Bike Finder · Pivot
Pivot Shuttle LT
Pivot
Shuttle LT 2026
CurrentEnduro eMTBCurrent · 8.9/10iFreshness 8.9/10
Carbon Bosch CX-R full-power eMTB, 170/162mm travel, DW-Link
Travel F/R
170/162mm
Wheels
MX (29F / 27.5R)
Frame
Full carbon
Weight
23.4 kg
Price
From £9,399
View the Pivot Shuttle LT on Pivot’s site
Pivot Shuttle LT 2026
From £9,399
EMTB Forums verdict
The Pivot Shuttle LT 2026 is a carbon dw-link enduro eMTB built around the latest Bosch Performance Line CX Gen 5 motor and an 800 Wh PowerTube battery. Headline numbers: 170 mm of fork travel, 162 mm at the rear, 23.4 kg claimed for the Pro trim, 120 Nm of peak Bosch torque, a 63.2 to 64.1 degree adjustable head angle and reach progressing from 420 mm on XS to 494 mm on XL with two-position geometry. The community framing has been mixed: long-term Pivot fans love the brand's chassis quality, but @bmwpowere36m3 flags SI linkage added maintenance complexity, and @ramoes notes some riders specifically avoided prior-Gen 4 Bosch Pivots in favour of Gen 5 alternatives.
Drive system and range. The Bosch Performance Line CX Gen 5 brings 120 Nm of peak torque, 250 W nominal and a 750 W manufacturer-claimed peak from a 2.8 kg unit. @Plummet compares Gen 5 directly with Gen 3 and Gen 4 Bosch on the Pivot platform, calling Gen 5 "more powerful with better steep climbing performance". The 800 Wh PowerTube on the Pro and Team trims (750 Wh on the Ride) is removable. @Plummet's 3-hour ride on a 600 Wh Bosch system returned 21 per cent left at the end, suggesting genuine 4-hour ride time at 800 Wh is achievable.
Geometry and handling. Two-position geometry: the "Low" setting gives a properly slack 63.2 degree head angle, while "High" sits at 64.1 degrees. Reach progression is clean: 420 mm on XS, 434 to 436 mm on SM, 459 to 461 mm on MD, 474 to 476 mm on LG and 494 to 496 mm on XL depending on configuration. The 443 to 444 mm chainstay is among the shortest in the 162 mm-travel enduro class, supported by Pivot's 8 mm Swinger rear-centre adjust. Wheelbases run 1189 to 1305 mm. With a mullet wheel setup (29 inch front, 27.5 inch rear) standard and an adjustable 76.5/78 degree seat-tube angle, this is one of the most configurable enduro chassis in the mainstream.
Build and value. Four trims. Pro at £9399, 23.4 kg, with Fox 38 Factory GRIP X2 with Kashima fork, Float X Factory or DHX Live Valve Neo air shock, SRAM Maven Ultimate four-piston brakes and the DT Swiss hybrid mullet wheelset. Ride at £9499 stepping into Fox Performance suspension. Ride SLX/XT at £10250 with Shimano four-piston and the SLX/XT mixed transmission. Team at £14499 sits at the top of the line. Value pick is the Pro: it has the best suspension kit at the lowest price in the family.
Community-verified strengths. Three things owners praise. Long-term reliability of the prior generation is documented: @Gavalar reports a Pivot Shuttle LT with EP801 running 800 miles over 11 months with no issues. The CX Gen 5 chassis pairing is widely welcomed: @Plummet rates Gen 5 ahead of the prior generations on the same chassis. And the adjustable 78/76.5 degree seat angle and 8 mm chainstay adjust make this one of the most fit-tunable enduro frames in the segment.
Caveats and known gripes. Three honest flags. @bmwpowere36m3 notes the Shuttle LT's SI linkage adds maintenance complexity and is harder to service than the simpler dw-link. @MarkE192 reports significant motor rattle on descending on a prior Shuttle LT EP8 build that contributed to switching brands; the move to CX Gen 5 should reduce this concern but the prior chassis is the reference for residual concerns. And @saione compares the prior Pivot Shuttle LT 2024 directly against the Yeti 160e and finds the Yeti's suspension "significantly better". Pivot has clearly responded with the 2026 chassis refresh but cross-brand-loyal buyers may want to demo both.
Verdict. The Pivot Shuttle LT 2026 is for the rider who wants a properly tuned carbon enduro chassis with the latest Bosch Gen 5 motor, an 800 Wh PowerTube and the most fit-adjustable geometry in the segment. If you want a simpler linkage or the broadest dealer network, look at a Cannondale Moterra LT or Specialized Levo. Production status is current.
💬 Forum discussion
Pivot Shuttle LT
132 replies · 59.1k views · last reply 4 months ago
Join the discussion →
“Did Pivot say this? I have not seen anywhere that the Race Motor is 60% more powerful than the standard CX! I’ve got the Race and the new Gen5. Power seems identical, but the Race can get the max assistance at a lower rider input level,…”
— Rob Rides EMTB · ♥ 7 · most-liked post
Frame
Carbon dw-link frame with 162 mm rear travel paired to a 170 mm fork, mullet/MX wheel compatibility with 8 mm Swinger rear-centre adjust, adjustable 76.5/78 degree seat tube angle, integrated 800 Wh Bosch PowerTube (Pro/Team) or 750 Wh (Ride).
Bike geometry diagram
XSSMLXL
Toptube607 mm634 mm651 mm674 mm
Reach420 mm434 mm459 mm474 mm494 mm
Stack610 mm645 mm655 mm664 mm673 mm
Seattube378 mm399 mm432 mm470 mm
Chainstay444 mm443 mm443 mm443 mm443 mm
Headtube Angle64.1°63.2°63.2°63.2°63.2°
Seattube Angle (eff)76.5°75.7°75.7°75.7°75.7°
BB Drop23 mm22 mm22 mm22 mm22 mm
Wheelbase1189 mm1232 mm1261 mm1280 mm1305 mm
Headtube95 mm110 mm120 mm130 mm140 mm
Standover648 mm678 mm678 mm693 mm709 mm
Front Centre745 mm789 mm818 mm837 mm862 mm
Trims · 4
Pro
£9,399
Ride
£9,499
Ride SLX/XT
£10,250
Team
£14,499
MotorBosch Performance Line CX Race · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX Gen 5 · 120 NmBosch Performance Line CX Gen 5 · 120 Nm
BatteryBosch PowerTube 750 · 750 WhBosch PowerTube 750 · 800 WhBosch PowerTube 750 · 800 WhBosch PowerTube 750 · 800 Wh
Travel F/R170/162 mm · all trims
FrameCarbon · all trims
ForkFox Performance Elite Podium 29", 44mm offset, GRIP X2 - 170mmFox Performance 38 29", 44mm offset, GRIP - 170mmFox Performance 38 GRIP, 170 mm travel (Ride SLX/XT build)Fox Factory Podium 29", 44mm offset, GRIP X2 - 170mm
ShockFox Performance Elite Float XFox Performance Float XFox Performance Float X air shock (Ride build)Fox Factory Float X2
HeadsetPivot Precision Sealed CartridgePivot Precision Sealed CartridgePivot Precision Sealed Cartridge
StemPhoenix Team Enduro V2 - 40mm (SM-LG), 50mm (XL)Phoenix Team Enduro V2 - 40mm (SM-LG), 50mm (XL)Phoenix Team Enduro V2 - 40mm (SM-LG), 50mm (XL)
HandlebarPhoenix Team Carbon - 20mm Rise 780mm (SM), 35mm Rise 780mm (MD-XL)Phoenix Ride Aluminum - 20mm Rise 780mm (SM), 35mm Rise 780mm (MD-XL)Phoenix Team Carbon - 20mm Rise 780mm (SM), 35mm Rise 780mm (MD-XL)
GripsPhoenix Factory Lock-OnPhoenix Factory Lock-OnPhoenix Factory Lock-On
SaddlePivot Ride E-BikePivot Ride E-BikePivot Team E-Bike
SeatpostOneUp Dropper V3 150mm (SM), 180mm (MD), 210mm (LG-XL)JD/PIVOT YSP23GLS 150mm (SM) 170mm (MD) 200mm (LG-XL)RockShox Reverb V2 150mm (SM), 175mm (MD), 200mm (LG), 225mm (XL)
BrakesSram Maven Silver 4-pistonSram Maven 4-pistonShimano SLX/XT 4-piston hydraulic disc (Ride build)Sram Maven Ultimate 4-piston
Rear derailleurSram X0 Eagle Transmission 12-SpeedSram Eagle 90 Mechanical Transmission 12-SpeedShimano XT M8100 12-speed (Ride build)Sram XX Eagle Transmission 12-Speed
CrankPraxis Alloy eCranks E-MTB 34t - 155mmPraxis Alloy eCranks E-MTB 34t - 155mmPraxis Carbon eCranks E-MTB 34t - 155mm
ShiftersSram AXS Pod ControllerSram Eagle 90 Mechanical Transmission 12-SpeedShimano SLX/XT M8100 12-speed (Ride build)Sram AXS Pod Controller
CassetteSram GX 1275 Eagle Transmission 10-52tSram XS-1270 Eagle Transmission 10-52tSram XX 1297 Eagle Transmission 10-52t
ChainSram X0 Eagle Flattop 12-SpeedSram Eagle 70 Flattop 12-SpeedSram XX Eagle Flattop 12-Speed
DrivetrainSram X0 Eagle Transmission 12-SpeedSram Eagle 90 Mechanical Transmission 12-Speed1x12 Shimano XT M8100 mechanical (Ride); SRAM X0 Eagle Transmission (Pro); SRAM XX Eagle Transmission (Team)Sram XX Eagle Transmission 12-Speed
WheelsCrank Brothers Synthesis DH, 31mm - Mixed 20x110 F/12x157 RDT Swiss H1900 w/ DT Swiss 370 hub, 30mm - Mixed 15x110 F/12x157 RDT Swiss hybrid wheelset, mullet 29"/27.5"DT Swiss Hybrid HXC1501 Carbon, 30mm - Mixed 20x110 F/12x157 R
TyresContinental Kryptotal-F 29" x 2.4" SuperSoft Compound Enduro Casing / Continental Kryptotal-R 27.5" x 2.6" Soft Compound Enduro CasingContinental Kryptotal-F 29" x 2.4" SuperSoft Compound Enduro Casing / Continental Kryptotal-R 27.5" x 2.6" Soft Compound Enduro CasingContinental Kryptotal Fr Enduro 29x2.4" front; Continental Kryptotal Re Enduro 27.5x2.6" rearContinental Kryptotal-F 29" x 2.4" SuperSoft Compound Enduro Casing / Continental Kryptotal-R 27.5" x 2.6" Soft Compound Enduro Casing
Weight23.4 kg24.1 kg
Price£9,399£9,499£10,250£14,499
Rides similarly
Spot a mistake?
