Are you talking the 100nm update?@Suns_PSD is a gen 5 with the update less efficient than a stock gen5?
I'm not retarded dude.@Suns_PSD is a gen 5 with the update less efficient than a stock gen5?
you‘re so close. find some where they normalize for input power.normalized for speed
Your wrong about dji. It's not 10-20 less efficient than bosch.I'll keep it to this thread 'cause there have been a lot of hurt feelings when I bring it up in other threads, but it's obvious that the Bosch is somewhere between 10-20% more efficient than the current Avinox.
Although perfect range tests don't exist, literally dozens of reviews and personal antidotal posts have shown this to be the case with only a handful indicating that they are approximately equal.
I don't care if the Avinox provides more assistance, people have tried adjusting it down, and they ride together or the same routes as they rode on the Bosch, and 95% of the reports are that the Avinox uses its battery up more quickly than the Bosch.
Furthermore, Avinox motors have had running changes for noise, so some might make noise, some might be more efficient, so one single individual result really is just a data point.
Look at how many reviews of the Bosch say they prefer the 600w battery and it's plenty, where-as every review of a 600w Avinox says 'it needs/ they'd prefer the 800w'.
Anyways, the Bosch is the better motor in terms of efficiency, noise, reliability, serviceability and power delivery from a stop (where-as the Avinox seems better once already rolling at higher speeds). The Bosch is also technically lighter when you consider the efficiency part of the equation and that you need more battery with the Avinox.
I LOVE the Rogue bike but consider the M1 motor a liability. However, some things have been shared with me regarding the updated M2. If Avinox acknowledges that noise and efficiency have been improved, I intend to buy the Rogue with an M2. If all the M2 does is increase power, I'll go with a Regulator or the LTe to get the Bosch.
It just SUCKS that no one offers a frame only, Bosch CX-R 600w only proper bike.
PS. As far as why I don't just buy a Norco VLT Range to get the Bosch as it's very similar to the Rogue, primarily it's the CX motor instead of the CX-R, it's an entire bike instead of a frame, the 800w battery which would literally last me 2 days, the fat downtube & the bit weird geo that is in-between sizes.
The test i did was with a mate who is 3kg lighter than me max. offset that by my bike is 1kg lighter, total difference 2kg.You have one DJI Plummet. Like I said, there are different iterations of it.
There are testers that have went through many. For instance, PB had 2 different DJI's in their test and had the same conclusion. Never mind that Avinox acknowledged the rattle and drag to Francis...
Also, you are more fat than your kid. LOL
I'll admit you have the most trusted argument for ranges being equal.The test i did was with a mate who is 3kg lighter than me max. offset that by my bike is 1kg lighter, total difference 2kg.
The motor isnt less efficient. it just has more power and as standard an algorithm that uses more power. Dial it back and you get similar range for similar weight riders.
PS In my group of riders theres 2 x amflows, 3 x teewings and 2 x rogues. What's consistent is once the power settings are backed off the dji's are getting similar range and if the riders are smashing high powered settings they burn battery fast....
I've only done a parking lot test on the Rogue. But have done some solid tech climbing and descending miles next to a mate riding one. What i can say is that both bikes are freaken similar in capability if we disregard motor differences. I would not be displeased with either bike far as capability is concerned.I'll admit you have the most trusted argument for ranges being equal.
Man, what a selection of bikes in your region! I guess just being so close to Asia does that.
Have you shredded the Rogue yet? If choosing today, would you choose your current Crestie, the new Crestie, or the Rogue?
Thx.
Interesting. I have not read that test yet, but will check it out.btw, just reading the emtb-mag test of the Maxon S, that's how efficiency looks like:
and that we will have soon for both of the big ones too...
dunno, there are videos in the test i haven't watched yet, maybe they explain the test environment there, or that's in one the follow ups in 26:Interesting. I have not read that test yet, but will check it out.
Do we know how they are measuring efficiency? There is a difference between Electrical Input>Rear Wheel output (taking into account drivetrain, chainline, tyre etc.... ) and Motor Electrical>Motor Mechanical output.
| E-Bike Motor Test: 4 In-Depth Analyses | Date |
| 1. Climbing Power, Range & Efficiency – Which motor gets the most out of every watt-hour? | 23 January 2026 |
| 2. The Myth of Motor Noise – What really matters? | 30 January 2026 |
| 3. Juice Bar: The Battery Size Myth & the Fast-Charging Trend – how much energy is actually in your battery, and how quickly are you back in the adventure? | 6 February 2026 |
| 4. What does 1,000 W of peak power really deliver? What are the downsides, and how does the 750-W regulation come into play? | 13 February 2026 |
reading the article helps... (btw, that just shows me that you really just jump too fast to conclusions, my inital impression of you stands)Yet the Mahle has 80% efficiency and that's not listed as a Pro?
no, the mahle showed motor errors when they increased rider input > 200w in the test rig. you just compared two different rider input value efficiencies and jumped to conclusions too early, as always. i see now where your issues lie, you only skim through stuff, probably also here, and read only what you want to read ignoring what could shatter your predefined opinions.
because the Mahle failed the test at 250w input.What's not clear to me, is why would they list a Pro of the Maxon as high efficiency, yet it's only 76%, nearly the same as the Pinion.
because the Mahle failed the test at 250w input.Yet the Mahle has 80% efficiency and that's not listed as a Pro?
NO. EFFICIENCY IS NOT A STATIC NUMBERYour above point has nothing to do with the Mahle's efficiency, as underscored by the Mahle's actual efficiency being the second highest in the test.
now please use your "critical thinking skill" and explain, why YOU think the efficiency at 200W input should be compared to the efficiency of 250w input, when you only have one dataset for the Mahle motor, but not the same dataset for the other motors (and vice versa).Efficiency (η)
Efficiency is a relationship between the input power and output power, given as a percentage (%). This line is more or less parabolic with the vertex more towards the lower torque values (see pink line in example above). It typically peaks early on in the torque range then slowly decreases as the motor gets closer to its stall torque.
Using the motor near it’s peak efficiency ensures optimal motor life and power consumption. It is best practice to use a motor at or near its peak efficiency. The further away a motor gets from max efficiency, its performance becomes less reliable.
it's called swiss german and only exists as a spoken language, their written language is german (my mother tongue, i'm german).I don't speak Swiss
