I’ll have to do that once I’m back home. I’m traveling right nowTake the serial number off the back of the CSU and punch it into the Fox website and see what that says.
Bike Help Center | FOX
www.ridefox.com
Actually I found I had taken a pic of it. Apparently it’s a 2021/2022! Odd that it looks more like the older forksTake the serial number off the back of the CSU and punch it into the Fox website and see what that says.
www.ridefox.com
Thanks for the info. I think my build date was 2022 if I recall correctly, but I could check again. My Specialized box said 2022/2023FOX released the updated 36 in 2022 if i remember correctly
Your Levo is a 2022 model but the build date will have been in 2021 (check the sticker under the top tube) so they would of used a 2021 fork
Spesh would of ordered loads of forks for the 2022 bikes in early 2021, maybe even late 2020
If the FOX website says its a 2021/22 fork then it must of been made right before they changed to the updated version, ethier that or they were only making the top of the range 36 factory and elite versions with the updated csu and bleeders and the Rhythm version came later
Don’t know if 38 rhythms are different but these have the bleed valvesI don't think any Rhythms have the bleed valves or the lube channel things. Happy to be shown I'm wrong...
