Strive:ON problems
It looks like the conical part is there to close the gap and stop any gunk and mud getting into the threads. I’d say the collar on the bolt does all the work of applying pressure to hold the crank
Yes I agree and decided not to ride today and ordered a replacement bolt instead 👊🏽
Got my Strive:On CFR two days ago (ordered it at 23rd of December 2023), but couldn't unbox it until today. I ordered a reduced bike in the outlet, unridden but with minor paint damage. Was super surprised that everything was like new, no scratches, nothing. Only in the area of the upper screw in the down tube some paint chipped off (see picture). Doesn't look nice but for about 1000 CHF less I can live with that pretty good.
Ok, but my real reason for this post is: how does Canyon deal with the latch problem (I was super excited)?
Again, I have to say that I am pleasantly surprised: They include the newly revised version of the Latch from Bosch with the bike (see pictures with part number). The old version of the latch was mounted, so you have to change it yourself. No instructions, not a word about it, but as a mechanic you don't have an issue with it. Have already changed it and keep the old as backup in case the new one fails.
Photos: left: new latch, middle: new latch part no., right: old latch installed
As an engineer, however, I still don't quite trust this solution. That's why I looked around at Cascade Components for the metal version (see photos on p. 14 of this forum). I’ve got the confirmation that it should be available soon! I will order and install it as soon as possible, and then I hope that there will be peace with this tiresome topic...
My latch is also broken. I called Canyon and received the new, reinforced version within three days. Good service.
Have any of you also combined the new version with Tobias' solution?
Yes, a few of us have. I've not ridden mine since installing this setup yet though.
I have the new latch with Tobias’s fix and have had no issues at all. The bike is pretty much flawless for me now. Shorter cranks are next and that’ll be it done
Yeah, shorter cranks are on my list, top.
Which one do you prefere?
No 155mm versions are available in Germany right now besides Hope (expansive)
I have looked at the Hope cranks as 155mm is my preferred length to try. Was hoping there’d be a 155mm option from E*Thirteen.
Anyone else know of compatible 155mm cranks other than Hope?
Hey all, I've been back and forth with whether to post this but... my Strive:On is great and I've gotten some good rides on it in the slop now. With Tobias's battery fix no cut outs from day.1 so nice that works. However I do find that at 25km/h it cuts off pretty hard and feels like an elastic band pulling me back, but if I can pedal hard through it and I mean pedal REALLY hard if I can just get it up to like >=28-30km/h then it's almost easier at that speed to pedal it than it is between 25-27km/h.
Is it just me????
It's really like they want to discourage you at 25-27km/h to go harder unless on a big hill down. Even then it doesn't seem to pick up speed as fast as a regular MTB and I would expect it to pick up speed faster as it's 25kg so potential speed due to weight should be more.
Appreciate your thoughts. The local Canyon repair place looked at it and said no resistance and it's all fine but in my mind I still feel something there...
is this your first E-bike? than i suspect nothing is wrong.
it does feel like that in the beginning. you get used to it.
don't forget that you have a heavy bike with dragy tires, with "enduro" geometry
I agree with @Jona .
Mine feels like the invisible man has slammed the brakes on when it reaches the limit but it's a big heavy bike with heavy wheels and sticky downhill tyres.
I don't fully appreciate how much the motor is actually doing until it cuts out 😳
To be honest, if you use the bike as intended, you won't notice it much.
look for the steepest climbs and decent, you won't notice and have a lot of fun :cool:
OK folks, thing is I can ride my bio bike over 25km/h on this stretch of trail which is mostly flat, slightly downhill and has a few jumps but can't pedal it over 25km/h easily enough to really him them at speed, bit frustrating. It's just weird that 25-28km/h is so hard to push through and it almost frees up over 28km/h and becomes a bit easier again. Meh still an awesome bike :)
Well that's VERY interesting!!! With the latest Flow update I was able to make one setting AUTO and I feel a lot less drag above 25km/h in AUTO than I do in eMTB. I'm sure there's something in it... either way AUTO works a treat
Where in the Flow app did you find this?
It's in custom riding modes.
Have you got the latest version of the app, 1.18.6 and updated your bike?
Just updated the app. I was on a late 1.17 version. Looking forward to checking it out ready for a ride in the Peaks on Tuesday
How did the ride go?
Did you try out any of the new modes?
I haven't had chance yet.
Yeah read above. I found AUTO to be very interesting. Need to try it again but weather is just shit and trails are closed
Me neither. The weather has been so wet in recent weeks that my planned route in the Peaks would have been nothing but a slop fest. Fingers crossed for a dry, windy week to dry out the ground
It is indeed a temporary solution from canyon. It is similar to what many people have done, including myself. My temporary solution worked well. It takes away the weight of the battery from the small clips which brake. I swapped the latch . Feels solid. Canyon said the final solution will take longer, which makes sense the need to order molds and test thoroughly,...
I'm still really happy with my bike. It rides amazing. I would advise it, regardless of this issue.
update regarding the latch issues : I recieved and installed the new bosch latch. went on few ride. no problem.
So it is clear that the issue is mainly caused by Bosch. i guess Canyon strive:on has the most issues with it, although the scott also had simular issues.
anyway, i'm happy how Canyon Belgium handled it. the acknowledged the problem, they send a temp solution first and now the final solution.
and i'm still really happy with the strive:on, great bike.
after a long wait, i started my own development last year. after many prototypes, i have a perfect and working solution, even with contact pressure adjustment.
That looks great and there are even metal parts underneath, wow!
Do you sell that? How long did you test your solution under real working (riding) conditions?
Knick Knack I'm going insane!
OK, I'm pretty sure it's coming from the crank area (hopefully not the motor) but when I'm pedalling I'm getting some knick knack sounds, not mega loud and I don't think it's rock being thrown up on the downtube as they're usually louder (but very annoying! never had it like this with other bikes maybe bigger fat downtube to blame). So question is... do I remove the cranks and clean and re-grease? it's not the seat post I don't think but will move it up and clean it and use carbon paste... but what else should I do? I'm very experienced with pulling apart my bikes and servicing them and understand typically where these noises can come from on a regular bike but unsure with this as new to eMTB. Any advice beyond the regular cranks, seat post, seat, stem bolts, pedals etc... appreciated.
BTW anything special to consider with an eMTB re clean/re-grease cranks apart from the fact it has no bottom bracket that I can service?
    Join 43,250
