vikino1
I have it and I am satisfied.
I have purchased 6 Dengfu E10's with M600's over the last 3 years for family and friends. Hard to believe but the first motor back in 2019 with firmware 14.6 is by far the best in terms of power delivery through the levels and battery range (80kms). I have newer bikes with 46.3 and 46.7 and the difference is like night and day. The newer versions have way too much assist on L1 so it is very hard to ride economically and conserve battery. The latest bike received just 3 weeks ago is version 46.3 and again too much assist at level 1 but this version has really low assist/torque even on L5 unless you maintain a really high cadence. Hills I can climb easily on L3 on my first bike (14.6) can not be climbed with the latest one. I am working with my contact at Dengfu to get to the bottom of this as it is so bad I need to
In another thread they say you can now change the power output on the newer m600 motors. Firmware version 46.2, 46.3I have purchased 6 Dengfu E10's with M600's over the last 3 years for family and friends. Hard to believe but the first motor back in 2019 with firmware 14.6 is by far the best in terms of power delivery through the levels and battery range (80kms). I have newer bikes with 46.3 and 46.7 and the difference is like night and day. The newer versions have way too much assist on L1 so it is very hard to ride economically and conserve battery. The latest bike received just 3 weeks ago is version 46.3 and again too much assist at level 1 but this version has really low assist/torque even on L5 unless you maintain a really high cadence. Hills I can climb easily on L3 on my first bike (14.6) can not be climbed with the latest one. I am working with my contact at Dengfu to get to the bottom of this as it is so bad I need to find a way to correct it or not worth riding. Just hoping that Bafang will relent and provide a simple way to reprogram these motors.
yes i have 46.2 controller and can change output power on each level assist with besst pro.In another thread they say you can now change the power output on the newer m600 motors. Firmware version 46.2, 46.3
Did your motor come with that firmware version, or did you buy a new controller?yes i have 46.2 controller and can change output power on each level assist with besst pro.
buy new controller. old controller suddenly deadDid your motor come with that firmware version, or did you buy a new controller?
Interesting! Where did you buy it?buy new controller. old controller suddenly dead
Does new controller looks different than old one?buy new controller. old controller suddenly dead
I am waiting on delivery of the BESST tool as to date I have wanted to avoid playing around with changing firmware versions. No option now as need to do something.I have the 46.7 on mine and it's true L1 is too powerful. I cut the motor under 5% slope and in fact i constat i consume more or less the same than the M500. +-50% consumed for 1200 m D+. Different riding, but not so bad. I keeping the 46.7
14.6 is available on github, have you tried to download it on the other motors ?
L5 power (5/5) on 14.6 is stronger and delivers at lower cadence. It is so strong I never ever use it as easy to lose traction on dry technical climbs. On the road for getting up steep hills at the end of a long ride it is great. 46.7 is still ok on L5 and if I could reduce the ease at which L1 ramps almost immediately to 200w it would be ok. The latest bike with 46.3 needs tuning across the power range in relation to how the watts are activated eg torque and cadence. To get support uphill you need high cadence which is impossible on steep switch backs etc where you need to control cornering. It is not just about setting different watts at each level, it is about what the sensor settings (torque/cadence) that triggers that output and how long that power runs on after you reduce input. We all have different preferences so ease of customisation would be such a winner for this motor.How you could compare L5 on 14.6 and 46.7?
looks the same.but i dont check details componentDoes new controller looks different than old one?
Hi all. My account manager at Dengfu raised my issues with FW 46.3 with Bafang and they have sent me what looks like a modified version (attached below). I am still waiting on a BESST tool so can try it out. I have tried to upload this to Github with no success, so if someone else can add this to the database that would be appreciated. If anyone tries this out on their M600 before I do, it would be great to hear how it performs. A post above suggests that FW 46.3 maybe accept changes to power levels with the BESST Pro tool so someone may also be able to test this.
46.2 can tuned with besst proHi all. My account manager at Dengfu raised my issues with FW 46.3 with Bafang and they have sent me what looks like a modified version (attached below). I am still waiting on a BESST tool so can try it out. I have tried to upload this to Github with no success, so if someone else can add this to the database that would be appreciated. If anyone tries this out on their M600 before I do, it would be great to hear how it performs. A post above suggests that FW 46.3 maybe accept changes to power levels with the BESST Pro tool so someone may also be able to test this.
Only the new M600 controllers.anyone who has the 46.2 to share
Or does it only run on the new M600?
Does it run on the old M600?
Where did you buy the new controller?buy new controller. old controller suddenly dead
u can contact Flora Yuan on facebook. Her company name Joyebikes at Alibaba.Where did you buy the new controller?
Can you take a photo of his markings?
How can I tell the new version from the old one by marking?u can contact Flora Yuan on facebook. Her company name Joyebikes at Alibaba.
talk about M600 controller. mine 46.2 from her.flora is not able to offer fc 2.0 controller
Not yet. I am still waiting for the delivery of the BESST hardware so I can have a go at updating the FW. My request was for the assistance and ramp up provided at L1 to be reduced and max assistance at L5 - as 46.3 seemed very weak at L5. I have a bike with FW 14.6 and this to me is perfect, so I suspect I will load this on my newer bikes and be happy.Did you have a chance to test the new firmware? Do you know what Bafang did modify in the file they sent you?
Thank you for reply. I hope the old firmware can be used with the new controller. I am thinking to try 14.6 myselfNot yet. I am still waiting for the delivery of the BESST hardware so I can have a go at updating the FW. My request was for the assistance and ramp up provided at L1 to be reduced and max assistance at L5 - as 46.3 seemed very weak at L5. I have a bike with FW 14.6 and this to me is perfect, so I suspect I will load this on my newer bikes and be happy.
