ffs, please, learn the difference in power output and what efficiency really means. thanks. i even annotated these two diagrams for your, and marked the difference in output for your, i even translated the bad german words in easy english:
the first diagram shows you the power output of the bosch, in the different modes (x axis shows rider input, y axis how much power the motor puts out, at the wheel, at the same rpm:
now the power curve of the avinox motor, after the software update where they also increased the power. you can clearly see, that for the same rider input, you get out a lot more power in the higher assistance modes, than on the bosch. BUT THAT DOESN'T MEAN IT'S LESS EFFICIENT. efficiency is IN the motor, how much loss there is in the different gears. that is probably there, but that's not much. how much? this we will know at the latest in february, when all parts of
ebike-mtb's motor test are released, as they announced they have tested that with the help of DEKRA Stuttgart.
see that BIG FAT RED circle? that's the higher output. when you turn down assistance to lvl 7, than you have a similar power curve than Bosch's EMTB+ mode, everything above that, the motor uses more battery but gives you more power = less rider work. and that's most probably the area most testers are usually riding in, hence why they use more battery. they didn't test how much less input they needed to put in to get that amount of power.
hope that finally helps you understand the difference,
@Suns_PSD. but please, for the love of everything, stop calling it less efficient, because it isn't.
thx.
rant over
