There are many mounts discussed in this thread.I just download it...
Any suggestion for a really good bike mount please ?
The Official BLEvo Thread
It should work.. sometime I notified that it was possible only after force a reflash of the firmware of the battery..can anyone tell me if my 2017 levo can go past the speed limiter of 20 mph with the BLEvo app and no other modification??
or can someone please tell me where i can get this info??
is the reflash something i can do myself or would i need to take it to my local shop?It should work.. sometime I notified that it was possible only after force a reflash of the firmware of the battery..
Only the dealer can do..is the reflash something i can do myself or would i need to take it to my local shop?
Sure you can have it... You can save with different name and then you can rename it..Hello Paolo,
Is it possible to add new users in Smart Power Expert Mode and Bike Setup? I see that only existing ones can be modified or renamed.
I have read the manual but cannot find it.
I have BLEvo 3.8.0 on Android.
BLEvo try to connect to the latest bike connected.. If on your wife's phone connect to her bike, BLEvo should always try to connect the her bike..Hi
is it possible to force BLevo application to forget a bike? Application on my wife's phone always tries to connect to my bike although my bike is not switched on. My bike is not on the list of paired devices in Bluetooth setup nor in Mission control... I have no problem on my Blevo application, it always connects to my bike...
Application is great!
Hello, Paolo.Sure you can have it... You can save with different name and then you can rename it..
Hi guys, I’m having trouble with the blevo app in that on my 2017 comp the settings don’t seem to work.
I set the wheel size to 2255 as my bike was chipped by last owner, and it always goes back to 75K on the speed section.
Plus eco is just as strong as turbo which I’m strugling to get more than 25k a ride
Has anyone come across this?
Does anyone know how to unrestrict the bike? I believe it was done on the light blue app.
I’ve seen this on YouTube but it doesn’t tell you how to undo it.
Hope someone can help?
Ok, but you can modify 5 user settings.. I hope the quantity is enough..Hello, Paolo.
I am not able to create new users. I can only modify and rename existing presets. I am experimenting with different parameters in BLEvo to achieve maximum battery saving in different scenarios.
It is not essential but I would like to create new users and so respect the existing ones.
BLEvo works with new KenevoHello!
I Have a Kenevo Expert -21, and wondering if I should buy the BLevo App.
Is it possible to change max. speed in -21 model Kenevo with the app?
levociraptor.ecwid.com
The old model of Kenevo doesn't have the TCU.. all is inside the battery.. You can keep the firmware as isI have a 2019 kenevo expert. Can inipgrade motor/battery firmware while preserving TCU firmware? TCU is 1.7 Which id like to keep for speed limiter mod. Currently 5.0.4 on motor and a.16.x on battery
Maybe in the future will be something similar in BLEvo..Is it or could it be possible to link ANGI crash sensor in Blevo?
This sentencePaolo since a few weeks I have mounted an extender on my LEVO FSR (2016/17). Everything works fine and my range is much wider. However I set the configuration BLEVO keeps indicating that my battery is 98%. If I indicate in configuration that I want to have the batteries shown separately or added together, then that works ok. I have read on the BLEVO site that the battery indicates above 100% when an extender is mounted. What am I doing wrong ? See attached pictures.
Thank you! I purchased Blevo on android. Is it possible to have this installed in my ios as well?The old model of Kenevo doesn't have the TCU.. all is inside the battery.. You can keep the firmware as is
great thanksMaybe in the future will be something similar in BLEvo..
Clear. ThanksThis sentence
"I have read on the BLEVO site that the battery indicates above 100% when an extender is mounted"
is true only for SL model where the extender is the Specialized extender, because BLEvo can read the data (percentage and wh) directly from the extender battery. For all the other kind of extender, BLEvo doesn't know these data..
do you have suggestion which maps to use in israel ?It should work.. sometime I notified that it was possible only after force a reflash of the firmware of the battery..
