Yep! I am aiming to head down to Somerset end of the month with it if you’re able to? Could possibly stretch to FOD.Can I have a go? Please? Pretty please?
They are sending me one hopefully ?
Will do a full on video, ride review etc etc and some nice pics for the site.
Also, In my conversations with some manufacturers they are not promoting their own bikes too much as they can’t get enough bikes in to sell (and don’t want to annoy customers!!) One Brand said they have had to hold back on all marketing and magazine reviews due to low availability.
Wouldn't it be possible to add bosses even as it is now? Looking at your picture with the bottle strapped on the top tube it doesn't look like there is a whole lot of clearance for just any cage, but they could use it as an opportunity to sell a cage and bottle that fitted those dimensions, just like YT who charges a horrid price for their cage and bottle just because noone else makes one that fits the tiny hole under the shock.The only real thing i would change on the bike is to have the top tube run like the line in this pic, and Vitus put some bottle bosses on the under side of it, as the extra space in the triangle would allow a cage and bottle to be easily fitted - i think the only reason it is like this at the moment is to allow standover height for people sizing up, but for me at least its got a low standover so i don't think would cause any issue. I might even suggest it to them!
If possible, also mention some of the negatives and compare it to other bikes.
I find that far too many "reviews" end up being a bunch of riding footage, some information about the bike that is also easily obtained from looking at specs and a statement about "this bike is good".
Also, I like your tool placement on the bike. I think i'll copy that!
The problem with looking for faults, is that it can become nitpicking or personal preference, and can ruin a review. You've only to check out magazine reviews and it become the reviewers dislike for "the width of the handlebars" that makes one bike better than the others in a group test. I'd go as far as suggesting very few bad mtb's are now made, more likely the bike if it does review badly, it's because the reviewer isn't using it for it's intended purpose (specialisation).If possible, also mention some of the negatives and compare it to other bikes.
The m1900 rims...is the yellow "tape" on the inside OK for tubeless or did you need to pull it off?
Sounds like you need some rat bites in your tyres ,First breakageDestroyed the rear rim coming down the Cobbler this evening. Think it was at least (more than) partly my fault. There are hundreds of drainage channels across the path and they need clean bunny-hops. Rear weight is difficult (for me) to manage good hops.
Anyway, I'm thinking Deemax but will decide tmrw.
Had mine a couple of months now and the usual niggles, dropper post lever very stiff, battery life a bit dissapointing and rats nest of wiring at the cockpit but all this I can sort.
I did have an issue with it not free wheeling very well but that came down to rear brake setup.
Used E-tube to customise map but just turned everything onto low but I don't use boost as it eats the battery as most of you will know.
With this setup I managed 2 loops of Ae forest yesterday totalling 27 miles so that's all good.
One issue I found yesterday is the lower shock bush has some play so fired an email to wiggle and await response.
I'm looking for more tuning options withe the steps motor if anyone has info that'd be great.
Overall a cracking bike at any price point.
Did you re-route you're dropper cable the New?I got mine yesterday, and it's a hoot! Super fun and size wasn't a problem at all. I initially cursed at the dropper, but it turns out that it was just installed pretty badly and a large kink in the cable prohibited it from working correctly. There were also several bolts that wasn't tight and the brakes rubbed a lot. The spoke magnet was also in the wrong place. All to be expected really, except for the kink in the cable.
After some fiddle with e-tube the firmware got updated and it was smooth sailing. Until the bike stopped. E010 was shown on the display 2 times. Reboot of bike and configuration "backup" seems to have worked. I haven't seen it since.
I also got a W013 a few times. I found out that if you turn on the bike while pedaling the sensor won't initialize properly and an error will show.
But other than that ... wheeee! Can't wait to get home from work today!
Good times!
No I used a set of huge pliers to straighten it out and it has worked fine since!Did you re-route you're dropper cable the New?
