Bike Finder · Rotwild
Rotwild R.EX 900
Rotwild
R.EX 900 2026
CurrentEnduro eMTBCurrent · 7.7/10iFreshness 7.7/10
All Mountain
Motor
Avinox M1 · 150Nm · 1300W
Battery
Rotwild 864Wh
Travel F/R
160/150mm
Wheels
29F/27.5R
Frame
Full carbon
Weight
22 kg
Price
From £7,800
View the Rotwild R.EX 900 on Rotwild’s site
Rotwild R.EX 900 2026
From £7,800
EMTB Forums verdict
The Rotwild R.EX 900 2026 is a German-built carbon enduro eMTB and Rotwild's range-first Avinox flagship. Headline numbers: 170mm fork, 160mm rear (frame notes describe 160 front / 150 rear, indicative of conservative travel positioning), DJI Avinox M1 at 105Nm and a 1000W peak with a 2.52kg motor mass, a removable 864Wh battery, 22.4kg claimed, 64.0 degree head angle and reach 462 to 512mm across M, L and XL. Trim ladder: base at GBP 11,999 and ULTRA at EUR 12,490 (22.1kg). With no curated community quotes on file yet, this verdict draws on the gold spec and the well-established DJI Avinox platform behaviour. Rotwild has a long heritage in premium German eMTB engineering with a small but devoted following.
Drive system and range. The DJI Avinox M1 is the most powerful production motor in its tier in 2025: 105Nm of torque, 1000W peak and a 2.52kg motor mass. Avinox can sustain peak torque longer than rival full-power motors thanks to large gearbox surface area and aggressive thermal mapping. Rotwild has fitted a notably large 864Wh battery: bigger than the standard Avinox FP800: making the R.EX 900 a deliberate range-first build. The battery is removable. Real-world range with 864Wh on a 160/170mm rig is genuinely capable of 2,000m+ of vertical in a single charge for typical riders, well into all-day backcountry territory. Avinox's app ecosystem, anti-theft alarm, 4G/GPS and over-the-air firmware updates come built in.
Geometry and handling. 64.0 degrees up front is bang on the modern enduro norm. Reach steps cleanly: 462 (M), 487 (L), 512 (XL). Chainstays are a uniform 439mm and wheelbase tops out at 1303mm on XL. The polydynamic carbon frame uses mid-high pivot kinematics with a mullet wheel concept (29 front, 27.5 rear), modular dropouts and an Acros RW EXC angle-adjustable headset: all genuine engineering depth from Rotwild. Three sizes is on the conservative side; riders under 1.70m or over 1.95m should fit-check.
Build and value. Two trims. Base (GBP 11,999, 22.4kg) gets a FOX 36 Float Performance fork (160mm, GRIP damper), FOX Float X Performance shock (185x55mm), MAGURA MT5 HC-W four-piston brakes and Shimano XT M8100 1x12 mechanical. ULTRA (EUR 12,490, 22.1kg) is the higher-tier build. Standout: 864Wh removable battery on a 22.4kg carbon enduro rig is class-leading for range-per-weight. Questionable: GBP 11,999 base pricing puts it firmly in YT Decoy Carbon Pro and Specialized Kenevo Pro territory, where carbon AXS Transmission and Maven brakes are standard.
Caveats and known gripes.
  • Premium pricing. GBP 11,999 base is a serious ask: rivals with similar Avinox M1 power and 800Wh batteries from Amflow, Crussis or Olympia start meaningfully cheaper.
  • Three sizes only. M (462mm reach), L (487mm) and XL (512mm) only: no S, riders under 1.70m should look elsewhere.
  • Mechanical drivetrain at the base trim. Shimano XT M8100 mechanical on a sub-23kg Avinox carbon enduro flagship is conservative; AXS Transmission is standard on most competitors at this price.
  • No curated community signal yet. The R.EX 900 has no owner reporting on the eMTB Forums community at the point of writing; long-term motor and frame reliability data is yet to mature.
  • Limited UK dealer network. Rotwild is well-distributed in Germany and Austria but thinner elsewhere; warranty routing requires planning.
  • Mullet only. Wheel configuration is fixed at 29 front, 27.5 rear; full 29in or full 27.5in are not options out of the box.
Verdict. The R.EX 900 is the range king of the Avinox carbon enduro segment in 2026, with proper 170/160mm travel, an 864Wh removable battery, 22.4kg system weight and Rotwild's polydynamic carbon engineering. It suits riders who prioritise range and German-engineering pedigree, who fit M, L or XL, and who can support Rotwild's central European service network. Buyers chasing AXS Transmission and Maven brakes at the base trim, smaller sizes or a more cost-effective entry into Avinox M1 power should look at Crussis E-Full 12, Amflow PL Carbon or Commencal Meta Power. Production status: current.
Frame
Polydynamic carbon frame handcrafted from high-modulus carbon fibres with mid-high pivot kinematics, mullet wheel concept (29 in front / 27.5 in rear), modular dropouts and Acros RW EXC angle-adjustable headset, 160 mm front / 150 mm rear travel
Bike geometry diagram
MLXL
Toptube596 mm621 mm648 mm
Reach462 mm487 mm512 mm
Stack638 mm642 mm651 mm
Seattube445 mm475 mm511 mm
Chainstay439 mm439 mm439 mm
Headtube Angle64°64°64°
Seattube Angle (eff)78°78°78°
BB Drop28 mm28 mm28 mm
Wheelbase1246 mm1273 mm1303 mm
Headtube110 mm115 mm120 mm
Standover735 mm733 mm732 mm
Front Centre807 mm834 mm864 mm
Trims · 4
Core
£7,800
Pro
£8,670
Ultra
£10,840
ULTRA
MotorAvinox M1 · 150 Nm · all trims
BatteryRotwild 864Wh · 864 Wh · all trims
Travel F/R160/150 mm · all trims
FrameCarbon · all trims
ForkFox 36 Float Performance 160mm GRIP 2-PosRockShox Lyrik Select+ 160mm CHARGER 3.1Fox 36 Float Factory Kashima 160mm GRIP X HSC/LSCFOX 36 Float Factory Kashima, 160 mm
ShockFox Float X Performance 185x55 2-PosRockShox Super Deluxe Select+ 185x55 3PFox Float X Factory Kashima 185x55 2-PosFOX Float X Factory Kashima, 185 x 55 mm
HeadsetACROS RW EXC 1.5 - MOD · all trims
Steme*thirteen Plus 35, 50 mmROTWILD S120, 35 mmROTWILD S120, 35 mmROTWILD S120, 35 mm
Handlebare*thirteen Plus, 20 mm rise / 780 mm widthROTWILD B280, 15 mm rise / 780 mm widthROTWILD B220 Carbon, 15 mm rise / 780 mm widthROTWILD B220 Carbon, 15 mm rise / 780 mm width
GripsERGON GD10 · all trims
SaddleERGON SM SportERGON SM SportERGON SM ProERGON SM Pro
Seatpost8PINS NGS2.0 integrated dropper, 192-228 mm8PINS NGS2.0 integrated dropper, 192 mm (M) / 210 mm (L) / 228 mm (XL)8PINS NGS2.0 integrated dropper, 192-228 mm8PINS NGS2.0 integrated dropper, 192-228 mm
BrakesMagura MT5 (203/203mm)SRAM Maven Bronze (200mm)SRAM Maven Silver (200mm)SRAM Maven Silver, 200 mm rotors
Rear derailleurSHIMANO XT M8100 SGS Hyperglide+SRAM GX Eagle Transmission AXSSRAM X0 Eagle Transmission AXSSRAM X0 Eagle Transmission AXS
Cranke*thirteen Plus, 165 mm (M/L) / 170 mm (XL)e*thirteen Plus, 165 mm (M/L) / 170 mm (XL)e*thirteen Race Carbon, 165 mm (M/L) / 170 mm (XL)e*thirteen Race Carbon, 165 mm (M/L) / 170 mm (XL)
ShiftersSHIMANO XT M8100 I-Spec EVSRAM AXS Pod ControllerSRAM AXS Pod ControllerSRAM AXS Pod Controller
CassetteSHIMANO CS-6100, 10-51T, 12-speedSRAM GX Eagle XS-1270, 10-52T, 12-speedSRAM GX Eagle XS-1275, 10-52T, 12-speedSRAM GX Eagle XS-1275, 10-52T, 12-speed
ChainSHIMANO HG 7100, 12-speedSRAM GX Eagle Transmission, 12-speedSRAM X0 Eagle Transmission, 12-speedSRAM X0 Eagle Transmission, 12-speed
DrivetrainShimano XT 8100 12spSRAM GX Eagle AXS 12spSRAM X0 Eagle AXS 12spSRAM X0 Eagle Transmission AXS; e*thirteen Race Carbon, 165 mm (M/L) / 170 mm (XL); SRAM AXS Pod Controller; SRAM GX Eagle XS-1275, 10-52T, 12-speed; SRAM X0 Eagle Transmission, 12-speed
WheelsCrankbrothers Synthesis EnduroCrankbrothers Synthesis EnduroCrankbrothers Synthesis Enduro CarbonCRANKBROTHERS Synthesis Enduro Carbon, mullet (29 in front / 27.5 in rear)
TyresSchwalbe Albert Evo Trail 29x2.5 / 27.5x2.5Schwalbe Albert Evo Trail 29x2.5 / 27.5x2.5Schwalbe Albert Evo Trail 29x2.5 / 27.5x2.5SCHWALBE Albert Evo 29x2.5 front / 27.5x2.5 rear
Weight22.8 kg22.6 kg22 kg22.1 kg
Price£7,800£8,670£10,840
Spot a mistake?
