Tieff
So let's hope that both of you will pass the tests!Good news:
No powercuts after this part of the trail...
Tests will continue!
Is a pass/break (me or the bike) result!
Hey @Niklas which model and what Q-factor did you order from Miranda?
How do they fit the bike?
sorry for the late reply, ever since then, zero problems so far
Hi Mike,Hi Folks
looking at buying a strive on 750 watt, currently had a Trek rail for the last 3 years with zero problems, hopefully I won’t regret it.
Could the older Bosch (non smart) be more reliable than the new system ?
Having read about the multitude of battery connection issues I am wondering if anybody has replaced the catch mounting with a bolt in system, I can’t see me having to remove the battery that often and a couple of screws would not be an issue.
A ridgid mount would solve a few issues.
Mike
You mean you are using the "Tobias rebuild kit" which is different from the Cascade Components latch replacement?
Yes! I paid 20 including shipping to the US. Installed in 5 minutes and works perfectly.You mean you are using the "Tobias rebuild kit" which is different from the Cascade Components latch replacement?
There are different positions where the battery can cause the noise. Please have a look at the STRIVE:ON POWER CUTOUTS forum from @Mario Antony and also some posts from him in this forum. He describes very well what can go wrong at the latch and the upper bracket. You'll have to check the screws and secure them with Locktite. Unfortunately my lower arms are a bit too thick, I can't reach the upper bracket with my hand without needing a surgeon to release my arm again... But if the battery is not pushed tightly enough to the upper bracket by the latch mechanism (this is when the latch is worn out or damaged over time) it has some play (mainly in the upper bracket). This can become more worse over time and finally it's so much that you can hear the battery moving. This however is already a later stage and damage of the battery contact pins is very likely. But also the upper bracket can move together with the battery if the screws are not tightened and secured correctly. So better check everything which is related to the battery latch and upper bracket. If you close the latch and you can still move the battery (even very slightly) then you'll have an issue. The point is, that the battery is not held by the Bosch rail (which is the case in other bikes) but just by the latch and the bracket... which is (I mentioned it already before) a severe design flaw in my eyes and the one who did this design should get a big slap on his a** at least!I have now also ordered the Bosch Power Latch from Cascade Link and hope that this part will finally calm my bike down on the downhill.
Bike Canyon Strive ON CFR LTD.
Where or how exactly is the battery causing the noise?
Does anyone here know more and can explain it?
Thanks Marco
Heeeee @Marco0809, you already have it... Mine is still on the way... Jealousy, jealousy
I wouldnt recommend this bike to anyone. These problems are an inexcusable waste of new owners' resources.Hi Folks
Mike
The stock chainring size is 36t, which works pretty well for me without me calling myself a weak/slow rider, but as we all know, that's relative.What is the maximum size of chainring ?
I sympathise with the owners especially since the bike rides so well; but if they expect a better design of the bosch battery clamp will solve the problem I fear they will be disappointed.I wouldnt recommend this bike to anyone. These problems are an inexcusable waste of new owners' resources.
An incredibly lame flaw that doesnt get enough attention is that the maximum chainring size is insufficient except for the weakest/slowest riders, and there is nothing we can do about it.
Just checked my Trek rail and it’s a 34 and never really noticed a problem with it other than balls out down hill on the road and then I just freewheel once I’ve beaten the gearing So a 36 should be fine for me.The stock chainring size is 36t, which works pretty well for me without me calling myself a weak/slow rider, but as we all know, that's relative.
That's what I'm saying too. The Canyon Strive:On has an extremely unfortunate (to put it mildly) design when it comes to the battery mount. The 750Wh battery from Bosch weighs 4.3 kg. Hanging it not on the rail provided for it, but only on the latch, is something that no reasonably experienced engineer would even think of. I just don't know what the Canyon people were thinking and why Bosch approved something like that???I sympathise with the owners especially since the bike rides so well; but if they expect a better design of the bosch battery clamp will solve the problem I fear they will be disappointed.
I have no doubt re-designed, or 3rd party versions of the clamp, will last longer, but having followed the thread on this problem, I am convinced the clamp is a victim rather than the cause of the problem.
A permanent solution needs to be one that properly secures the battery. I have 2 bikes that use the Bosch clamp, one of which has covered over 1000 miles. Neither bike has caused any problems or damage to the clamp. Both bikes use the full Bosch rail system to hold the battery however.
Don't agree, Bosch is obviously a supplier! And as you say ... for a reason... they choose a specific design. So, if a bike manufacturer doesn't stick to the requirements Bosch should have a say, because that is not according to the requirements. Just compare to what happens in other branches (for instance in Automotive industry)...Bosch is merely a supplier in this scenario so has no say in how any brand chooses to secure the battery. What is relevant however is that Bosch chose to design a complete system consisting the battery, rail, and clamp.............for a reason!
How? Refuse to sell anyone a 750 Bosch battery unless they also buy the rail? Not practical.Don't agree, Bosch is obviously a supplier! And as you say ... for a reason... they choose a specific design. So, if a bike manufacturer doesn't stick to the requirements Bosch should have a say, because that is not according to the requirements. Just compare to what happens in other branches (for instance in Automotive industry)...
Quantity pricing, availability guarantees, and warranty parameters are all negotiation topics that canyon and bosch would have had, as industry professionals.How? Refuse to sell anyone a 750 Bosch battery unless they also buy the rail? Not practical.
