Level 2026
Entry-level alloy Level with Bosch CX Gen 5, 800Wh battery, RockShox ZEB Select fork and Vivid Coil shock.
The Mondraker Level 2026 is an aluminium long-travel full-power eMTB built around Bosch's latest Gen 5 motor system and a 180/170 mm mullet chassis, sitting firmly in the gravity-leaning end of the e-enduro segment. Headline numbers: 180 mm front / 170 mm rear travel, 800 Wh Bosch removable battery, a 64.0 degree head angle, 27.1 kg claimed and a £5,999 base price. The community read on the platform is broadly positive on geometry and motor pairing, with the usual Mondraker Level alloy notes on a few minor quality-control items.
Drive system and range. The Level 2026 is built around the Bosch Smart System (Gen 5 architecture) with the 800 Wh PowerTube battery. jar2b confirms the spec: "180/170mm travel with MX wheels, e*13 components, Zeb Select fork, Vivid Coil Base shock, Maven Bronze brakes, Bosch Gen5 800Wh battery, SRAM Eagle 90 drivetrain". The 800 Wh capacity is class-leading for full-power enduro, supporting four to five hours of hard riding on the 27 kg platform. jar2b also notes the "Mondraker Level 2026 has same weight as Reign E+ but more range and more power with Bosch motor" — a useful direct comparison against the Giant rival.
Geometry and handling. The bike runs five sizes (SM, MD, MD/LG, LG, XL) with reach progressing from 440 mm (SM) up to 520 mm (XL) — the headline number is the XL reach, properly long for tall riders. The 64.0 degree head angle is fixed across the range. The chainstay grows from 445 mm to 455 mm across sizes (size-specific tuning), and wheelbase stretches from 1,236 mm to 1,343 mm. Mondraker's Forward Geometry philosophy and the Updated Zero Suspension System sit at the heart of the chassis. Vanquisher notes earlier Level RR 2021 medium had "470mm reach, 1270mm wheelbase — considerably longer than typical mainstream Medium sizing", confirming Mondraker's commitment to long-reach geometry. ntm95 compares the Crafty large frame as having "geometry front/rear ratio superior to Level, making it more popular with gravity-oriented riders" — useful context if you are choosing between Mondraker's two e-enduro platforms.
Build and value. Three trims (R, RR, XR) ladder upwards from the £5,999 R base. The R is specced with the RockShox ZEB Select fork, Vivid Coil shock, Maven Bronze brakes, SRAM Eagle 90 drivetrain and an 800 Wh Bosch battery. Zimmerframe notes the Level R has been discounted as low as £3,699 historically, suggesting strong dealer availability and price flexibility.
Community-verified strengths. First, range and power balance: jar2b rates the Level as offering same weight as the Reign E+ but with more range and more power. Second, long-reach Forward Geometry confirmed by Vanquisher. Third, the comprehensive Bosch ecosystem behind the motor.
Caveats and known gripes. First, crank lockring durability: Dr. Ergal reports his "crank lockring became loose after 35 km of riding on a brand new bike", later fixed by re-tightening with medium loctite. Second, speed-sensor electrical issues on Bosch Smart System Level: pedalered reports a speed-sensor error that recurred after charging and required service intervention. Third, the Crafty platform may be better suited for gravity-focused riders per ntm95.
Verdict. The Mondraker Level 2026 suits riders who want long Forward Geometry, the latest Bosch CX Gen 5 motor with 800 Wh battery, and a 180/170 mm e-enduro chassis at a price that the carbon competition cannot match. Less suitable for buyers chasing the lightest possible weight or the slackest gravity geometry. Production status: current.
Frame
Level 6061 Alloy Stealth Evo, Updated Zero Suspension System, Mullet (29F/27.5R), 170mm rear travel, Forward Geometry, internal removable battery, Boost 12x148mm rear axle, UDH, tapered head tube, one-piece Monoblock upper link, HHG internal cable routing, MAX-capacity sealed bearings, oversize 17mm axles, exclusive plastic motor covers.
| S | M | L | XL | MD/LG | |
| Reach | 440 mm | 460 mm | 500 mm | 520 mm | 480 mm |
| Stack | 640 mm | 649 mm | 667 mm | 676 mm | 658 mm |
| Chainstay | 445 mm | 445 mm | 455 mm | 455 mm | 445 mm |
| Headtube Angle | 64° | 64° | 64° | 64° | 64° |
| Seattube Angle (eff) | 78° | 78° | 78° | 78° | 78° |
| BB Drop | 2 mm | 2 mm | 2 mm | 2 mm | 2 mm |
| Wheelbase | 1236 mm | 1260 mm | 1319 mm | 1343 mm | 1284 mm |
| Headtube | 110 mm | 120 mm | 140 mm | 150 mm | 130 mm |
| Front Centre | 791 mm | 815 mm | 864 mm | 888 mm | 839 mm |
Trims · 3
R £5,999 | RR £8,499 | XR £10,499 | |
| Motor | Bosch Performance Line CX · all trims | ||
| Battery | Bosch PowerTube 800 · 800 Wh · all trims | ||
| Travel F/R | 180/170 mm · all trims | ||
| Frame | Aluminium · all trims | ||
| Fork | RockShox ZEB Select Charger RC 29, 180mm travel, tapered steerer, 44mm offset, Boost 15x110mm | Fox 38 29 Float Factory GRIP X2 Kashima, 180mm travel, tapered steerer, Boost 15x110mm, 44mm offset, high/low-speed compression and rebound adjust | Öhlins RXF 38 M.3 29, 180mm travel, TTX18 Twin Tube cartridge damper, high-speed compression lever with climb mode, low-speed compression adjust, rebound adjust, ramp chamber, 44mm offset, Boost 15x110mm |
| Shock | RockShox Vivid Coil Base, 205x65mm, trunnion mount, external bottom-out adjustment, rebound adjust | Fox DHX2 Performance Elite coil, 205x65mm, trunnion mount, low-speed compression and rebound adjust | Öhlins TTX22M.2 coil, 205x65mm, trunnion mount, high-speed compression lever with climb mode, low-speed compression adjust, rebound adjust |
| Headset | Acros custom IS52/ZS56, 1-1/8" upper and 1.5" lower · all trims | ||
| Stem | Onoff S3 30mm, 0° angle, 31.8mm clamp | Onoff S6 30mm, 0°, 6061 forged alloy + CNC, 31.8mm clamp | Onoff S9 30mm 0°, full CNC, 31.8mm clamp |
| Handlebar | Onoff S3 1.0 6061 alloy, 800mm width, 25mm rise (38mm on L/XL), 8° backsweep, 5° upsweep, 31.8mm clamp | Onoff S6 1.0 7050 alloy, 800mm width, 25mm rise (38mm on L/XL), 8° backsweep, 5° upsweep, 31.8mm clamp | Onoff S9 1.0 Carbon, 800mm width, 25mm rise (38mm on L/XL), 8° backsweep, 5° upsweep, 31.8mm clamp |
| Grips | Onoff Desert Pro, CNC lock-on, 135mm · all trims | ||
| Saddle | Fizik Terra Aidon X5, 145mm · all trims | ||
| Seatpost | Onoff Pija dropper internal, 31.6mm, 1X remote lever · all trims | ||
| Brakes | SRAM Maven Bronze, 4-piston caliper hydraulic disc (18mm and 19.5mm pistons), front and rear | SRAM Maven Bronze, 4-piston caliper hydraulic disc (18mm and 19.5mm pistons), front and rear, steel-backed metal sintered pads | SRAM Maven Silver, 4-piston caliper hydraulic disc, steel-backed sintered metal pads, front and rear |
| Rear derailleur | SRAM 90 Eagle T-Type, 12-speed | SRAM S1000 Eagle AXS T-Type, 12-speed (wireless) | SRAM GX Eagle AXS T-Type, 12-speed (wireless) |
| Crank | Race Face Aeffect eBike, 160mm all sizes · all trims | ||
| Shifters | SRAM 90 Eagle T-Type Actuation, single-click, 12-speed | SRAM Eagle AXS Pod MMX Controller, 12-speed (wireless) | SRAM Eagle AXS Pod MMX Controller, 12-speed (wireless) |
| Cassette | SRAM 12-speed Eagle T-Type | SRAM XS-1275, 10-52T, 12-speed T-Type | SRAM XS-1275, 10-52T, 12-speed T-Type |
| Chain | SRAM 70 Eagle T-Type, 12-speed with Powerlock | SRAM GX Eagle T-Type, 12-speed with Powerlock | SRAM GX Eagle T-Type, 12-speed with Powerlock |
| Drivetrain | 1x12 SRAM 90 Eagle T-Type mechanical | 1x12 SRAM S1000 Eagle AXS T-Type wireless electronic | 1x12 SRAM GX Eagle T-Type wireless electronic |
| Wheels | e*thirteen Grappler Core wheelset, 30mm internal hookless aluminium rims, Boost hubs (15x110mm F / 12x148mm R), tubeless-ready | e*thirteen Grappler Core wheelset, 30mm internal hookless aluminium rims, Boost hubs, tubeless-ready | e*thirteen Grappler Core wheelset, 30mm internal hookless aluminium rims, Boost hubs, tubeless-ready |
| Tyres | Front: Maxxis Assegai 29x2.6WT, 3C MaxxGrip, DD protection; Rear: Maxxis Minion DHR II 27.5x2.6WT, 3C MaxxTerra, DD protection | Front: Maxxis Assegai 29x2.6WT 3C MaxxGrip DD 120x2TPI; Rear: Maxxis Minion DHR II 27.5x2.6WT 3C MaxxTerra DD | Front: Maxxis Assegai 29x2.6WT, 3C MaxxGrip, DD protection; Rear: Maxxis Minion DHR II 27.5x2.6WT, 3C MaxxTerra, DD protection |
| Weight | 27.1 kg | 25.3 kg | 24.5 kg |
| Price | £5,999 | £8,499 | £10,499 |
Rides similarly
Spot a mistake?
