curufinwe_wins
Hmm thanks. I guess I'm going to have to play with it.In a very similar CEF55 frame I am runnig 38T front sprocket.
Due to excessive play in lower/rear motor mounting bolt, had to put 0,7mm thick distance at non drive side - so motor moved about 0,7mm to the right. Also I have chamfered sprocket a bit on inside so now have about 2mm of the clearance to the back arm.
Regards
I'm a bit sad, because this bike will be a small for my wife (27.5), and I kinda either need to be able to get a 38 (ideally 42, but at least 38) or I have to shell out extra money for the shimano 9-45 cassette.
I have that same cassette on my bike, so it isn't a bad component, but... its expensive, and I would really prefer using something a bit more durable for her since she tends to grind and mash a lot more.
(She uses a 42/11 right now and that just barely works for her on our flats. She was not happy with the speeds she was reaching with the 38/11 previously. 38/10 would give the same ratio as 42/11, 36/9 is higher, but still).
