deertrackdoctor
One up V2 240 fits with approx 20mm gap so not quite slammed downHi, I see it in the photos, but I wanted to make sure... Does Oneup V3 240 fit all in size Large?
Run then for two years on a trek rail without any issues so I see no reason why they won't work outm9n the cubeThank you. They are the same ones I found. Fingers crossed!
Fucking hell that's proper catastrophic!Newman carbon wheel decided to give up on its 3rd ride out.
View attachment 167535 View attachment 167537
It's came with SRAM XO wireless which I immediately removed and replaced with Shimano linkglide XTDid you keep the slx or move it on?
It takes the piss that we have to buy an extra bit. Why isn't it in the box with the display? Many people will be upgrading their System Controller on the top tube for the Kiox 400c.![]()
For anyone wanting. Not due till October tho.
There is no 440c it’s the 300/500/400It takes the piss that we have to buy an extra bit. Why isn't it in the box with the display? Many people will be upgrading their System Controller on the top tube for the Kiox 440c.
TypoThere is no 440c it’s the 300/500/400
Sorry mate I was meaning the whole bikeIt's came with SRAM XO wireless which I immediately removed and replaced with Shimano linkglide XT
Because every bike manufacture has their own solution/design for integrating it into the top tube. It's not on Bosch to produce whatever extras required to mount it.It takes the piss that we have to buy an extra bit. Why isn't it in the box with the display? Many people will be upgrading their System Controller on the top tube for the Kiox 400c.
Good point. I was caught up in the ONE77ness of it all.Because every bike manufacture has their own solution/design for integrating it into the top tube. It's not on Bosch to produce whatever extras required to mount it.
Ah yes sold it to a riding buddy who's a vets happy manSorry mate I was meaning the whole bike
#rideshimanoIt's came with SRAM XO wireless which I immediately removed and replaced with Shimano linkglide XT
I found the front shock setting to be important. I was having pedal strikes and found the bike to be almost unrideable on uphill technical single track with the rear shock setting closer to 30 than less than 20 mm sag. I now keep it <= 20mmThis helped me alot from pedalstrikes, went deep into suspension tuning and found that I had to much sag and now bike is alot higher when riding, this have bit not made any negative impacts on my riding ability or comfort.
No but you can work it out. Essentially wrap the chain around the largest gear and the chain ring. Connect them together and in your case add 6/7 extra links. That should allow you to do what you need to. Start with the above at 7 and then remove one additional link if need be.Anyone know the chain length I need for a xl xt group set ?
I got my display the other day. Just waiting on mtb monster to send me the bracket in next 2 weeks. Does look smart with the screen but it should have been like the Santa Cruz where no bracket is needed.If anyone is curious. This is what the Kiox 400c looks like in situ without the adaptor plate. My theelectricbikeshop will have the adaptor plate in stock in a week or two, so will fit and update here.
Apparently I am one of the first to get the display (from their shop in Cardiff) and very hard to get hold of at the mo.
View attachment 167772 View attachment 167773 View attachment 167774
100%. They knew about it, like Santa Cruz, but didn't make the hole the correct size ready to retrofit the display. Disappointing. We'll possibly be the first two to get them on!I got my display the other day. Just waiting on mtb monster to send me the bracket in next 2 weeks. Does look smart with the screen but it should have been like the Santa Cruz where no bracket is needed.
Fitted. 150mm (With Acid for comparison)£40 no bolts https://amzn.eu/d/3AptHff
Great choice the SLX is a great bike.Hi! I’ve been following this post for a while and finally decided to buy my One77 SLX 2025. Once I receive it and make the first mods, I’ll share them here.
I have a question about the Kiox 400c display: is it plug & play? Any experiences? On the Ridewill website they told me that the kit can ONLY be activated through Bosch dealer diagnostics.
For me it's about being able to see the info I want without having to stop and get my phone out of bag. Getting a quick reference on the move.Just out of curiosity, what's all the fuzz about the Kiox display? Maybe I'm doing something wrong but I prefer simpler UI with less disturbing elements.
If I didn't already have my purion I would be fitting the kiox so I'm happy to stick with the purion. I also use a garmin for maps which suits me fine. The purion on the bars is at the right position too.Just out of curiosity, what's all the fuzz about the Kiox display? Maybe I'm doing something wrong but I prefer simpler UI with less disturbing elements.
I just want battery percentage.Just out of curiosity, what's all the fuzz about the Kiox display? Maybe I'm doing something wrong but I prefer simpler UI with less disturbing elements.
I'm not sure I'll even use the navigation.For navigation, you're "stuck" with Flow app or can you mirror the screen from your mobile to Kiox?
I'm using garmin edge 1040 for navigation, notifications etc. from the phone. And smart watch..
It's absolutely piss poor of you ride anywhere remotely remote !I'm not sure I'll even use the navigation.
It uses the Flow app, but you can import a gpx file from some other app.For navigation, you're "stuck" with Flow app or can you mirror the screen from your mobile to Kiox?
