I had my 2019 motor exchanged early January due to the noise issue. After the exchange I noticed the motor firmware was 6.0.0 where my old motor had 6.1.0. I don't know the difference between 6.0.0 and 6.1.0 so I thought the newer the better. Maybe this can explain the watt peak power difference? What firmware are you having? Be careful, for obvious reasons, too that when upgrading motor or battery firmware at your LBS, they can not exclude the TCU so if you currently are running 2.025 or 2.019 it will be upgraded to 2.026. (like mine)
My max. recorded motor peak power is 723W at 37V and 19,8A. My cadence at that moment was 77rpm and I delivered 305W at that moment. The assistance was 32% with peak power 100%. I was riding with BLEvo smart heart rate and smart leg power.
I keep thinking that it's not interesting to measure the amperage. I full agree measuring and comparing power in watts makes sense. I keep stick to this opinion as power is the result of voltage and amperage and voltage will drop in time.
Regarding the 410%, I need to check another post of Specialized Rider Care. If I will find it I will add it in this post. -> I found it again here it's explained:
Understanding Support vs Peak Power in Mission Control App v2.0 - EMTB Forums
So taking the above in mind at the moment I received 723W from the motor as a peak, my input was multiplied by factor 2,37 and that most likely is due to the assistance was set at 32%.
What I will do next time when I go, especially for you Kiwi, I will run turbo at 100%/100% uphill and will give all power which I have in me. I will check the results afterwards and let you know. I guess you then have a good comparison between a 2018 Levo, your 2019 Levo (of which I don't know the firmware update) and mine.
Good idea?
