Great weather for it isnt it! Another OcUK enjoyer I seeAt the half way house today (pub).
Thank you for your reply.I replaced mine as the black wasn't my bag. Got them from invisi-frame.
Thank you for the reassurance; It’s difficult to stop second guessing yourself. My decision was further reinforced by getting home and jumping back onto my Sommet 290 in a Large and it definitely felt roomier than the One77 did in Large. Totally happy I’ve got an XL coming, even if I have got to wait a couple more weeks now (bonus is that invisiframe is now available and so will be fitted before I collect)At 178cm the L fits me just fine although its smaller than the S4 Status but a smidge which is noticeable. If I was 2-3cm taller I would want the larger bike thats for sure so the XL should fit you at 184cm just fine. It was hard work getting the bike, everywhere was selling out the following day so I had to be properly "on it" so to speak. For the money and the spec you get, is there actually anything with a Gen5 thats better value? I think likely not.
I didn't have the invisiframe option when I got mine so I have gone ghetto with some car wrap that helps with avoiding stone chips. Its doing its job just fine thankfully.Thank you for the reassurance; It’s difficult to stop second guessing yourself. My decision was further reinforced by getting home and jumping back onto my Sommet 290 in a Large and it definitely felt roomier than the One77 did in Large. Totally happy I’ve got an XL coming, even if I have got to wait a couple more weeks now (bonus is that invisiframe is now available and so will be fitted before I collect)![]()
It’s a motor out job and the rear is a pain in the arse with standard lines for clearances so the braided at 0.2mm thicker or what ever they are may be a tight squeeze.Has anyone mounted hope brakes with braided hose on their bike? Is the hose diameter thicker compared to regular hose? Any issues with rear cable routing?
Hi, just a quick question: motor fixing bolts: what's the required torque? And is it T35? I've just ordered Hope V4s and while waiting for the parts delivery, I can prepare tools etcSwapped the forks for my existing Grip2 damper, new Hope Tech 4 V4 brakes with TRP 2.3mm rotors 220/200 front/rear, shimano XT 11S Linkglide, PNW bars, stem and 170mm dropper and added low speed adjuster to the rear shock. Finally PINND 140mm cranks and pink Deity pedals that the bike shop gave me for free.View attachment 159793View attachment 159794View attachment 159795View attachment 159796View attachment 159797View attachment 159798View attachment 159799View attachment 159800View attachment 159801
11nm apparently but I am not 100% on that.Hi, just a quick question: motor fixing bolts: what's the required torque? And is it T35? I've just ordered Hope V4s and while waiting for the parts delivery, I can prepare tools etc![]()
Publicación en el hilo 'Nuevo Bosch CX generación 5 - Problema con el sello/casquillo' New Bosch CX generation 5 - seal/bush problem11 nm, aparentemente, pero no estoy 100 % seguro de eso.
Hi there,Does anyone have a part number for the one77 motor guard? Yep mine has gone awol on a trail last night and I've only just noticed it gone (duh!)
Nice one
My pleasure. Let us know how you get on, if it’s cheapish it might be worth holding a spare.Nice one![]()
Gutted. Original Xt brakes? Or had you changed them?
Ordered and should be here weds. This is why it came off (I visited the crime scene to try and find it). Bike is too lowMy pleasure. Let us know how you get on, if it’s cheapish it might be worth holding a spare.
I wasnt impressed with the routing of the original brake lines either to be fair, Ive had to add a twist to my line to give it a positive spring back towards the rear arm to avoid the line meeting wither the wheel or the edge of the rotor.
Mines creaking as well so I shall be removing bolts and adding assembly grease. It creaks like its dry which is very poor for a new bike.After some rides my bike creaks like an old wagon ....Shop says they have to disassemble shock linkage and grease it.
Where did you order from?Ordered and should be here weds. This is why it came off (I visited the crime scene to try and find it). Bike is too lowView attachment 160731
£20 delivered - new port cover coming soon too. Feck knows where that went.She is low!
How much was the guard? Did you buy a new charge port cover too…..![]()
e-bike shop - you need to ring them as they are ordered from Cube directWhere did you order from?
Only problem I see with the cable after removing it is this
