robikinkela
I've recently had the opportunity to thoroughly test the firmware update and have noticed a few flaws:
1) The motor makes noise when you engage the walk mode, but the same noise is heard every time you stop pedaling and start again, that is, when the electric motor kicks in after a pause.
2) Every time you stop pedaling and start again (and this happens even when you shift gears without exerting yourself), the motor exerts an unnecessary forward thrust, and it does so quite abruptly, to the point of being unpleasant.
3) In the dynamic microtune 0/100 mode, the display does not show the motor power output and the assist ratio.
4) I've noticed that when climbing a hill at a high cadence, the motor reduces support towards the top end, and this happens when you pedal aggressively at a high cadence. Sometimes it even seems like the motor reaches a sort of power wall, only to immediately recover, irreparably jeopardizing its continuity of action.
I sincerely hope that Specialized will fix these flaws as soon as possible, but I also wonder how they could have released an update so hastily: didn't they test it before putting it on the market?
