Bafang Go+, is it a new App for all motors ?
Tomblarom
111
172
Yes using DPC245CF80301.2-DP C245.C 3.0.bin worked for me!
sandnap
79
82
Herriman, UT USA
LInk please and Thank you
The Aurora store is included in the OS I use on my phone (CalyxOS) but you should be able to download it directly from their website. auroraoss.com
Again, I didn't install it this way but it should work. Once you have it installed you can find the application by searching for "bafang". When you view the Go+ app you can click on the three dots in the upper right hand corner and choose "Manual download". Enter the version 83 and it should install it. You will need to uninstall the current version first though.
  • Like
Reactions: PLM
PLM
21
8
Graceland
Thanks!
PLM
21
8
Graceland
Hey everyone!
Kathy (from Frey bike) discussed with Bafang, Bafang guys need to research the problem.
So as Frey bike has motor warranty, Bafang sent a new motor with express delivery, which should arrive in 10-12 days.
We will see if it works, I'll let you know. Fortunate I'm a mechanical engineer..
Any update with new motor?
Freda
102
98
Vaasa
Hey, I also had this "Operation Failed" issue, but on Android 13! Bafang sent me a new firmware file for DPC245 3.0. I will test it on Friday, but maybe it helps you already. Version: DPC245CF80301.2
EDIT:
I flashed with BESST, tested on Android 13 as before and it solved my "Operation Failed"-issue, when opening "Set the personalized ride".
Do you know if there is any other improvements on this? I don’t have any other problems except GO+ doesn’t let me change motor settings, I thought maybe this could help.
Tomblarom
111
172
What is your motor type / model ?
I have all. M510, M560, M600 (46.2).
Hi, can this device replace the 245 v3 display to use GO+ and a classic 181 controller? I can't understand what else it's for... Thank you
I think the Bafang IOT device is for setups, where you want GPS, 4G-connectivity and if your display has no Bafang GO+ support. If your DPC181 is the CAN-version (triangular plug), I'm sure, it can be used with Bafang IOT. Maybe consider buying the DPC010 instead of adding IOT-device..
raggertje
16
13
The Netherlands
My DPC245 V3 no longer wants to connect to the GO and GO+.
Previously it worked properly. When I install my DPC241 I can connect to GO, so there is nothing wrong with the iPhone apps. I suspect there is something with the Bluetooth connection. The strange thing is that the display can be seen in a BMS app, but not the Bluetooth overview of my iPhone.
Anyone have an idea what it can be?
Dado
588
411
Bratislava
That is normal, you can not see under BT devices. It depends what BT protocol is display using. There is lot of protocols on BT.
Verdo07
21
8
Italia
I don't have the bike yet but I was thinking of building it with an integrated handlebar and since I couldn't mount a DPC 245 display I was thinking of a simple DPE 181... but how can I use GO+ in this situation? or should I forcefully buy a best tool?
Tomblarom
111
172
@Verdo07 I never heard of an "DPE 181" and I clearly explained it before: only IOT, DPC245 and DPC010 support GO+! If you want to combine it with an "non-GO+" display, you gonna need the IOT device. But it's untested and I cant tell how well it works. Having the BESST dongle is helpful anyways when messing with different firmware and hardware. Consider buying.
Verdo07
21
8
Italia
thanks for the answer...I guess it's necessary besst tool but I find it more complicated than using GO+ to play with the parameters... especially if you need it during a trail... this is what I meant:
Tomblarom
111
172
Oh, I oversaw that. I have seen it before. It seems, Bafang GO is supported, but nothing about GO+ (for setting assist levels).
525K
