The Official BLEvo Thread
Status
Not open for further replies.
I might have found it: based on previous posts, I went into the Blevo settings under apps and made sure the optimisation is off.
But when you say now battery optimization, I believe it is somewhere else....see below.
I have now selected that BLEvo can use as much energy as it needs.
Will test this.
View attachment 12018View attachment 12019
Which Android version you have?
Yes, but the speed value will be wrong.. I need to implement some speed adaptation when this kind of system is used...
Don’t want to correct the master but within BLEvo there is already an option integrated which allows to use GPS for speed and distance instead of using the bike speedsensor.
So if tuning systems (like Badass, LSS, etc) modify the magnet pulses to increase the cutoff speed, selecting this option should provide the correct figures again.
What difference does Blevo madness setting make compared to Default Specialized? (I'm on firmware 22)
I see in the instruction that in madness CM = 0 whereas in Default CM = 100 the other settings are the same. Can someone explain CM to me as in the instruction manual it's not very clear. Thanks
Also I've read on this thread that updating the firmware to .23 should give me a higher max power output. Do people find that this corresponds to a reduced range?
The CM 0 setting is a special setting because in the firmware x.22 there was a bug that with the CM under 20% the behavior of the motor was better. CM 0 is the most reactive setting you can have. CM 100% consume a lot..
HI Paolo, - I have a Levo Expert and am using Blevo, which is fantastic. My problem is that the phone I use is an old Iphone 5s (only used for app). App worked very well but the battery only lasted 2 hours. So I found a Vodafone video to improve battery life and turned lots of things off. Now when I use Blevo I do not get and speed, distance or time showing as I am riding. Do you know what I need to turn back on to fix the problem?
How should he know this?!
Maybe the best idea is to undo the settings from the video step by step and to figure out what it is/was.
I'm guessing that the GPS unit has been deactivated.
It was valuable - more than your question.
Sometimes people should just try to think...
It worked before, you followed a video with battery saving tweaks, now it doesn't work anymore.
What could have been happened during that time? :)
Btw. it is quite normal that Belvo is sucking battery like hell (display, gps...). You should get a power bank.
10,000 users !!! (Apple 45% + Android 55%)
Target that I never imagined !!
I have to thank all the testers and users for making this App grow as unexpected .. without your help and your advice BLEvo would never have reached at what it is today ..
Thanks again.
Paolo
Thanks again.
Paolo
Without you Paolo we would not have the amazing App BLEvo ?
Congratulations Paolo with the huge milestone and great achievement! Every BLEvo ride with it’s proportional smart heart rate and leg power support makes me smile! With the new openandroid maps and the remote I even don’t need to consider a Garmin device anymore.
Keep up the good work!
Finally, after a long wait, I also release the 3.4.0 version of BLEvo for iOS with the addition of remote control management.
In this video I explain how to configure.
Here are all the news:
- Added remote control management
- Increased the help of the Smart HR when connected to the Smart Power
- Added "Support BLEVO" page
- Added audio message to understand when the GPS is not in coverage
- Added additional checks on the validity of GPS coordinates
- Bugfix: Now if it does not find the GPS use the bike sensors to calculate the movement
Thanks again.
Paolo
Congrats Paolo, molto bene!
Hi.. I have a Kenevo 2019 and a sunnto spartan wrist HR. Does anyone know if the app works with this HRM?
Hi Paolo,
Is it possible in one of your next updates to display the Battery Current reading in the ‘after ride’ statistics.
If it is, could you display the maximum and the average readings for Eco, Trail and Turbo please?
Hi @PaoloBLEvo. Love the app, its far superior to mission control. The only thing i cant work out is how do I tell blevo that ive changed my battery half way through a ride? After a recent ride it wouldnt connect with my 2nd battery without ending the ride so i had no data using the 2nd battery. Other than that id say the app the near perfect, carry on and thank you!
Hi Matty
Can you tell me how you carry the second battery , what model back pack?
Wow. 10.000 times €10, you are rich!!!! ;) You can buy 10 s-works levos!
Also, as an answer to a question before: a connect IQ version is not just difficult, it is impossible. But there are already levo data fields for garmin.
Hi Vilt, from a reliable source I understood Apple and Italian taxes are significant. If you then devide the amount what then remains by all the hours which are invested in BLEvo development (which even still continues) and the support afterwards via all the forums I guess Paolo, could have better worked at a local pizzeria and earned more and had less stress or spend more quality time with his family. ;)
I keep finding €9,99 for this impressive app a bargain as we have all spend >€5k for our bikes.
Hi Paolo,
Maybe a stupid question, but why do you need this value? If you like to know the value you can easily calculate it by deviding the power (W) by the voltage (V). The voltage is roughly 36V so the outcome should present the Amperage (A).
P=UxI
Power (W)
U = Voltage (V)
I = Amperage (A)
P=UxI
Power (W)
U = Voltage (V)
I = Amperage (A)
Why do I need it? Simple, because the information is available and is ‘Currently’ pardon the pun, what I need for an ongoing investigation of mine. If the info I have requested can be displayed in the ‘after ride’ stats that would be perfect for me.
I suppose you could ask why I also need the info in the screen shots below.... my simple answer is... If it’s available, why not? I need some of it but there maybe someone out there who needs all of it. I don’t want to spend loads of time calculating when the results can be just be displayed like everything below.
Do you use BLEvo?
Status
    Join 43,212
