I think the best one is 17A from Github.Hello everyone. Does anyone have a good firmware for the M500 36v? thank you
Try contact Flora : [email protected]Hi,
is the nylon gear in M500 the same as the nylon gear in M600?
Yesterday I broke some teeths on my M500 gear and now I can't find any seller on Aliexpress selling for M500, only for M600 (Aliexpress search engine sucks).
Does enybody know where to buy this gear for M500?
Could you tell which pins? I don't have spare display. This is CAN version. Do I need Besst Tool when replace controller? I also do this test and after push the power button, voltage droped to ~2-3V so it seems, fuse in controller should be ok?Hello.
Seems like controller is gone. Have you tried to swapp display and buttons? Most probably wont help though.
If you skilled, I can tell you which pin short to ground to check if controller starting (if you dont have spare display).
Have a stupid question but... can't find any button to start PMMate, you doing wrong conclusions, because you dont know how the power up works. Why u so surprised it is discharging capacitors, when u press power button? Press also minus and plus, one if it will be discharging also. There is resistor on buttons which is grounding battery.
Why u wont put down controller and inspect first pcb? Its 1 minute. That part with finns, no need to open whole motor. You look skilled. I would say you would find something blown or greenish rust on battery voltage paths.
PM me.
And yes, you would need Besst as you would need run calibration after controller replacement.
Or this can be cheaper then Besst:
? it's not locked, you just need dedicated wiringHello everyone
Is there a way to unlock the thumb throttle on the M510 FC 2.0? Thanks
You have wiring with throttle ? on mine FC2.0 its functioning well with 1t2 wireI connected the 1t4 cable
mine direct connect and work for thumb throttle.Hello everyone
Does anyone have the contact of a trusted seller who sells version 2 of the M600 engine?
I tried to buy on Ali, but there are all liars and deceivers, they send the wrong version.
I need a version that is configurable via BESST
Is it possible to adjust the assist levels through BESST?
This store is run by liars.Greenbikekit New controller with 46.2
