Bike Finder · Stevens
Stevens E-Inception ED 9.7
Stevens
E-Inception ED 9.7 2026
CurrentEnduro eMTBCurrent · 7.9/10iFreshness 7.9/10
Power Enduro eMTB with Shimano EP801
Travel F/R
170/170mm
Wheels
29F/27.5R
Frame
Full carbon
Weight
23.5 kg
Price
£7,899
View the Stevens E-Inception ED 9.7 on Stevens’s site
Stevens E-Inception ED 9.7 2026
From £7,899
EMTB Forums verdict
The Stevens E-Inception ED 9.7 2026 is a German carbon enduro built around the Bosch Performance Line CX Gen 5 motor, with 170 mm front / 160 mm rear travel and a 0.5 degree slacker head angle than the predecessor. Headline numbers: 120 Nm of torque, 800 Wh removable Bosch PowerTube 800 battery, a 64.3 degree head angle, 23.5 kg claimed and a £7,899 base price. The carbon SL HMF frame integrates the 800 Wh PowerTube via a frame cut-out. There are only two curated community quotes on file, both about the older E-Inception ED 8.7 GTF on Shimano EP8 — the 2026 9.7 build uses the newer Bosch ecosystem, so the older battery/motor issues are not directly relevant.
Drive system and range. The Bosch Performance Line CX Gen 5 delivers 120 Nm of torque and a 750 W manufacturer-claimed peak after the post-PU2.0 firmware update unlocked the eMTB+ mode and around 400% support. The 800 Wh PowerTube is removable and is one of the largest packs in the Bosch ecosystem, supporting four-and-a-half to five hours of mixed-trail riding on the 23.5 kg chassis. The Gen 5 magnesium casing brings motor weight to 2.8 kg and the long-running gearbox clacking is finally resolved. Bosch dealer support is the strongest in the segment for warranty and service, which matters more on a brand like Stevens with a smaller specialist dealer footprint outside Germany.
Geometry and handling. The bike comes in four sizes (R1, R2, R3, R4) with reach progressing from 435 mm to 490 mm. The 64.3 degree head angle is fixed across all sizes — properly modern for a 170/160 mm enduro and notably 0.5 degree slacker than the predecessor's geometry, signalling a deliberate gravity shift. The 450 mm chainstay is shared across sizes and wheelbase grows from 1,229 mm (R1) to 1,305 mm (R4). The four-bar linkage suspension is well-developed for the segment, and the frame's removable-battery cut-out keeps service simple while preserving frame stiffness.
Build and value. Only the base trim is on file at £7,899. The carbon SL HMF chassis, Bosch CX Gen 5 motor and 800 Wh battery represent strong value for a premium German-built carbon enduro — pricing sits below the comparable Specialized Levo Gen 4 trim ladder and the higher-end Mondraker Level trims with similar battery capacity.
Caveats and known gripes. First, the limited dealer network outside Germany makes warranty and service less convenient for UK buyers. Second, the 2026 9.7 build kit details are not fully published in the primary sources, so specific brake, drivetrain and wheel spec should be confirmed with the dealer before ordering. Third, the predecessor's older battery/motor combinations have had documented reliability issues (alex11 reports Shimano EP8/Darfon battery error E020 on a 2023-era ED 8.7), though this is not directly relevant to the 2026 Bosch-equipped 9.7.
Verdict. The Stevens E-Inception ED 9.7 2026 suits buyers who want a premium German-built carbon enduro with the latest Bosch CX Gen 5 motor, the largest practical 800 Wh battery, and properly modern slack geometry, at a price that undercuts the Specialized/Mondraker premium tier. Less suitable for buyers who require a tight UK dealer network or who need detailed published build-kit spec before committing. Production status: current. Confirm specific 9.7 component spec directly with the dealer before ordering.
Frame
Carbon SL HMF enduro frame with 170 mm front / 160 mm rear travel, 0.5 degree slacker head angle than predecessor, removable Bosch PowerTube 800 Wh battery via frame cut-out
Bike geometry diagram
R1R2R3R4
Reach435 mm452 mm472 mm490 mm
Stack622 mm631 mm645 mm668 mm
Chainstay450 mm450 mm450 mm450 mm
Headtube Angle64.3°64.3°64.3°64.3°
Seattube Angle (eff)75.5°75.5°75.5°75.5°
Wheelbase1229 mm1250 mm1277 mm1305 mm
Front Centre779 mm800 mm827 mm855 mm
Trims · 1
Base
£7,899
MotorBosch Performance Line CX Gen 5 · 120 Nm
BatteryBosch PowerTube 800 · 800 Wh
Travel F/R170/170 mm
FrameCarbon
HeadsetAcros Blocklock Taper 1 1/8"-1.5"
Drivetrain1x12 mountain bike drivetrain
Weight23.5 kg
Price£7,899
Rides similarly
Spot a mistake?
