vikino1
I tried to use this FW of yours with Beestom. I don't know what happened, but after uploading the engine remained dead, it couldn't be started at all. Dado helped me a lot. And I didn't experiment with it any more.
Do you have an Email for Flora or a link, thanks.U can contact Flora Yuan from Changzhou Joyebikes. I got 46.2 controller from her. I think she still have it.
PM meDo you have an Email for Flora or a link, thanks.
do you mind sharing the file?I received last year from Joyebikes a m600 CR X10N.500.FC 3.2 with FW CRX10NC3625i132047.2 for 36V. I tried to modify the parameters for the speed and current limits. After uploading the new parameters nothing has changed. I requested a new firmware for the motor but received just the already installed version 47.2 which I uploaded again with BESST-Pro. Now only the highest level works. If the max PAS is 5, level 1-4 doesn't work at all (as engine is switched off). I tried to set all parameters to 100%, no change, lower levels are not working. Any ideas what goes wrong?
If I try to calibrate the torque sensor I don't get any response from BESST. Is this normal? Also the position sensor calibration never finish (it starts to turn the wheel, stops but the tool still shows "Please wait"). Manual test of the torque sensor shows changes if I push the pedal (e.g. from 750 to 880).
I should contact the Bafang Service center in Poland. Does anybody has experience with it?
None of experimental f/w is working. Don't use it.Hi, I own a M600 48V running it with a 52V battery. With the LVC at 20% I won’t be able to discharge the battery fully to 38V. I did saw the FW ‘experimental 48v25a (38v lvc)’ posted by ornias. Anyone experience with this FW? Is there another solution like running a 42V FW?
Bafang_M500_M600/Firmwares/Custom/Motor/m600/experimental 48v25a (38v lvc).bin at 53792f024da25d133ba1ba377a9310bfb455c6e0 · OpenSourceEBike/Bafang_M500_M600
Contribute to OpenSourceEBike/Bafang_M500_M600 development by creating an account on GitHub.github.com
You dont have much options. That 25A firmwares are not working fine.Hi, I own a M600 48V running it with a 52V battery. With the LVC at 20% I won’t be able to discharge the battery fully to 38V. I did saw the FW ‘experimental 48v25a (38v lvc)’ posted by ornias. Anyone experience with this FW? Is there another solution like running a 42V FW?
Have you tried the 46.9?Here is my comparison with 46.6 fw (Mainly against Luna 14.6)
= more agressive ramp up/down , but not as violent as on 46.7
= stop after propelling in 1-2 seconds, which is OK. Depend on PAS level used.
= going uphill is more fun then Luna fw, but calories burned (at least value from computer) is less on Bafang fw.
I added calories burned and avg speed value, to compare for future tests as well.
Only downside i found on 46.6 fw is range calculation, which is varying a lot. looks like strongly depend on battery V/temperature and is not relevant. Recovery rate is much more then other fw. (luna, bafang 46.7+)
Luna fw looks like very eco oriented, good for people who want:
- use own "manpower" for propelling as high as possible
- for distance gaining
- for difficult terrain, where adhesion is more important than just pure power
myself i prefer 46.6 more to fit my style.
I will recompare with longer circuit to zero battery, but this need higher parts out of snow, so i must wait a bit.
Kiwitourer, how does the new firmware version effect throttle input, is it still limited by the PAS setting or does it give 100% in all settings?I have attached the revision earlier in this thread. It is looks like it has set L1 at 15% power and then 35 55 75 100.
Hi. I very rarely use the throttle but my sense is that the throttle power varies by setting. For example, I use the throttle to assist with hill starts on L1 & L2 and it is manageable and it works fine. If I use the throttle from standing start on L3 or above I get a error code (21 - I recall) and the bike needs to restarted. I can use the throttle fine on L3-5 when I am moving on the flat.Kiwitourer, how does the new firmware version effect throttle input, is it still limited by the PAS setting or does it give 100% in all settings?
bumpHave you tried the 46.9?
In your opinion the L5 on 46.7 weaker than on 14.6 or stronger?
Anyone tested when power is starting to be reduced on 46.9? (its also 30% or different?)
Today I added comparison with Luna 14.6 firmware:
My observations:
- PAS1 is very nice, exactly what I needed. Current is not over 5A, usually I see 3-4A.
- Instant drivetrain stop when you stop pedaling like bafang 46.7. Like it
- Overall, i feel like less powerfull then 46.7 (maybe like 46.6?), mild and not kicky. It will be good to compare with 46.6.
Values/numbers are below. For future tests i must:
- change wheel size to match 1:1
- track range only on PAS1, or PAS0, as every fw is calculating range differently (and differently on each PAS level).
I tested today the 46.9.Yes 46.9 is stock and came with the motor from the factory. I'll test the other elements and get back to you.
I may be limited by my odd version of the DCP18 display. My range of watts and amps is capped visually and it does not have bluetooth.
| fw | 14.6 | 46.7 | 46.7 | 46.9 |
| Batt end [%] | 66 | 55 | 61 | 66 |
| Avg speed [km/h] | 28.6 | 29.6 | 28.2 | 29,6 |
| Energy burned [kcal] (apple watch) | 888 | 902 | 518 | 733 |
| Distance [km] | 28,2 | 28,2 | 27,99 | 27,68 |
| Ride conditions | Cruising up to 42km/h | Hard ride up to 53km/h | Cruising up to 42km/h | Cruising up to 42km/h |
| Terrain | Flat road/brick | Flat road/brick | Flat road/brick | Flat road/brick |
sorry, i meant 14.6 vs 46.9.I can do it during coming week.But i can compare only 46.7 (current one i am using) and 46.9.
Luna fw was to "week and eco" for me. Dont think they change a lot.
Thanks for the firmware. This is what I was looking for.Hi. L1 support is set low at 100w max and the ramp up is mild. When you start on the flat in L1 you no longer get the quick support and "too much power" feeling that exists in the original 46.3. L2 at 35% max feels closer to the old L1 power with a bit more torque. For technical trails uphill the ramp up and ramp down on L2 is manageable. I have tested L4/5 on long steep uphill trails and the support is now very strong and you don't need to maintain high cadence to access that support. This modified version has addressed all the issues I raised with the original 43.6 with L1 thru 5 each having a clear role while riding. This is much closer the 14.6 FW, which I can't install on my latest bike due to boot loader incompatibility, but I can ride happily with this modified FW.
use old besst software version, will work.Hey guys,
I tried to change the max speed limit from 25kmh to 32kmh in BESST, but I recieve the notification:
"Notice: Speed limit is set above 25Km/h. Please adjust the speed limit within the limits prescribed by local law."
I am using the account that was provided by the motor seler. My understanding is, that that acount is not permeted to change it above 25kmh. What can I do about it? If I use python script to logon, will it work then?
I tried older version 1.2.20, with dealer account, and it still doesn't work.use old besst software version, will work.
use phytonI tried older version 1.2.20, with dealer account, and it still doesn't work.
