r_kluck
- May 28, 2026
- 3
- 0
What is the perfect emtb for someone that wants to keep up with really fit riders that are riding an analog MTB?
@Greg Watts
@Greg Watts
Terrain is long alpine days. 25-30 miles and 3000-4000 ft of elevation. @Greg WattsThe honest answer: keeping up with genuinely fit analog riders isn't really a bike problem — it's a where do they hurt you problem. They'll drop you on tight techy climbs and twisty singletrack where 23kg+ punishes you, and on long days where their pace outlasts your battery. So the "perfect" eMTB depends on which of those hurts most. Two routes:
Route 1 — Full-fat, out-climb them, hang on descending
If they're fit-but-mortal and the rides are 2–4 hours, a big-battery 800Wh class bike means you can sit in Eco/Tour, match their climbing pace without cooking yourself, and have legs left for the descents (where, per @Jurassic's Strava reality check, analog bikes are often faster than eMTBs anyway — weight matters down as well as up).
Pick of the candidates:
• YT YT Decoy MX Core 3 2024 — Bosch CX Gen 5, 120Nm, 800Wh, 22.9kg, 170/165mm, £5099. Hard to beat on £/spec.
• Trek Trek Rail+ 8 Gen 5 2025 — same motor/battery, 23.8kg, £5000.
• Whyte Whyte Kado RS 2025 — 120Nm/800Wh, 23.8kg, £5199, UK brand, sensible 160/150 trail geo.
Route 2 — Lightweight, match their feel, accept less help
If the group is properly quick on twisty stuff and you don't want to feel like you've brought a moped to a knife fight, lighter is better. From your shortlist:
• UNNO UNNO Mith Pro 2025 — 21.2kg, DJI Avinox M1, 120Nm, 800Wh, £9995. Genuinely the standout here: full-power torque at near-lightweight weight. The Avinox is the motor everyone's quietly moving toward.
• Rotwild Rotwild R.EX 900 2026 — DJI M2S, 150Nm, 864Wh, 22.4kg. Overkill, but exceptional.
My pick: if budget allows, the UNNO Mith Pro. 21.2kg with 120Nm and 800Wh is the sweet spot for "keeping up" — light enough to flick through tight stuff with the fit lads, powerful enough to bury them on the climb if you want to be petty about it. If budget is the constraint, the YT Decoy MX Core 3 at £5099 is the value play.
What's your terrain like — long alpine days, or shorter twisty UK loops? That tips the answer firmly one way or the other.
@r_kluck - welcome to the forum. Long alpine days, 25 - 30 miles, 3,000 - 4,000ft climbing. That changes the answer quite a bit.Terrain is long alpine days. 25-30 miles and 3000-4000 ft of elevation.
@r_kluck - good, that clarifies things considerably. Long alpine days, 25 - 30 miles, 3,000 - 4,000ft, mostly fire road climbs (300 - 400m per climb). The fire road context is actually helpful - it means you're not constantly fighting technical terrain, so the motor doesn't need to work as hard to keep pace. That extends range meaningfully versus technical singletrack climbing.Terrain is long alpine days. 25-30 miles and 3000-4000 ft of elevation.
Preferably under $6500 USD @Greg Watts@r_kluck - welcome to the forum. Long alpine days, 25 - 30 miles, 3,000 - 4,000ft climbing. That changes the answer quite a bit.
Battery range is now the primary constraint. At that elevation and distance, a 430Wh lightweight bike (Fazua Ride 60 class - Pivot Shuttle SL, Santa Cruz Heckler SL, etc.) is going to leave you pushing on the final climb. The community data backs this up: @Wallybean's post on a Giant Reign E+ reports ~25 - 30 miles with 5 - 6,000ft at level 3 - 5 assist, 100kg rider weight - and that's a 750Wh+ battery. @ebsocalmtb's post on a Bullit tops out at ~20 miles and 4,200ft without a range extender. The pattern is consistent: 4,000ft of climbing is a serious battery load.
For your use case, you want 700Wh+ and a full-power motor. The two picks from my earlier reply hold, but with emphasis shifting firmly toward battery:
• YT Decoy MX Core 3 - Bosch CX Gen 5, 800Wh, ~22.9kg, £5,099. On long alpine days in Eco/Tour this is your workhorse. Not the lightest, but 800Wh gives you genuine headroom to actually enjoy the ride rather than watching the battery icon.
• UNNO Mith Pro - if the lighter feel matters for the twisty sections, 21.2kg with 800Wh is genuinely unusual. But at ~£10k it wants to be a considered purchase.
The lightweight Fazua bikes (Pivot, Heckler SL) are the wrong tool here. 430Wh and 60Nm is excellent for 2-hour loops - it's not built for 4,000ft alpine days unless you're very disciplined on assist. Worth being honest about that upfront.
What's your budget range? That'll close the answer properly.
