Levo Gen 2 2019 HT FULL UPGRADE, photos and problems
Ritid69
12
Norway
20,497
Is this a quiz ??
First problem .. the saddle.. I'm proposing we place it on top of the gold colour pole to the left. With the white part upwards and the skinny part facing to the right - or towards the steery sticks if we're being technical.
How come it looks like all the geometry is all screwed up as if the forks are on backwards, but the forks aren't on backwards ???
Ritid69
12
Norway
First to go was this Jones bar, the previous had the bright idea of fitting these bad boys ??‍♂️. Now fitted with race face cash gold bars.
Ritid69
12
Norway
Is this a quiz ??
changed out the fork to a 130mm travel rock shox pyke .
View attachment 43448 First to go was this Jones bar, the previous had the bright idea of fitting these bad boys ??‍♂️. Now fitted with race face cash gold bars.
Is this a quiz ??
Ritid69
12
Norway
Xt brakes front and rear with 180mm discs, having problems with the rear caliper spacing as it seems like the top of the disc is rubbing on the pin in the caliper, not mich space between caliper body and the disc even with the correct spacer bracket fitted, will try and add a 1-2 mm washer in between to slightly raise the caliper. Or buy a xt disc if theses Techno ones are not compatible because of the wave.??? Any one had similar issues
