Bike Finder · Trek
Trek Powerfly FS
Trek
Powerfly FS 2026
CurrentTrail eMTBMature · 6.6/10iFreshness 6.6/10
Bosch Performance CX full-power trail eMTB up to 800Wh
Travel F/R
130/120mm
Wheels
29F/29R
Frame
Aluminium
Weight
25.08 kg
Price
From £4,000
View the Trek Powerfly FS on Trek’s site
Trek Powerfly FS 2026
From £4,000
EMTB Forums verdict
The Trek Powerfly FS 2026 is an aluminium full-suspension trail eMTB built around the Bosch Performance Line CX Gen 5 motor, with 120/130 mm travel and singletrack-tuned conservative geometry. Headline numbers: 120 Nm of torque, 600 Wh removable Bosch PowerTube battery, a 65.0 to 66.0 degree head angle, 24.58 kg claimed and a £4,000 base price. Trek's Powerfly platform has earned a strong reputation for sensible everyday usability rather than aggressive trail performance, with the community feedback consistent across multiple model generations.
Drive system and range. The Bosch Performance Line CX Gen 5 delivers 120 Nm of torque and a 750 W manufacturer-claimed peak after the post-PU2.0 firmware unlocked the eMTB+ mode with around 400% rider support. The 600 Wh PowerTube is removable via Trek's RIB 2.0 system, which is one of the better battery-extraction designs in the segment. The 600 Wh capacity is modest by 2026 standards (the Bosch ecosystem now supports 800 Wh in the same form factor), but appropriate for the 120 mm-rear-travel trail brief. On a 24.6 kg trail chassis, expect comfortable three to four hours of mixed-trail riding before reserves bite. Trek's UK dealer network is the strongest in the segment for warranty and service.
Geometry and handling. The Powerfly FS uses Trek's traditional size nomenclature (15.5", 17.5", 19.5", 21.5") rather than alphabetical sizing, with reach progressing from 425 mm to 500 mm. The head angle floats between 65.0 and 66.0 degrees depending on size, with a long 458 to 461 mm chainstay shared across the range and wheelbase from 1,201 mm to 1,290 mm. The 66 degree head angle and 460 mm chainstay are firmly conservative — sensible-trail geometry rather than aggressive descending. The frame uses Trek's ABP (Active Braking Pivot) rear linkage. rider upgraded from earlier Powerfly to a 2022 FS9 Equipped "mostly because it was the FS model and had all upgraded components along with an 85 Nm motor and a 625 W battery" — useful generational context.
Build and value. Only the base trim is on file at £4,000. The Alpha Platinum aluminium frame, Bosch CX Gen 5 motor and 600 Wh battery represent solid value for a Trek-built trail eMTB, with the Trek dealer network as the key value-add. rider notes a "2022 Trek Powerfly FS4 as a spare used with 135 miles on it for $2,700 which is 1/2 of what it was selling for new with tax last year" — Trek depreciates fast on the used market, which favours new-bike buyers but not resale.
Community-verified strengths. First, Trek's dealer network: the strongest in the segment for warranty and service. Second, the ABP suspension is well-developed and well-supported. Third, RIB 2.0 battery extraction is genuinely well-engineered. olde-mtber confirms the bike has a "walk mode function for chain lubrication" — a small but useful detail.
Caveats and known gripes. First, conservative geometry: 65 to 66 degree HA and 460 mm chainstay are well behind modern trail eMTB rivals (Whyte ELyte at 64.6, Canyon Neuron:ONfly at 64.5). Second, brake-bleed reliability: Sophie777 reports a 2019 FS7 "right-sided brake lever compressed fully to bar, resolved with single brake burp; recurred next season affecting both brakes, requiring full bleed". Third, motor-removal complexity: Stihldog documents the motor-drop procedure requires "Torx 40 Plus socket, torque wrench, basic shop tools; no crank/chainring removal needed" — manageable but not trivial. Fourth, 600 Wh battery is modest by 2026 standards.
Verdict. The Trek Powerfly FS 2026 suits everyday riders who want a sensible, conservative trail eMTB with the latest Bosch CX Gen 5 motor, Trek's industry-leading dealer network, and approachable handling geometry on flowing singletrack. Less suitable for aggressive trail riders, those chasing modern slack-head geometry, or buyers who need the largest practical battery (800 Wh class rivals deliver more range). Production status: current.
💬 Forum discussion
Trek Powerfly FS 2019 - scrapping/tinny noise
8 replies · 5.4k views · last reply 85 months ago
Join the discussion →
“I used to get a tinny rattle from my rear disc @ ~15mph on my LT7. Changed to some different discs and the noise has gone.”
— thewildblue · ♥ 3 · most-liked post
Frame
Alpha Platinum Aluminium full-suspension frame with ABP rear linkage, RIB 2.0 removable battery, tapered head tube, internal Control Freak routing, Motor Armor, Boost148, 12mm thru-axle. 120mm rear travel; 29" wheels on M-XL, 27.5" on S.
Bike geometry diagram
15.5"17.5"19.5"21.5"
Reach425 mm450 mm475 mm500 mm
Stack597 mm629 mm647 mm666 mm
Chainstay458 mm461 mm461 mm461 mm
Headtube Angle65°66°66°66°
Seattube Angle (eff)77°77°77°77°
BB Drop30 mm45 mm45 mm45 mm
Wheelbase1201 mm1223 mm1257 mm1290 mm
Headtube130 mm110 mm130 mm150 mm
Standover756 mm780 mm775 mm778 mm
Front Centre743 mm762 mm796 mm829 mm
Trims · 2
FS+ 4 Gen 4
£4,000
FS+ 6 Gen 4
£5,000
MotorBosch Performance Line CX Gen 5 · 120 Nm · all trims
BatteryBosch PowerTube 600 · 600 Wh · all trims
Travel F/R130/120 mm · all trims
FrameAlpha Platinum Aluminium · all trims
ForkRockShox Recon Silver RL, Solo Air, Motion Control damper, lockout, tapered steerer, 42 mm offset, Boost110, 15 mm Maxle Stealth, 130 mm travelFox AWL Rail HD, Rail 2.0 damper, tapered steerer, 44 mm offset, Boost110, 15 mm Kabolt axle, 180 mm direct mount, 130 mm travel
ShockRockShox DeluxeFox Float Rhythm, 2-position damper, 210x50 mm
HeadsetFSA IS-2, 1-1/8" top, 1.5" bottom
StemBontrager Comp, 31.8 mm, Blendr compatible, 7-degree, 50 mm length · all trims
HandlebarBontrager Comp, alloy, 31.8 mm, 40mm rise, 780 mm width · all trims
GripsBontrager XR Trail Comp, nylon lock-on · all trims
SaddleBontrager Verse P3, steel rails · all trims
SeatpostBontrager Line Dropper, MaxFlow, internal routing, 31.6 mm (100mm travel size S; 170mm travel sizes M/L/XL) · all trims
BrakesTektro Gemini SL, 4 piston hydraulic discShimano 4-piston hydraulic disc, M6100 lever, M6120 calliper
Rear derailleurShimano CUES U6000 GSShimano XT M8100, long cage
CrankFSA Bosch CK-220, 36T ring, 165 mm lengthE*thirteen E*spec Plus, 160 mm length
ShiftersShimano U6000, 10-speedShimano SLX M7100, 12-speed
CassetteShimano CUES LG300, LINKGLIDE, 11-48, 10-speedShimano Deore M6100, 10-51, 12-speed
ChainShimano LG500, 9/10/11-speedShimano Deore M6100, 12-speed
DrivetrainShimano CUES, 10-speedShimano XT/SLX, 12-speed
WheelsBontrager Line Comp 30Bontrager Line TLR 30
TyresBontrager Gunnison Pro XR, Tubeless-Ready, 27.5x2.40" (S) / 29x2.40" (M, L, XL) · all trims
Weight25.28 kg25.08 kg
Price£4,000£5,000
Rides similarly
Spot a mistake?
