ELyte EVO 2026
Bosch CX-powered lightweight trail/enduro eMTB - time saver, fun maker
The Whyte ELyte EVO 2026 is a lightweight carbon trail eMTB platform from the UK brand, now offered in this top-spec MX (mullet) build with the latest Bosch Performance Line CX Gen 5 motor. Headline numbers: 120 Nm of torque, 400 Wh Bosch CompactTube battery, 150 mm front / 142 mm rear travel, a 64.6 degree head angle and a £5,699 base price. The Bosch CX Gen 5 fitted to a 400 Wh battery is the platform's headline talking point — both for what it enables and for the compromises it introduces.
Drive system and range. The Bosch CX Gen 5 delivers 120 Nm of torque and a 750 W manufacturer-claimed peak after the post-PU2.0 firmware update. Whyte has paired it with the 400 Wh Bosch CompactTube — significantly smaller than the 600 to 800 Wh PowerTubes the CX Gen 5 is typically run with. rider flags the structural concern: "the integrated 400 Wh doesn't have enough power to fully power the CX motor and is essentially detuned". Mteam confirms the v2 frame proves "the CX motor IS compatible with the 400 Wh battery despite Bosch's official stance". zizajaun explains the packaging trade-off: "Whyte ELyte 150 and ELyte EVO use 400Wh internal battery plus range extender above the BB, with a rotated motor to allow the battery to drop as far as possible, giving lower centre of gravity than standard 600/800Wh Bosch batteries". Endorium reports actual range: "Whyte ELyte with Bosch SX 400Wh + 250Wh extender in Eco gets 26 miles and 5,000 ft of climbing at 100 kg rider weight". andyjayh notes the Forbidden e-Druid Avinox "got 23 miles/5,500 ft vs ELyte 18 miles/4,000 ft on similar ride in Auto mode" — direct range comparison.
Geometry and handling. Four sizes (S, M, L, XL) cover a 431 to 506 mm reach range. The head angle is fixed at 64.6 degrees and is properly modern for a 150/142 mm trail eMTB. The 450 mm chainstay is shared across sizes and wheelbase grows from 1,212 mm to 1,303 mm. The lowered CoG via the rotated-motor / smaller-battery packaging is the platform's key engineering signature.
Build and value. Two trims are listed: the RS (base £5,699) and Stag Works (premium). rider notes Gen 5 upgrade pricing — "cheapest I have seen is at mtb monster at £5,999, down from the £7,250" — suggesting dealer flexibility. zizajaun confirms a critical detail: "Frame is identical between SX motor and CX motor versions, but manufacturer does not permit CX motor upgrade on used SX-equipped bikes" — important resale consideration.
Community-verified strengths. First, low-CoG packaging: zizajaun notes the rotated-motor and small-battery packaging deliver lower CoG than standard 600/800 Wh Bosch builds. Second, modern 64.6 degree HA. Third, the Bosch CX Gen 5 motor (with the caveat below) is genuinely powerful when fully fuelled.
Caveats and known gripes. First, the 400 Wh battery is the platform's most-flagged compromise — rider bluntly says the CX motor is "essentially detuned" due to insufficient battery capacity. The range-extender is essentially required for proper rides. Second, motor-mount issues: rider reports "increasing problems with the motor mounts of Bosch's current SX and CX e-bike motors" with the issue first appearing on the long-term ELyte EVO RS test bike. Third, the CX-vs-SX upgrade lockout: buyers committing to SX cannot later upgrade to CX even on the identical frame.
Verdict. The Whyte ELyte EVO 2026 suits riders who want a UK-designed lightweight trail eMTB with the latest Bosch CX Gen 5 motor and the low-CoG packaging that the small 400 Wh battery enables, and who are comfortable with the range-extender as essentially mandatory equipment for full rides. Less suitable for buyers who want range without a range-extender, the simplest stock battery setup, or who are concerned about Bosch motor-mount durability on the platform. Production status: current.
| S | M | L | XL | |
| Reach | 431 mm | 456 mm | 481 mm | 506 mm |
| Stack | 629 mm | 641 mm | 652 mm | 663 mm |
| Chainstay | 450 mm | 450 mm | 450 mm | 450 mm |
| Headtube Angle | 64.6° | 64.6° | 64.6° | 64.6° |
| Seattube Angle (eff) | 77.5° | 77.3° | 77.1° | 76.9° |
| Wheelbase | 1212 mm | 1242 mm | 1273 mm | 1303 mm |
| Headtube | 114 mm | 127 mm | 140 mm | 152 mm |
| BB Height | 342 mm | 342 mm | 342 mm | 342 mm |
| Front Centre | 762 mm | 792 mm | 823 mm | 853 mm |
Trims · 2
RS £7,250 | Stag Works £9,999 | |
| Motor | Bosch Performance Line CX Gen 5 · 120 Nm · all trims | |
| Battery | Bosch CompactTube 400 · 400 Wh · all trims | |
| Travel F/R | 150/142 mm · all trims | |
| Frame | Carbon fibre · all trims | |
| Fork | RockShox Lyrik Select+, 150mm travel, DebonAir+, Charger 3.1 Damper | Fox Float 36 Factory 29in, 150mm travel, 44mm offset, Grip X2 damper |
| Shock | RockShox Deluxe Select + RT, DebonAir, Fast Black coating | Fox Float X Factory Series, EVOL, lock out, 210mm x 50mm, custom tuned |
| Headset | FSA No. 69/56/SRS, 1-1/8in upper and 1.5in lower with sealed angular contact bearing (ACB) cartridge bearings | FSA No. 55R, 1-1/8in upper and 1.5in lower |
| Stem | Whyte Trail full CNC, 32mm extension, 35mm bar bore · all trims | |
| Handlebar | Whyte Custom 6061 alloy, 30mm rise, 35mm bar bore, 800mm wide | Race Face ERA Carbon, 20mm rise, 35mm bar bore, 800mm wide |
| Grips | Whyte Enduro lock-on · all trims | |
| Saddle | Whyte custom | Fizik Terra Aidon, 145mm wide, Wingflex, S-Alloy Mobius rail |
| Seatpost | TranzX +RAD 30.9mm, Adjustable | Whyte drop.it II Adjust, 30.9mm |
| Brakes | SRAM Code Bronze Stealth | Hope Tech4 V4 |
| Rear derailleur | SRAM S1000 T-Type AXS, 12 speed | SRAM XO T-Type AXS, 12 speed |
| Crank | Whyte 155mm ISIS arms, SRAM Direct Mount 36T chainring, T-Type | Hope E-Bike Cranks, 155mm length, Bosch mounting, 36T chainring |
| Shifters | SRAM AXS Pod, right, MMX, 12 speed · all trims | |
| Cassette | SRAM XS 1270, T-Type, 10-52T, 12 speed | SRAM XS 1295, T-Type, 10-52T, 12 speed |
| Chain | SRAM GX T-Type, 12 speed | SRAM XO T-Type, 12 speed |
| Drivetrain | SRAM S1000 T-Type AXS, 12 speed; Whyte 155mm ISIS arms, SRAM Direct Mount 36T chainring, T-Type; SRAM AXS Pod, right, MMX, 12 speed; SRAM XS 1270, T-Type, 10-52T, 12 speed; SRAM GX T-Type, 12 speed | SRAM XO T-Type AXS, 12 speed; Hope E-Bike Cranks, 155mm length, Bosch mounting, 36T chainring; SRAM AXS Pod, right, MMX, 12 speed; SRAM XS 1295, T-Type, 10-52T, 12 speed; SRAM XO T-Type, 12 speed |
| Wheels | WTB ST Tough rims (30mm internal width), alloy double-sealed cartridge bearing hubs (15x110mm Boost front / 12x148mm Boost rear, light-assist e-bike specific) | Hope Pro 5 hubs (15x110mm Boost front / 12x148mm Boost XD rear), DT HX531 rims (30mm internal width) |
| Tyres | Maxxis Minion DHF, EXO TR MaxxGrip 29in x 2.5in front; Maxxis Dissector, EXO+ TR MaxxTerra 29in x 2.4in rear | Maxxis Assegai WT, TR, 29in x 2.5in 120TPI, EXO+ Sidewall front; Maxxis Minion DHR 2 WT, TR, 27.5in x 2.5in 120TPI, Double Down rear |
| Weight | 20.9 kg | 20.8 kg |
| Price | £7,250 | £9,999 |
Rides similarly
Spot a mistake?
