If he has never weighed them how would you know what they weigh?
I know what my S4 Expert weighs. <54 lbs soaking wet.
Guys need help.
My Levo 4 comp carbon keeps cutting assistance for 1 sec or even just shuts off completly.
I also gets randomly on the screen "No battery detected check app & connector"
What the hell is this? The bikes has 1500km & has been amazing...is this the "nest thing" that needs to be upgraded?
Also all this s***t happened after I bought the fast (smart) charger for a 4 days trip where we needed to do 120km each day. I am afraid that fast charger screwed up my system/battery
Any thoughts please?
Guys need help.
Does your bike have the new spring loaded battery seat installed?
Guys need help.
Your battery connection is loose
no I checked & still have the nest with the black screw (not silver) & no springs
Have you tried a hard reboot? Firmware updated?
Recently I took a bad fall and my Levo stopped communicating with the app and accessories. Works fine after rebooting it.
how do you do a hard reboot? I did the 40secs hold of the top (power) button but it did not change anything. The shop did reinstall the firmware/software which was up to date but they did it anyway...nothing changed. If anything it is worst now.
I think I will have to go back to the dealer. 😢
40 miles on it
10 HARD
I love this thing. It’s my lift replacement device
170mm F/R
CC long travel link EXT-E Storia , and yes the Podium. Predictable in the air. Effortless in rough.
Waiting on my graphics…..
How are you liking the 170 front and rear vs the standard 160/150? Noticeable difference? Any disadvantages?
Yeah that’s it. Sorry brotha.
I mean there’s probably more weight. But it’s almost indescribable. I’m really glad I did it. Floats, but with control. The HBO is so awesome a wheessh instead of clunk.
Curious if you chose to adjust the head angle or flip chip; or did you keep those at the stock setting?
Stock for now. Geometry will be played with later, don’t want another set factors to deal while I dial my suspension.
I like the fat tire look, must be magic carpet ride? It also makes downtime look smaller
Thanks they're 2.6" Kryptotal, with enduro casing and soft (not super soft) compound. I'm a lifelong northeast rider that's brand new to the Arizona desert so these were a local's recommendation. While they are super resistant to rim strikes/pinch flats; honestly everything feels super slippery unless you really commit; plus i'n not crazy about how they much they deflect off rocks. For this reason i just picked up a pair of 2.5" Assagai MaxGrip DH tires to help me find a baseline. Might go to the DoubleDown casing if the DH feels too heavy duty. We'll see!
Guys need help.
I had the same.
You can adjust the battery nest with the screws located under the downtube/ motor protector, but I just got the sprung loaded battery nest which fixed it.
Guys need help.
I had the same problem and when I mentioned it to my LBS they mounted the new battery nest version with springs and now it's all good.
Specialized is aware of this problem since they have made a new version just months after releasing Levo 4 but will most lightly get rid of the old ones before new bikes is on the market with the new version.
Ask for a new and you'll get it.
Random question - But anyone's screen never able to keep time? Every time I turn on my bike the time is never correct. This happens even if I don't take out the battery or completely drain the battery.
I have the same issue but no idea why this is happening. As soon as you open the app it switches to the correct time.
