Other Cascade Components 2023+ Levo SL Link
Feb 21, 2022
83
26
Los Angeles
I am coming off a gen 3 Turbo Levo with an EXT E-Storia and Cascade Components long travel kit. On the Turbo Levo this link and shock absolutely transformed this bike.
I haven't received my new SL yet and will give it at least 20 rides of tweaking before trying anything new.
In the meantime I was interested in collecting people's observations and experiences with this new link.
Lightme
243
267
Sydney
I have it paired with a Storia. Personally I really like it - the increased progression suits my riding style and the trails I ride. With the stock link and shock I was running sag in the high teens in order not to bottom out.
Very happy with my decision.
ccornacc
United States
Do you need a new shock length for this modification, or will the stock size work?
I’m currently on a gen 3 levo with the LT Link, and if I try out the SL, the extra 10mm of travel seems intriguing.
Thanks!
Tonester
Atlanta, GA USA
This just came in today. I'll be installing it and pairing it with my bike's stock Fox Float X. The seal kit for my shock won't be in for another week so I'll be waiting to try anything different with volume spacers. I do intend upping the sag a bit until then. Will report back.
83
26
Los Angeles
This just came in today. I'll be installing it and pairing it with my bike's stock Fox DX2. The seal kit for my shock won't be in for another week so I'll be waiting to try anything different with volume spacers. I do intend upping the sag a bit until then. Will report back.
Curious, how did it turn out? Did you mean DHX2? Was expecting it not be supported by Fox given their documentation and therefore only options would be steel shaft 23+ super deluxe coil, EXT Storia, Ohlins TTX. The DHX does have a slightly thicker steel shaft and is more yoke compatible than the DHX2 but still not as robust as the alternatives. Interestingly the new SJ15 alloy has a DHX spec'd so the new yoke design must not scare Fox as much as before, however the kinematics between the SJ and Levo SL are different
Tonester
Atlanta, GA USA
Corrected. Its just a Fox Float X. It turned out well. I can't say I feel a huge difference yet, but I haven't been able to get much riding in due to rain, hurricanes, etc :)
ripeinmay
7
Ireland
Jumping in here for some info. Do you need a different sized shock for the cascade link vs stock to get 160mm? I.e. what's the eye to eye value and stroke value?
Tonester
Atlanta, GA USA
I did not need any additional hardware to install the link. I only had to switch my shock geometry chip to the "High" position.
ah1
125
68
Santa Cruz CA
For those that did install the Cascade link - what's the verdict? How does it feel on the Levo SL if you use the same shock you've used without the Cascade?
Lightme
243
267
Sydney
It’s great. Increases progression, giving more confidence on rougher, faster trails. I changed to an EXT Storia which I also bought from Cascade.
Greeno
29
12
San Diego, Cal
Purchased my Levo last summer and rode it a few times before the upgrade and it seemed fine.
I installed the Long Travel Link as well as replacing my original shock with a Fox float x 230x65 and love the way it rides.
It seems to have made a positive noticeable difference in being able to push harder in corners and the occasional jumps.
Sold the original 210x55 shock for 3 bills so that haelped.
P00KIENRAYRAY
26
8
California
I recently upgraded to a 170mm Fox 38. Front end feels like a completely different bike now. Now that I’m riding harder and faster, the rear feels squirrelly and I’ve been drifting more than I’m used to. Does the link help with this?
Greeno
29
12
San Diego, Cal
My bike came with the stock Fox 36 Rythem and I sold that too and put a Fox 38 factory (170mm) on the front.
My figuring was that raising the front up, and also running a 29’r and keeping the headset in the center position was good since I was going with the longer travel shock and flipping the rear chainstay chip to the higher position kinda leveled it all out.
Plus it raised the bottom bracket up and using 160mm cranks I rarely get pedal strikes.
Really happy with the performance.
572K
