Update
The current Chain stay length is 440 with a tolerance of +- 1mm see below. We are flying in the 450 rear triangles to arrive in UK on May 10th they will be free issued to anyone who has ordered an XL bike or frame and to anyone else through our website. Please allow 10 days for customs and UK internal delivery.
Chain ring bash guards are available now at £15.00 plus PnP from [email protected]
Below is a CnC'd version of the linkage, Rob has one and there is just one more available in the UK. Currently we are not stocking them. They are exactly the same in all dimensions as the black Version.
Current frames are certified to cat 4. We are awaiting the final 5 categorisation testing in Germany, this could take time. Current frames must be considered Cat 4 until we officially announce the Cat 5 certification.
Any formal Veduro update on 700WH slim battery support with the Rogue? Can it be adapted to the M2S-equipped frames enroute, like with the Crestline? Or is a new frame version in order?
I was able to test my Intend Hover Monocoque 205x65mm in a size Large frame. Full bottom-out was about 4–5 mm clearance to the rubber charger port cover. But it was just a quick test in a different bike shop. I'll test it again in my Large frame.
There is no way. I just got my Avinox light cable. I just checked the pinout. If I’m right, it’s the exact opposite of the SRAM one. Is that correct? See photos. Or is the red output the recessed part? Then it would be correct.
That’s the light cable. The red circles are the ones that are connected to the wires.
That’s the SRAM spec sheet.
They are not for sale to the public at this point as they are all going into the new bikes, absolute pain in the arse for all the people who were advised to buy the Higo….
and forbidden is giving them to their customers with eagle 70/90 deraileurs...
have you tested them with a voltage tester?
Yeah, the ones in my picture with the red circle have continuity with the wires in the cable.
ffs, i think i just order some axs batteries too. i have two of these light cables on order and two of the micro a axs cables already here
I think it could be correct, but I’m not sure about the SRAM drawing. What is the recessed part and which one isn’t?
have you also ordred this one?
Oh nice, this one has all 4 wires. You’re good. Mine has only 2 wires. It’s the Supernova adapter cable for their lights.
Could this be used/adapted to run other lights? I’ve got a big power magic shine 8000 and it would be nice not to have to strap its battery to the frame!
Yes, but I’m not sure what the watt limit for the output is. But most likely you’re good. Its 12v
no, i spoke with the distributor. a bit over a week ago the ship was around namibia. so takes 2-3 weeks to rotterdam. then it needs to get unloaded and shipped to switzerland. they booked both a lorry and a spot on a train, but it is not clear when exactly they get it. sucks big times, i‘ll leave on the 26th to finale and probably need to rebuild my kenevo sl for this trip. and ride the shitty 23 x2 it came with.
my proper shock no longer fits, it just arrived from the tuner:
i have now a one of a kind fenix 2.0 with the last available side by side res
I’m guessing you have no update on your frame delivery? Im on the same Batch.
I have to bring my Hover Shock to Intend before I can fit it to the new frame. But then I can’t ride it on my current e-bike after the changes, which sucks if I do it too early. But if the frame arrives sooner than expected, I’m stuck with no shock.
I tried to mount the Hover opt and it’s not working in the frame M. The pigi back slamed to the charging port.
On what size frame you’ll mount it?
I orderd a size large. Yeah its worse with the Opt.
If you’re 100% sure you would order the Hover Monocoque, I could maybe test it on a size medium for you, with 205×65mm or 205x60mm.
I tested it with my Moto V2 (aka Rover). But the Body is the same as the Hover Monocoque
talked again today, they expecting them thurday/friday next week. not much longer :eek:
You haven't read the manual have you 😉. That hole is for a 600 battery.
Did you get yours from ace with the e-storia bundle?
I have - I now recall that! I’m sure my battery in loose, it it will be out soon for cable/hose routing so will sort then.
No jtech for the shock.
If you have the possibility that would be great. thx :D
isn’t the 800wh mounted with a screw from the top under the display or do i mix it up with the crestline?
Yep. Thats the one. Silly design really. The trek tq set up is way better. There is a bit of a technique to it and once you get that you're away. Do the bottom bolt up first then the top, helps locate it. Near impossible doing it the other way. Trust me 😆
