The Official BLEvo Thread
Status
Not open for further replies.
Hello ,
Been trying to upload a ride to Strava and i'm getting this error . tried with 4g and Wifi connection.
Also , tried to upload the TCX / GPX file manually but Strava was showing only part of the ride , while the file itself containes the complete ride details .
Please your advice .
Thank you View attachment 11666
Send to me the tcx file.. I will check.. thanks..
Thanks Paolo didn’t knew that!
Congrats on your app, looks great and a lot of great feedback here in the forum!
Another burning question, can BLEvo void specialized warranty?
I've received a reply from Specialized overnight. Please see below for their response. At the moment we are aware of only one way to see if the bike has been hacked. By looking at the wheel circumference in the diagnostics report that can be generated in the Mission Control. If the wheel circumference is lower then 2000 (around the 800) it usually means it's hacked. Unfortunately this information can be restored to factory defaults in Mission Control as well - so it's not a 100% accurate method.
Hi Paolo,
Can you capture the maximum Amp output of the motor and also allow it as an option to be displayed while riding the bike?
Hi Paolo,
The Amp value is in the csv for now, if you want to check it..
Why you would like to have this value while riding?
There appears to be an issue on some bikes only pushing out 14 to 17 Amps where they should be pushing out over 20 Amps.
So more of a fault finding exercise. If it is in the csv then maybe that is all I need for now.
Hi Paulo
I've just downloaded Blevo. On mission control it says battery health 100% whereas on Blevo it says 95% Which is more likely to be correct?
Hi Paulo
Because with Mission Control always the Health is set to 100%.. I think there is a bug in Mission Control..
I was getting max 571w
Got 5.04 update and now getting 788w
Great news mate, can you do me a favour?
Can you look at column U and find your 788 reading for me?
If you then scroll back across to the left to column J is will give you the Current reading. I guess this reading will be 20, 21, 22 or even 23
I’ll do one better
10.23 battery firmware, 5.0 motor firmware
571 max watts - 14.2 amps
10.23 / 5.04
788w max - 20.2A
Both with battery voltage at 38v
@PaoloBLEvo I had my first ride with the TurboLevo and with Blevo yesterday. As I first did read all 50some pages of this thread, I had high expectations, but there are no words to describe the app...??.
I have changed a few times the settings whilst always pausing the ride and continuing. And I see that Blevo did not track my movement..
I cannot find what I have done wrong...below the difference between Blevo and my Mio. Screenshot_20190318-144043_Strava.jpgScreenshot_20190318-144108_Strava.jpg
I’ll do one better
10.23 / 5.04
788w max - 20.2A
Hi, is this consitent a cross the board for all the 2019 Levo's? get more power output with 5,04 motor firmware?
I cannot find what I have done wrong...below the difference between Blevo and my Mio.View attachment 12005View attachment 12006
Ios or Android?
Where you put the phone? Bag, pocket or handlebar?
I’ll do one better
10.23 / 5.04
788w max - 20.2A
@outerlimits is talking about a 2108 Levo with a 1.3 engine not a 2019 Levo with a 2.1 engine.
Ok.. have you removed the battery optimization for BLEvo in Android battery configuration?
I might have found it: based on previous posts, I went into the Blevo settings under apps and made sure the optimisation is off.
But when you say now battery optimization, I believe it is somewhere else....see below.
I have now selected that BLEvo can use as much energy as it needs.
Will test this.
Screenshot_20190318-225250_Device maintenance.jpgScreenshot_20190318-225306_Device maintenance.jpg
Status
    Join 43,219
