Levo SL Gen 1 Official Levo SL Thread
Technogod
15
13
Do you remember whether you liked it for the SL? As mentioned, I'm feeling that the DPS is just not enough for me - I'm over 200lbs, ride fast with a lot of harsh/chattery and natural terrain (rocks/roots). Changing my fork from 34 to 36 did wonders for me (I kept 150mm though) I don't jump, but feel that DPS might not be enough, X2 could be overkill? (Float X won't fit with the battery)
Changing from Fox 34 to Fox 36 should have changed it to 160mm Travel.
Mik3F
109
91
Middleton
Just fitted my new shock, the bushing that were already on it fitted perfectly
Didnt need to swap them out with the DPS ones
Set it to the recommended Fox settings, but will dial it in when riding
Only downside is I have to put my bottle cage back on for my RE, as it is too tight of a fit using the Fidlock boa adaptor, still not an issue, Ill just have to remember to swap to the bottle cage before I go out on rides that will need the RE
sluette
44
52
Deutschland
Is the RE so big?
I'm using the new large Fidlock 0,75l Bottle without collision to the X2 im my L frame
Mik3F
109
91
Middleton
Is the RE so big?
Not really, its just when using the Fidlock Boa adaptor it puts it about 3mm from the bottom of the shock
When using the normal cage there is plenty of clearance
