I don’t know but I know you should not buy itguys - can't find solid info on this - stock m560 runs on 14s battery without issues ?
i have , mine is silky smoothy quiet , i just want to plug in 14s batteryI don’t know but I know you should not buy it![]()
Not sure what happens on stock, there is a firmware for 52V 22A.guys - can't find solid info on this - stock m560 runs on 14s battery without issues ?
m560 is quiet you say?i have , mine is silky smoothy quiet , i just want to plug in 14s battery
can you post the link ?Not sure what happens on stock, there is a firmware for 52V 22A.
Would be greatwhen weather will be better i could
Here you gocan you post the link ?
hey , you mean that 14s battery is working on 48v firmware or i misunderstood ? any problems ? motor behaves normally ? display also handles more voltage well ?Yes, it work's fine on 48V firmware. 70x LG M58 1502Wh battery is used.
thank u sir ! where these are sourced ? from bafang ? are they safe to use ?
I have no idea. Maybe @Dado knows?thank u sir ! where these are sourced ? from bafang ? are they safe to use ?
I did they told me this...i understand , mine is quiet , ask your supplier , i purchased via alibaba from fieldebikes
the 510 controller so they're taking us for a ridelook what my friend found inside m560 delivered with frame from alibaba . spot the detail...
2022 controller from M510 ??! I will dismantle mine soon so I wonder what I will find there, if it's the old motor then it would explain the insane noise.look what my friend found inside m560 delivered with frame from alibaba . spot the detail...
Yup, they’re all like this, been well known. Most of the differences between the 510 and 560 are just in software and the physical gears.look what my friend found inside m560 delivered with frame from alibaba . spot the detail...
Does that mean someone could update a M510 to M560 by replacing the nylon gear and flashing new firmware?Yup, they’re all like this, been well known. Most of the differences between the 510 and 560 are just in software and the physical gears.
Don't know. It's likely the motor itself is different as well, especially considering the difference in noise.Does that mean someone could update a M510 to M560 by replacing the nylon gear and flashing new firmware?
Hi gsoros ,Opened up my M560 today, ODO at 1500 km. The factory grease was plenty but quite dirty and thin, approx. the consistency of ketchup.
This one looks good but it's not possible to order it anywhere in Europe. Well, I found it on amazon.de but you have yo buy 4 packs for more than 100 eur... :-/ An from US amazon they don't ship to EU.i use this
where in eu ? i purchased easy in poland . this is typical GEAR grease , for bearings i think something thinner , teflon based oil perhapsThis one looks good but it's not possible to order it anywhere in Europe. Well, I found it on amazon.de but you have yo buy 4 packs for more than 100 eur... :-/ An from US amazon they don't ship to EU.
Do you use it also for bearings ?
I found only this one but it's something else not sure if it would work
John Deere Grease Gard Premium Plus 400g
Slovakia, do you have a link maybe ? I can buy from PL using forwarding service if not ship directly. Just googled it an really no results in EU shops. Don't know why.where in eu ? i purchased easy in poland . this is typical GEAR grease , for bearings i think something thinner , teflon based oil perhaps
