So I knew this DJI experimental setting was turned on(Extreme Attitude Protection) but I didn’t think it would almost kill me!
I went up a very steep lava rock face, as I was half way up, body positioned over the bars, confident I was going to make it, the motor locked up and the screen said the motor had locked up due to a 45deg incline angle!! This almost sent myself and the bike falling over and sliding down the solid lava slab. Luckily my saddle wasn’t fully extended and I was able to rapidly release from my pedals and step off, this is all happening on a supposedly 45deg angle! This could have been very ugly, all due to an experimental setting I left on. My ride report showed a max 31% angle, either way it was f*cking steep and slick and really sucked having the motor lock up mid ship with no warning. If you’re into steep climbing please turn this setting
off.
On a positive note, this same ride I had the Freehub Pre-Engagement setting and Quick Start setting turned
off for the first time, and wow the motor rattle was reduced quite a bit! Much quieter. I could also feel the Sidekick hub engagement float. Where before the DJI Freehub Pre-Engagement setting was definitely doing its job and absorbing all that hub pawl float in the SideKick. I also wasn’t getting the VPP kickback I was before…..now that the SideKick is doing what it’s intended to do.
Now that I’ve got my RS181’s skirt lifted and felt her out a bit, I’m very impressed. I’ve now got the DJI settings more dialed, the correct dropper length, suspension fine tuned, motor rattle reduced…..she rips! It feels lighter and more balanced than any other full power emtb I’ve ridden. I don’t know why but it is very easy to fling around compared to my previous emtbs (Crestline, S-Works) and my RS181 has the longest wheelbase over my previous emtbs. Maybe it’s because Ive been eating my Wheaties?
