almost identical peak-power lines, so the early verdict was "evolution, not revolution" — the revolution, it turned out, was simply how refined and quiet it had become. Note the date: Bosch unveiled the unit in September 2024 with bikes landing from early 2025, so this is a 2024-launch motor despite the firmware story that followed.
Then came the software. The July 2025 Performance Upgrade lifted Velomotion's measured peak power to around 685 W (a claimed 750 W) and torque to 100 Nm; the May 2026 Performance Upgrade 2.0 pushed the headline torque to a 120 Nm dynamic boost and the support ratio to a huge 600%, with peak power unchanged at a claimed 750 W. None of it touches the hardware — it is all unlocked through the eBike Flow app. The trade-off is heat: in Velomotion's testing the unlocked power tunes warm sooner and derate after roughly eight minutes of hard climbing (housing settling near 80°C), where the stock 85 Nm tune holds full power past the twelve-minute mark at a cooler ~75°C.
What hasn't changed is the CX's defining trait — a beautifully metered, natural delivery that never tries to outrun the rider. It needs a genuine ~200 W of leg to give everything, which keeps the ride feeling earned rather than electric. On raw shove it is now mid-pack among the heavy hitters: Velomotion measures the DJI Avinox M2S at ~1150 W (150 Nm claimed) and the Sachs RS at ~898 W / 112 Nm, and even Specialized's updated 3.1 S-Works (~810 W / 111 Nm measured) now sits clearly ahead of the Bosch's ~685 W. But as an all-round trail motor the Gen 5 remains the one most riders will simply forget is there.
“Same hardware, new software — Bosch answered Avinox without touching a single bolt.”
Sustained power & heat
How long the headline number actually lasts under sustained climbing load.
Stock 85 Nm tune
Holds 100% for 12 min · housing 75 °C
Velomotion measured ~12 min at full power before derating, vs ~8 min for Gen 4; housing settles near 75°C, cooler than rivals.
Performance Upgrade (claimed 750 W / ~685 W measured)
Holds 92% for 8 min · housing 80 °C
In Velomotion's test the unlocked tune derates from ~8 min under sustained 250 W load; ~8% down after 20 min, housing near 80°C, but still matches the stock tune's output.
Character
Rider input
Wants a real ~200 W of rider input to reach peak — far more than the Shimano EP801's ~100 W — which is exactly what gives the CX its earned, natural feel; the new 600% support eases that on steep crawls.
On the trail
Smooth, metered and utterly natural — it amplifies the rider rather than overriding them, holding power flat across a wide cadence so there's no surge to manage on technical climbs.
Noise
Near-silent from cold even under load — the Gen 4 clatter is gone — though a high-frequency hum creeps in as the motor heats up, approaching the benchmark-quiet Brose Drive S Mag.
Efficiency
A standout: Velomotion measured it consuming less energy uphill than its predecessor and virtually every full-power rival, so the firmware power gains cost little in real-world range.
The case for and against
Strengths
  • Class-leading refinement — quiet, smooth, natural delivery
  • Free firmware route to 120 Nm / 750 W / 600% support
  • Excellent efficiency and uphill range
  • Flat power curve from ~60 to 140 rpm
  • Lighter magnesium housing, runs cooler than rivals
Compromises
  • 120 Nm is a few-second dynamic boost, not sustained torque
  • Power tunes derate sooner under hard, prolonged climbing
  • Now mid-pack on raw power — trails Avinox M2S, Sachs RS and the updated Specialized 3.1 S-Works
  • Needs ~200 W rider input for peak — not a free ride
How it stacks up
On Velomotion's dyno the upgraded CX measures around 685 W peak. That now puts it behind every full-power heavyweight on raw output: the DJI Avinox M2S reads ~1150 W at 80 rpm (150 Nm claimed, ~1450 W at the very top of its cadence range with the FP700 battery), the Sachs RS ~898 W / 112 Nm, and — crucially — Specialized's 3.1 S-Works, after its February 2026 power update, ~810 W with a consistent 111 Nm, ranking just behind the Avinox M1. So the Bosch trails the updated 3.1 S-Works by roughly 125 W, it is not ahead of it; earlier comparisons that put the CX ~30 W up were measured against the pre-update 3.1. Against Shimano's EP801 the CX is quieter, more efficient and longer-lasting under heat, but demands more rider input to give its all. Where it still wins is character, not the dyno headline.
OWNER INTELLIGENCE
Most owners report no problems · 4,368 posts from 702 members analysed.
8Motor-mount frame sleeve / bushing walking out (early production) · typical onset: 0-650 km (first weeks of ownership; ~100-400 miles typical)
7Crank-seal squeak and per-revolution click · typical onset: 0-200 km
6Freewheel/clutch engagement clunk with delayed assist after coasting · typical onset: ~1 month / 300-1,100 km, progressive
Multiple owners report silent, trouble-free motors: 'rode 3 bikes with the gen5, zero rattle'; Transition Regulator 'totally silent on downhills'; Peak…
Read the full owner report →
