Bike Finder · Trek
Trek Powerfly+ FS
Trek
Powerfly+ FS 2026
CurrentTrail eMTBMature · 6.7/10iFreshness 6.7/10
Always breathtaking, never breathless
Motor
Bosch Performance Line CX Gen 5 · 120Nm · 750W
Battery
Bosch PowerTube 800 · 800Wh
Travel F/R
130/120mm
Wheels
29F/29R
Frame
Aluminium
Weight
24.5 kg
Price
£6,000
View the Trek Powerfly+ FS on Trek’s site
Trek Powerfly+ FS 2026
From £6,000
EMTB Forums verdict
The Trek Powerfly+ FS 2026 is Trek's full-power trail eMTB on the Alpha Platinum aluminium hardtail platform, refreshed for 2026 around Bosch's latest Performance Line CX Gen 5 motor and an 800 Wh removable PowerTube. It runs 130 mm of fork travel (120 mm on certain sizes) with 100 mm on size S, with a claimed 24.5 kg system weight. Headline numbers: 120 Nm of torque, 750 W peak power, a 65 to 66.5 degree size-specific head angle, a 442 to 461 mm size-specific chainstay range and reach growing from 410 to 500 mm across eight sizes. £6,000 for the base trim. Community verdict: a serious-mileage Bosch CX Gen 5 trail tool from a brand with the deepest UK dealer reach in eMTB.
Drive system and range. The Bosch Performance Line CX Gen 5 brings 120 Nm of torque and 750 W of peak power after the PU2.0 firmware update. The motor weighs 2.8 kg. Trek's RIB 2.0 (Removable Integrated Battery) housing makes the 800 Wh PowerTube genuinely easy to drop out for charging, a standout feature against rivals with side-loading or bonded battery designs. Real-world range on 800 Wh is exceptional: on a Powerfly platform with mid-assist trail use, owners can comfortably target 70 to 100 km per charge. Bosch Smart System pairs with Kiox displays and pushes firmware via the Bosch Flow app for ongoing motor refinement.
Geometry and handling. Head angles vary by size from 65 to 66.5 degrees, with the steeper figure on M and larger frames. Reach grows from 410 mm in SM to 500 mm in XL across an unusually deep eight-size table. Chainstays grow from 442 mm on SM to 461 mm on MD and larger, a sensible size-specific approach for taller riders. Wheelbases run 1151 to 1290 mm. Size S runs 27.5-inch wheels, while M to XL run 29-inch. Trek's Control Freak internal routing keeps cables clean, and the frame includes Motor Armor and Boost148 12 mm rear thru-axle for proper trail use.
Build and value. One base trim, £6,000. Build includes FOX AWL Rail fork with Rail 2.0 damper at 120 mm (100 mm on S), Shimano SLX/XT 12-speed drivetrain and Shimano 4-piston hydraulic brakes (M6100 lever / M6120 calliper). The standout strengths are the latest Bosch CX Gen 5 motor, the 800 Wh RIB 2.0 removable battery and Trek's strong UK dealer reach. The questionable note is that the trim ladder is published as a single configuration in our gold record, with the FOX AWL Rail fork sitting below the FOX 36 or RockShox Lyrik that buyers might expect at this price step.
Caveats and known gripes. The 130/120 travel and steeper 66.5 degree head angle on bigger sizes signal that the Powerfly+ FS is positioned as a trail tourer rather than an aggressive all-mountain platform. Anyone wanting steeper descending capability should look at the Trek Rail+, Powerfly+'s longer-travel sibling. The aluminium frame is reassuringly stout but adds weight compared to carbon rivals in the same price band. Trek's dealer pricing on the Powerfly+ FS sits slightly above the equivalent Cannondale Moterra Neo (£4,199 entry), so value-led buyers may want to compare. Long-term community visibility for the 2026 Powerfly+ FS specifically is limited at launch.
Verdict. The Powerfly+ FS 2026 suits the trail rider who wants Bosch CX Gen 5 power, an 800 Wh easy-removable battery, deep UK dealer support and Trek's signature aluminium chassis durability, in a sensible trail-tourer geometry package. Riders chasing longer travel, lower weight or more aggressive geometry should look at the Trek Rail+, the Cannondale Moterra Neo or the Marin Alpine Trail E. Production status: current.
Frame
Alpha Platinum Aluminium hardtail with RIB 2.0 removable battery, tapered head tube, internal Control Freak routing, Motor Armor, Boost148, 12mm thru-axle, singletrack-minded geometry. 29" wheels on M-XL, 27.5" on S.
Bike geometry diagram
SSMMMDLLGXL
Toptube570 mm605 mm635 mm665 mm
Reach425 mm410 mm450 mm440 mm475 mm465 mm500 mm
Stack597 mm599 mm629 mm641 mm647 mm655 mm666 mm
Seattube390 mm370 mm420 mm400 mm450 mm420 mm480 mm
Chainstay458 mm442 mm461 mm461 mm461 mm461 mm461 mm
Headtube Angle65°65.5°66°66.5°66°66.5°66°
Seattube Angle (eff)77°75°77°75°77°75°77°
BB Drop45 mm65 mm65 mm
Wheelbase1201 mm1151 mm1232 mm1195 mm1261 mm1226 mm1290 mm
Headtube100 mm133 mm110 mm108 mm125 mm123 mm140 mm
BB Height340 mm340 mm340 mm340 mm340 mm340 mm340 mm
Standover697 mm747 mm746 mm
Front Centre743 mm709 mm771 mm734 mm800 mm765 mm829 mm
Trims · 1
Base
£6,000
MotorBosch Performance Line CX Gen 5 · 120 Nm
BatteryBosch PowerTube 800 · 800 Wh
Travel F/R130/120 mm
FrameAluminium
ForkFox AWL Rail with Rail 2.0 damper, tapered steerer, 44mm offset, Boost110, 15mm Kabolt axle, 180mm direct mount, 120mm travel (100mm on S)
ShockHardtail (no rear shock)
HeadsetFSA IS-2, 1-1/8" top, 1.5" bottom
StemBontrager Comp, 31.8mm clamp, Blendr compatible, 7-degree, 50mm length
HandlebarBontrager Comp alloy, 31.8mm clamp, 40mm rise, 780mm width
GripsBontrager XR Endurance Elite lock-on
SaddleBontrager Commuter Comp
SeatpostBontrager Line Dropper, MaxFlow, internal routing, 31.6mm, 170mm travel (S: 100mm)
BrakesShimano 4-piston hydraulic disc, M6100 lever / M6120 calliper
Rear derailleurShimano XT M8100, long cage, 12-speed
CrankE*thirteen E*spec Plus, 160mm length, 36T chainring
ShiftersShimano SLX M7100, 12-speed
CassetteShimano SLX M7100, 10-51T, 12-speed
ChainShimano SLX M7100, 12-speed
Drivetrain1x12 Shimano SLX with XT derailleur and E*thirteen E*spec Plus crankset
WheelsBontrager Line Comp 30 TLR wheelset, Boost spacing, 6-bolt rotors
TyresBontrager Gunnison Pro XR, Tubeless Ready, dual compound, aramid bead, 60 TPI, 29x2.60" (S: 27.5x2.60")
Weight24.5 kg
Price£6,000
Spot a mistake?
