Guys I need advice.
Last week I fitted a long shock kit and new x2 shock to my levo. So far so good. It looks the business fitted to the bike.
I'm struggling to get the correct sag from the x2.
I'll be honest I'm a heavier rider at 110kg kitted up and even without my kit on I cant get the sag correct. I pressurized the shock correctly (stopped every 50 psi and pumped in to equalize) and I'm now at max pressure and the sage is something like 38%.
The strange thing is is that it also ramps up massively toward the end so I don't think it will ever reach full travel.
Is this right?? For my weight (Plus 10kgs for gear) Fox says I need 260psi. That coupled with the fact the link is supposedly meant to allow lower pressure too?
Now: The X2 is new and bought from a reputable online shop in the UK. However, when Ives scanned the QR code it comes up as being set up for a Ibis HD6 enduro bike. Would this make much difference at all?
Am I better off switching to a float x that can handle higher pressure?
I ride mine as close to 30% sag as I can get, if you’re at 38% you need to let some air out to lower your air pressure. 19mm of sag will put you at 30%, you can also measure your eye-to-eye if it’s easier for you, you’d want to be at 211mm sagged for 30%.
