Kenevo 2020 Upgrade/Parts Thread
Peko
I'm sure, lot's of parts will be changed around the new Kenevo. Let's show them here.
My S4 Kenevo Expert changes until now:
Tubeless (of course)
Sunrace 11-46 MX8
600lbs spring instead of 550lbs
Specialized Bennies pedals
Coming soon:
SQ-Lab 611 saddle and 70x grips
My 2020 Kenevo Comp now has the following fitted...
Fox 40 forks
Hope Pro 4 hubs with Fortus rims
Renthal direct mount stem
Burgtec 800mm bars
700 lb rear spring
Hope Tec3 V4 brakes
Hope floating discs
Hope seat clamp
Renthal sprocket
700w battery upgrade
Charge Spoon seat
Invisframed
Burgtec headset
Burgtec pedals
SRAM GX rear mech
Magic Mary 2.6 tyres
Vittoria airliners
DMR deathgrips
Just a custom graphic kit left to turn up and then it's all finished.
Fox 40 forks
Burgtec 800mm bars
700 lb rear spring
Hope Tec3 V4 brakes
Hope floating discs
Hope seat clamp
Renthal sprocket
Charge Spoon seat
Invisframed
Burgtec headset
Burgtec pedals
SRAM GX rear mech
Vittoria airliners
DMR deathgrips
travel of your fox?
offset?
Pics or it didnt happen people ?
I like what Specialized did with the looks of the comp, so no cosmetics!
Upgrades:
Ice Spike pro 27.5x2.6
Crud XL fender
Planned upgrades:
Smashpot coil conversion of Bomber Z1
31.8x 35mm DMR Defy Stem
shock spring from 500 to 450 lbs
Back fender (undecided)
Fox 40 forks
Burgtec 800mm bars
700 lb rear spring
Hope Tec3 V4 brakes
Hope floating discs
Hope seat clamp
Renthal sprocket
Charge Spoon seat
Invisframed
Burgtec headset
Burgtec pedals
SRAM GX rear mech
Vittoria airliners
DMR deathgrips
Just seen the graphics kit you got and wondered who you got the from ? I’m after some sky blue graphics for my 2020 comp !
Do you need to strip the frame then rebuild or is that included ?
Sweet ! I’ll give them a call ? Swore I’d never buy another brown bike ☺️
Upgrades:
Crud XL fender
Planned upgrades:
All upgrades are done!
Ended up with a mudhugger in the back.
The smashpot made the fork super plush. But trails are snowy now, so cannot really compare to the original setup.
How did you get on with fitting the Crud Fender XL, there was interference with the brake cable retainer on mine and i didn't want to cut the mudguard?
Final upgrade fitted now. After issues with the standard shock went for a Fox DHX2 shock. Just riding it round the block it already feels better, roll on its first full on test
Nice. (y)
Unfortunately there is no option for the 140mm Yari on my Levo, but I'm interested to hear how it works on the trail.
