4000ft in 11miles is my usual midweek Emtb ride. All climbing is either trail centre armoured surface, bridleway or fireroads (some bits are steep) and all done in boost as quickly as possible.
Local from the door riding here it's nowhere near so hilly. 20 miles and 1800ft sounds about right for a regular loop i've been doing for 15 years. On the Sommet this uses 2 bars, if that. again all climbing done in boost mostly at 14mph. (although on the flat and downhill I'm generally above the 15mph assistance limit or sat at it not really stressing the motor at all).
At a local DH/Enduro spot where half the climb is fireroad and the other half steep/technical with a few very muddy steep sections. and unridable on a normal bike i got not much more than 3300ft of climbing in roughly 10miles again all on boost and at full speed. blasting through those muddy unridable sections 12 (3 per climb) were deifinitely the cause of less range.
I rarely use eco at all and using the app upped "trail" to MID as I thought it was pointless on LOW.
I don't use a pack of any sort at all or even carry water on ebike rides as I barely sweat. I don't know what I weigh just now. my bathroom scales are broken. But I am around 1.5-2st heavier than usual at I'd guess somewhere in the 15.5-16st range in riding kit. I'm still fairly fit though and a pretty strong rider.
If I wanted to ride for longer/climb more I would just take a normal bike a normal full days ride on those can easily be 10000ft in about 25miles. No Ebike can match that sort of range and trying to eek out that mileage in eco would feel utterly pointless to me.
hope this helps.
Where do you manage to climb 10000 ft in 25 miles
Have you tried using another battery? Might be worth trying to borrow one
Zippy what your describing range wise is about the same as were all getting with shimano , it’s got a bit better now weather is warmer and trails are dry but 20 miles 2000 ish feet climbing all fairly tough off road is about it for a battery . The guys who are lighter than me are getting a bit more but it’s not a huge amount . If I go out alone for a quick ride and work hard on my local hill which is grassy and quite draggy on the climbs using mostly trail and a bit of boost I can kill the battery in 15 miles and 2500 feet of climbing in less than an hour and a half , that is steep quite constant climbing in the lower 3 gears . I think the range and red warning etc on the shimano is very inacurate. Getting the red one bar on the display when the battery still has 2 bars is a bit misleading Japsuride reckons his Bosch Cx wasn’t much better in the same conditions and similar on easier longer ridesIt's my plan, but all my e-mtb friends have either bosch or yamaha e-mtb's, so I need to approach a shop and ask for a loan (rental).
looking at my usual loop i probably do 4 ascents of reigate hill on trail with bits in boost, which according to this website is 215m elevation and 1.3km long:
Segment Details for Reigate Hill Top Speed Challenge! - VeloViewer!
So if i am doing this 4 times i am hitting 860m/2800 odd ft of elevation/climbing minimum on my loop
But no sir, your numbers are incorrect. Reigate Hill accounts only 83 meters of ascent - your 215 meters is the maximum altitude. It is the elevation change that counts, not the max elevation. Average grade of Reigate is "only" 6.5% .
So, 4 times Reigate Hill adds up only 332 meters / 1090 feets of positive ascent.
As a side note and maybe worth noting is that whenever someone is using a phone (app) as a fake altimeter, the total ascent is typically two times too high number, due to natural GPS inaccuracy in vertical direction. Garmin and many other real sports equipment are using atmospheric pressure for altitude, which is much better (but still inaccurate, especially when the weather changes suddenly).
I'm going to have to disagree with you here. When I go out with the work roadies I use Strava on my phone and most of them use Garmins. The difference in mileage and ascents is negligible.As a side note and maybe worth noting is that whenever someone is using a phone (app) as a fake altimeter, the total ascent is typically two times too high number, due to natural GPS inaccuracy in vertical direction. Garmin and many other real sports equipment are using atmospheric pressure for altitude, which is much better (but still inaccurate, especially when the weather changes suddenly).
Device without a barometric altimeter and the Strava mobile app:
If your activity was recorded with the mobile app or with a GPS device that does not have a barometric altimeter, Strava will use your activity's GPS data to "look up" the elevation for each point you record.
Nice. I know that they are selling extremely well ?I ordered an e-sommet VR. They write it will be here friday. I just hope it fits, they only had XL left.
They should be! Killer specs and cheap. I half expected them to cancel my order, I thought it was an error. After discount, the VR version with 170 RS Lyrik, it seems like a steal! I can't wait.Nice. I know that they are selling extremely well ?
@R120 I was actually trying to log in here to agree with you about just how good a bike the Sommet actually is. The suspension as you say is so good. You actually stop thinking about it underneath you.
I had a lot more to say but after typing that disertation in the name of saving face *sigh* I just can't really be bothered right now.
Manualling it. Or initiating the manual to reach balance point takes a whole different approach. You need to throw your upper body back and kick the rear wheel forwards (not pedal BTW) with such force if you did the same on your normal bike you'd be K.O.d on the floor behind the bike.
I can't imagine how hard it must be on a L or XL.
I knew this would be the case before I bought mine but even then wasn't ready for it. This is actually one of the main reasons I didn't even consider choosing a medium despite being 5'11"
It's on https://www.wiggle.co.uk/secure/myaccount/PersonalDiscountWhere did you find the discount, and more importantly do i have to prove i can do 10000ft in elevation a day to earn it!
Quite keen on a Vitus hardtail for the quiver
RRP is £3600
Wiggle 17% off £2988
Agreed. More pictures and more info please. Ride reports and live footage also welcome!![]()
It would be really helpful! Even though I already pulled the trigger on the bike and it should arrive Friday, I think it would be extremely helpful for anyone looking to buy the bike. Especially comparing the bike to other direct sales bikes if possible. I almost bought the Commencal power meta, but then I saw this extremely good deal on the e-sommet and I noticed a distinct lack of information about the ride characteristics and basically any information not easily read by the specs sheet. Also some comments about sizing would really help people who are trying to decide.Ha ha ha, the last thing you want is footage of me riding a bike. It's pretty slow going with a soundtrack of heavy breathing.
Happy to do a video review if it will be helpful.
Iain
Volts, how did you manage to get 17% discount, as Platinum customers 'only' get 12%?
EDIT: I missed a bunch of post before posting, sorry, I see it was Wiggle offering the discount, which is strange for such a popular bike
They are sending me one hopefully ?
