Thats a personal question 😆 but since you asked, my weight is 87kg so about 90kg with bike gear on. The spring was calculated by Suspension Tech and everything was dynoed to my weight and the bike kinematics.
Why no sprindex? they come standard usually on the normcorncob shock.
PS, yeah a custom tune to bike and rider is the berries!
I beg to differ. Excluding smaller batteries I made the following upgrades my full power E.
pedals 150 grams
one piece handlebar stem 200 grams
carbon wheels 350 grams
Full TI bolt kit 300 grams
Run and Exo+ of the front 200 grams
change from 11-51 to 11-45 cassette 150 grams.
There's 1350 grams right there. I could still save on a crank set, lighter rotors, seat, dropper without compromising performance.
150 gram pedals, are you insane! Is that per pedal!? Are you just standing on 2 spindles?
Just no on those handlebars. Also really not much lighter than a quality Oneup CF bar and average stem.
I only run carbon wheels but I keep breaking them, even 2 DH ones. I have a new set of CB Synthesis DH rims here for the new e-bike build. These were built with OneUp hubs and Sapim spokes and came in about 200 grams lighter than the same rims if you get their spokes and hubs.
I could get behind your Ti bolt program. Did you figure out your cost per gram? You going to sling me a set of your 3D printed motor bolts for my CX-R Antidote build? Hoping to stay under 50#s/ 23kgs.
I did that (Exo+ tires) for a long time and it worked fine and still would most of the time. But I decided to take the hit and now both and front and rear tires are absolute anchors.
Wait, weren't you on the Linkglide stuff? Pretty sure the 11-45 LG is still a 600 gram cassette right?
Regarding cranks for e-bikes, I once looked at E13's weight difference between the CF and the AL ones, and it was only a 50 gram weight difference. That's a big loss in strength (and $) for not a lot of weight. I only run Magura MDR-P rotors, Try them, you'll never go back. Also, they are much lighter than they look due to the Al center section. Seat, eh my ass only likes SQLabs and I only run OneUp droppers, which are in fact uber light.
I spoke to Norm when I ordered my shock and he said there has already been a 11 month delay on the 450-500 lbs spring and no word of when they would be available so he was working with eibach to get springs from them.
Luckily I already have the Sprindex spring but just needed the shock as the coil I was using now wont fit like alot of people. Hope mine arrives next week.
pedals 150 grams is that a joke?
one piece handlebar stem 200 grams this is not a xc bike, those are not available in ASTM 5 rated
carbon wheels 350 grams doable, but only with textile spokes
Full TI bolt kit 300 grams when they are available at some point in the future maybe
Run and Exo+ of the front 200 grams not a "fully capable" tire
change from 11-51 to 11-45 cassette 150 grams. not doable with transmission, which means you will lose one big appeal the motor offers
that's not a
fully capable carbon build
this bike NEEDS proper enduro tires and at least an insert in the back, else you can't really plow on ALL trails, what your "fully capable" implies. so no, not doable, like i said earlier. of course, if you ever only ride smooth flow trails than yes, maybe. but not for the stuff we have here in europe.
No Sprindex in my size. They are out of stock everywhere. The Super Alloy Racing spring was what Norm suggested as the best alternative so went with that.
150 grams was the weight savings. Not the total pedal weight. I think pedal weight is around 300 grams.
I ordered 2 spare ti motor bolts. So maybe I could hook you up.
Oops yeah I goofed on the cassette weight 580 grm 11- 45 so only 45 gram saving..
I assumed the numbers quoted were the weight savings not the actual weight of the replacement components?
<edit> I see that has now been confirmed
that's not a
You do you and ill do me.
I ride that set up on grade 6, national dh tracks with all sorts of ridiculousness. Ill be enduro racing on it this weekend. So yeah, its fully capable.
Ps 12 speed is terrible in the mud we get here in winter and there's far too many loose branches and vines around here to run expensive e electric derailleurs. Plus I. Think removing the sacrificial hanger is THE stupidest spec change in mountain biking history.
I stripped the transmission off my bike and sold it immediately.
11 speed link glide is the way for me.
that's not a
LOL stop it, my lad races DH without inserts. National level podiums and international at IXS and European champs. Champery, La Molina, Fort William etc etc.
and? and i ride all day, often remote, i can’t have a flat. and i haven’t had one in 4 years, so clearly i must do something right. plus: conti dh tires are usually the same weight as maxxis dd
And.... not everyone needs inserts :)
That's it really. You have a massive habit of forcing your opinions and views on here at people and anything different from your opinion is wrong.... However, that's not always (or even sometimes) actually the case. It may just be a case of misinterpreting the written word, but you seem very harsh with your views at times.
dude said „fully capable“, NOT capable enough for HIM. i take words literally, if you mean them differently that’s a YOU problem then, not a ME problem. if one thinks one can mount xc parts on a bike that goes mostly downhill, then it’s not for everyone. fully capable = ASTM 5 rated. that’s literally why we have these ratings, so ppl can expect a certain use case. this bike is atm ASTM 4 rated, and, according to Velduro UK, they try to get it even ASTM 5 rated atm. so, for a „fully capable“ build bike, all parts should also have this rating, else it‘s only partially capable.
Hilarious. Literally you say?
So when you say you "can't have a flat" do I take it you have a medical condition that will harm you if you get one or that you ride with solid tyres?
Or do you mean that you don't want to get a flat and are seeking to minimise the liklihood of getting one?
I'm voting with it being a YOU problem ;)
ok, let‘s go back to the start then. Rob posted a picture of a built bike, with NO PEDALS, at 23.97kg.
Now, please name all the parts (and their weight) to remove 1kg of this build to make it RIDEABLE, UNDER 22.97kg. I‘ll still claim that’s not possible, even with Exo+ tires.
Toffers Bike weights only 22.86kg with Pedals - but EXO Tires
(from min 12:00)
That's what i'm talking about. Take the pedals off and add DD's and ya close pretty much bang on to 1kg lighter than robs build.
That bike is a M isn't? The L frame is going to be more. I'll try to find out the difference next week and share.
Hey, Sethimus. You're actually more miserable than I first thought. You even told this influencer he was essentially brainless too. One of the reasons we bike is because of the awesome community, that community gets let down by knobs like you.
just hear him speak. not the brightest candle on the cake. that video could be half as long as it was just by having a clear thought on what you want to say instead of the mindless repetitions and fill words he used over and over
correction: i said that he has „keine ahnung“ which means having no clue and that he is a „substanzloser influencer“ which i would translate with „a shallow influencer“. which he is, just look at all those clickbait videos he has on his channel. but brainless is a bit strong…
now why would i say this? he clearly found both spoke magazin articles on the bike, because he stole one image from the first one. therefore, he should have noticed the part where they write about the cable integration in the production frames. yet, he still babbles about wanting to deaden the cable rattle by using foam -> not able to understand basic facts about what he talks about
Just for you, here's my "non-capable" 180mm e-bike bottom out testing....
FYI. That set up is 21.5kg with pedals 400wh, 22.5kg 600wh battery.
Those SRAM X01 11 speed cassettes are all steel and only weigh 250 grams and are what I currently use. The derailleurs are short & strong and only weigh like 240 grams. They are very durable ime. Combine them with an Eagle 12 speed X01 chain. The 12-speed chain is narrower, clears mud and shifts better and is also more durable than the 11 speed chains.
That's at least a 330 gram weight savings, in an important spot.
I did decide to finally go with a hardwired Transmission for the new build as the shifting performance is undeniable.
judging by the 3 pics @Rob Rides EMTB posted of his build, and by the fact that there is atm only one orderable size of invisiframe protection, my guess is he is on a size large. i put my detective hat on and made a list of all the observable parts on his frame and the weights (either from the manufacturer or weighted by R2). this is what i came up with:
Rob's Velduro Rogue Build
FrameVelduro Rogue L
Frame ProtectionInvisiframe40
HeadsetFSA No.57 ZS44/56124
ForkFox 382377
ShockFox X2763
Front WheelDT H1900 29"1029
Rear WheelDT H1900 27.5"1109
Tubeless ValvesPeaty x Chris King Gold60
Sealant?
Front TireAssegai DD 2.5 29"1320
Rear TireMinion DHR2 DD 2.4 27.5"1170
HandlebarOneup 800 50mm265
StemOneup 50mm173
Spacer3x10mm, probably aluminium30
GripsPEATY'S MONARCH GRIPS - MUSHROOM108
ShifterGX Pod45
Dropper LeverWolftooth Pro48,5
CranksAvinox 155m445
PedalsOneup Wave355
ChainringVelduro 34T
DropperOneup V3 31.6 240mm610
Seatpost clampVelduro
SaddleTerra Aidon249
Rear DerailleurGX Transmission470
CassetteGX Transmission445
ChainGX Transmission244
BrakesMaven Silver742
Front DiscSram H2 220260
Rear DiscSRAM H2 200259
12740,5
We know the weight of his build, without pedals, was 23.97kg. I found the weights for most parts but the velduro own chainring/spider and seatpost clamp and i don't know how much sealant he put in the tires. which leaves us at 11229.5g for the frame in size large, the seatpost clamp, the chainring/spider and the sealant. feel free to correct me/calculate with your own parts.
If it wasnt so muddy or stick strewen location i'd look at electric shifting. In the last enduro race which was a mud fest my boys E transmission would clog up and skip after every 3 min run. I carried a brush and we brushed out his cassette to get it shifting again for the next run. The link glide kept working through the mud. Plus ive seen 6 derrailluers torn to bits on e bikes in the last year. two of which are mine. I say no to $1000 derrailluers.
I'll end up in a similar range than Rob:
Headset
ForkIntend Flash2350
ShockFast Suspension 550lbs970
Front WheelTurbine V2 29843
Rear WheelSidekick/ARC31 Carbon/Pillar1077
Tubeless ValvesAirfix Super Valve 40mm60
SealantMilkit 250ml280
Front TireKryptotal Fr Supersoft 29 2.41290
Rear TireKryptotal Re Soft 29 2.41220
StemNewmen 318.4 50mm104
Spacer2x10 Carbon9
Grips70X M116
ShifterGX Pod45
CranksAvinox 155m
PedalsOutlier Pendulum454
Chainring
Seatpost clamp
Saddle60X 14cm264
CassetteX0 Transmission380
BrakesIntend Trinity514
Front DiscTRP RS05E 220256
Rear DiscTRP RS05E 203222
12131,5
(missing the insert i haven't decided on)
FYI, that weight listed for the Fox 38 Grip X2 is way too generous. LLM (possibly hallucinated) real world numbers:
  • Actual/Tested Weights: Independent tests and user reports generally show the real-world weight to be higher than the manufacturer's claim:
    • One test recorded a 2,434 grams weight for a Factory GRIP X2 model.
    • Another review weighed a 29", 170mm travel fork (which is very close to the 180mm variant) at 2,383 grams (with a 7.5" steerer tube).
    • Another tested sample, a 29" 170mm fork with a 190mm steerer, came in at 2,381 grams.
    • A sample with an uncut steerer was reported to be over 2,400 grams.
yes you're right, was probably the grip x version, that damper is lighter than the x2, i'll edit it and us the weight from r2 (2377g)
    670K
