This M560 is horrible noise...This is mine m560, do you think m510 is more silent?
I saw somewhere nylon gears replacement so maybe could help even more. Not sure if m510 has nylon gears by default.
Indeed but I guess all of them are like that ? Can you say something about m510? I know they are selling peek gear for this motor but not m560 so wonder if it’s quiet. Especially if that high pitched ugly noise is not there. I saw some m600 and this looks like more silent than m510This M560 is horrible noise...
Thanks for video. It is also notThis is the sound of Bafang M510 with new 3.0 controller.
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.www.youtube.com
If u look for silent go get DJi Avinox motor or Bosch CX5Thanks for video. It is also not
very silentBut guess more quiet than mine actually. is there a noise difference between fc2 and fc3 ?
I have gen4 and yes, it's night and day but gen3 was even more silentIf u look for silent go get DJi Avinox motor or Bosch CX5![]()
open in and check if bearings are okay and not causing horrible vibrations . try john deere header grease - it turns into fluid when compressed and turns into solid when not compressedI have gen4 and yes, it's night and day but gen3 was even more silentBut this bafang is on another bike. It might not be super silent but how mine M560 is simply unacceptable. My ears are in pain on trail, can't believe it's normal even for bafang. Anyway, M510 with peek gear could help a lot imo. Not sure if that guy in video had it installed. There is also peek gear for M600 but no peek gear for M560.
Mine is not RS labelIs the Bafang M510 FC3.0 the RS version or something else?
Who/where did you get the 3.0 controller from? ThanksThis is the sound of Bafang M510 with new 3.0 controller.
- YouTube
Hmm, how it is in real ? From video seems a bit noisy but it could exaggerate. Mine M560 is horribly loud so not sure if it's faulty or is normal. I've bought also M600 but it suffers from power scourge, in hills the power oscillates don't know what it is. But is much more quiet than M560. M510 on its way so I hope this will be much quieter than M560. Maybe I have to install nylon gear.This is the sound of Bafang M510 with new 3.0 controller.
- YouTube
The M510 should be just as quiet as an M600 if not even a little quieter. I’m sure M560 is “normal” based on the video. Anyone saying they have a “silent” M560 either came from another really loud obnoxious motor or a 1st gen M560 which the current version is an improvement over. It’s just a loud whiny motor, if anyone truly has a quiet one it’s absolutely an outlier and probably not correctly madeHmm, how it is in real ? From video seems a bit noisy but it could exaggerate. Mine M560 is horribly loud so not sure if it's faulty or is normal. I've bought also M600 but it suffers from power scourge, in hills the power oscillates don't know what it is. But is much more quiet than M560. M510 on its way so I hope this will be much quieter than M560. Maybe I have to install nylon gear.
It is a set with CEF69 frameset.Who/where did you get the 3.0 controller from? Thanks
Just the same with old M510, M820 is louder than M510. I have both but not yet try M560.Hmm, how it is in real ? From video seems a bit noisy but it could exaggerate. Mine M560 is horribly loud so not sure if it's faulty or is normal. I've bought also M600 but it suffers from power scourge, in hills the power oscillates don't know what it is. But is much more quiet than M560. M510 on its way so I hope this will be much quieter than M560. Maybe I have to install nylon gear.
Yeah, it's really hard to understand people who claims M560 is silent. I've read that "new" version should be more silent but it strongly depends who says so. Maybe I have another imagination what silence is because I'm used to Bosch gen4 motor which I thought it could be more silent because I've had gen3 which was a breeze. But this M560 of mine, oh god this is nasty sounding motor. It's really like jet and I'm embarrassed to ride with it. But it could be it's either a old version or something not right with it.The M510 should be just as quiet as an M600 if not even a little quieter. I’m sure M560 is “normal” based on the video. Anyone saying they have a “silent” M560 either came from another really loud obnoxious motor or a 1st gen M560 which the current version is an improvement over. It’s just a loud whiny motor, if anyone truly has a quiet one it’s absolutely an outlier and probably not correctly made![]()
OK thanksIt is a set with CEF69 frameset.
I tried to firmly lock these gears. Unfortunately, the controller throws an error if the rotor spins when it shouldn't. You can only ride with the throttle pressed.Have finally gear with one way bearing for M560. After half a year!
Had an idea. To replace it with normal gear pair, with solid shaft. I dont care If rotor is turned with pedalling. And should stand even more power...
Sorry, for out of topic.
Hmmm, gives you error? So for example when you have PAS level 0 and you pedalling? Interesting. What error number you got?I tried to firmly lock these gears. Unfortunately, the controller throws an error if the rotor spins when it shouldn't. You can only ride with the throttle pressed.
It's impossible to even start moving without the throttle trigger. If you ease up on the pedal while moving, causing the motor to shut off, but continue pedaling, the controller initially shuts off the motor without displaying an error. If you stop for a while, the motor works again. If you continue pedaling, an error appears. Unfortunately, I don't remember the error number.Hmmm, gives you error? So for example when you have PAS level 0 and you pedalling? Interesting. What error number you got?
Baby steps... Elon is certain we will be partying interplanetary soon.usa could make gaskets , they want to go to the mars , so they might start with gaskets ...
Hmmm, does not make sense to me. If you pedalling with some assistance, controller can not know you have locked that gear. Interesting.It's impossible to even start moving without the throttle trigger. If you ease up on the pedal while moving, causing the motor to shut off, but continue pedaling, the controller initially shuts off the motor without displaying an error. If you stop for a while, the motor works again. If you continue pedaling, an error appears. Unfortunately, I don't remember the error number.
cnc or sourcing from bafang ?Anyway to get spare gear for M560 took me 9 months and lot of confusions, crazy.
what is new ?M510 FC 3.0 firmware View attachment 168773
