Reign E+ 2022
Any of you guys dealing with seat post creaks? Mines been a pain since new, I’m constantly greasing the thing?
I’ve tried the rails the seat it self the collar I’m over it?
Mine does as well, bought some proper assembly grease the other day and will let you know if it helps.
I use carbon grip paste on my seatposts on all my bikes. I don't have any creaks plus you could potentially use a bit less torque than recommended if you wanted to.
Cheers mate!
I have tried automotive grease,
I tried slick honey,
I grabbed some really thick rubber grease yesterday it’s almost like a paste,
I’m hoping this works better
My Reign does not do this.
On further investigation I found that above 60 cadence the sound increases exponentially becoming louder than a Tesla at around 100 cadence. Strange thing is it has nothing to do with power assist level, and even steepness of road. So if I keep pedaling at a cadence lower than 50, I can still climb a 10pct grade road and the sound is just marginally higher than Bosch line active 2016 model. Now I will probably not return the bike, I will just readjust and wont pedal as fast as on my old bikes.
low cadence
high cadence
I just bought the E+2 version, ... . ....
My E+2 does not sound much. I would say motor noise is more or less on the same levels as of my previous emtb, a Haibike AllMtn with the bosch gen4. But the Syndrive pro's noise has maybe a higher pitch, whereas the bosch motor had more "bass" in its noise, if that makes sense.
low cadence
high cadence
The sound occurs when the load on the motor and chain is low. So you need to pedal harder, change gears for lower cadence. A lot of dudes dont have this problem because of this. Light load doesn´t benefit silence :)
Hello, good evening, does anyone have problems charging the battery placed on the ebike...? For a couple of months if I charge the battery put in the ebike the charge takes 7 hours and when you check the charge it is at approximately 70%, you disconnect and reconnect and finish charging 4/5 hours later but without turning off the charger
On the contrary, with the battery outside, the charge is done in approximately 5 hours, everything working normally... Is something similar happening to someone...?
A pal had a similar issue, would not fully charge in the bike, but full charge when removed.
No, I don't see this behavior on my two 2022 bikes. I'm running the latest available firmware but can't tell you from the top of my head what version it is.
Have you claimed this failure qith your LBS or Giant already?
I have reported a breakdown in my shop but have also provided screenshots of reports from other people here in Spain having the same problem but here I was asking why based on what I read since the October update there are all kinds of problems with the batteries and their behavior, in fact since the charging issue failed me, the battery also behaves differently, now it takes longer to drop below 100% when I drive with it, since an update in October everything has changed. ..
.... the battery also behaves differently, now it takes longer to drop below 100% when I drive with it, since an update in October
Thats also my experience, but the total distance / altitude I'm getting from the battery remains the same. It just takes longer until the first two bars are gone.
I had this problem. The bike shop I bought it from raised a warranty issue with the charger and replaced the charger. It charged OK with the new charger but I will have to charge a few more times to make sure its OK.
Anyone else tried a steering damper like the Cane Creek Viscoset?
Latest MBR reckons they transform the steering on a Reign E+ 1 - probably the only aspect of the bike I’m still not 100% on.
Me está pasando exactamente lo mismo, y ha sido justo desde la última actualización, antes en 5 horas todo ok, ahora la dejas toda la noche, y miras y está al 70%, la vuelves a conectar, y a veces no se queda eternamente cargando, me refiero, con el display verde parpadeando, no se queda fijo, luego miro, y esta al 100%, hace cosas muy raras, imagino que deben de sacar alguna actualización para solucionarlo.
Por otra parte, y en beneficio, me da la sensación que la batería parece, que dure un poco mas.
Si tienes alguna nueva información por favor informa, que me tiene el tema un poco mosca.
un saludo.
The exact same thing is happening to me, and it has been just since the last update, before in 5 hours everything was ok, now you leave it overnight, and you look and it's at 70%, you reconnect it, and sometimes it doesn't stay charging forever , I mean, with the green display blinking, it doesn't stay fixed, then I look, and it's 100%, it does very strange things, I imagine they should release an update to fix it.
On the other hand, and for the benefit, it gives me the feeling that the battery seems to last a little longer.
If you have any new information please inform me, that the subject has a little fly for me.
a greeting.
un saludo.
a greeting.
THIS WEEK I HAVE COMMUNICATED THE PROBLEM TO MY STORE THAT THEY HAVE TALKED WITH GIANT, THEY HAVE CONTACTED ME TO TELL ME THAT GIANT IS AWARE OF THE PROBLEM AND THEY ARE WORKING ON IT TO SOLVE IT, THAT THEY WILL RELEASE AN UPDATE SOON THAT WILL SOLVE THE PROBLEM, THAT WE ARE ATTENTION TO THE SUBJECT THEY WILL REMOVE IT AS SOON AS POSSIBLE. THIS IS THE LAST INFORMATION I HAVE.
Hopefully they will reset my odometer again! #resalevalue
Thanksss, graciasss
Thanksss, graciasss
I have the same issue since the October firmware release - battery 650wh takes about 9-10 hours to charge and the smartcharger green LED blinks continuously even when the battery is at 100% - Lets hope that Giant engineers have the idea to test the next firmware release before forcing it on their clients via that shambolic "RideControl" app!
I'll give you my parameters, to see if you have the same ones, I'm still the same with the battery issue
Hi there,
Can anyone help me out with this snap ring on the drive side BB? It’s obviously bent and needs replacing as it’s eating up the seal but I can’t work out what it even is supposed to do? The notch it sits in would have it not touching anything other than the crank arm? Is anyone able to take a pic of this area for me, or a parts diagram?
Thank you,
Alex
Has anyone changed the cable of the droper post ?
The end cap on the lever went loose, as result the cable frayed and then it was impossible to pull it back to place without causing it to fray more and more.
Removed the seat post, took the cable out only to see that the cable housing is nested deep inside the seat tube, it is impossible to catch it with something and try to pull it upward. On the other side, pushing the cable housing from the head tube, it does not move.
So I can't seem to find a way to push a new cable in, from that point.
Any ideas? 🤔
Any ideas? 🤔
If you remove the battery and flip the bike over, most likely you will be able to push the cable housing up the seat tube.
    Join 43,203
