A very quick summary:
- DT Swiss, super plush on single track and small bumps. As it uses a coil for the initial stroke its able to soak up the everything on the low speed compression. The most comfortable fork I've ever tested. Good mid stroke support. Starts to lose composure on bigger, longer, continuous hits. Only time I noticed this was at Bike Part Wales, doing full 10 minute runs from the top on black tracks. I also liked the set and forget characteristics of the fork.
- FOX 36 Factory, early days, but I'm liking the extra travel at 160. Although much firmer, not as comfortable, will be more suited to a bit more of a bashing.. 'enduro' if you want to call it that. Loads of adjustment and each click makes a difference. Probably will take me longer to get it dialled.
If you ride more trail style than anything else = DT Swiss
If you push it on most rides, bigger drops, bike park = Fox Factory (or Lyrik)
