DancingWithMyself
I think the rebound, compression, and check tunes are probably all I need. Really nice to have this in case I decide to pull the trigger. Huge thanks.
Yes, I run one on my 9.5. I will agree they are unreliable with the =<2021 model years. But, you can buy a 2021 and have a suspension shop replace the entire damper body with the improved 2023 version for 45$ when open for a rebuild, which solves a lot of issues.
They need service every year or they will die, but if you keep them clean, they are so nice. It is also compatible with the 205x65 overstroke, because the reservoir doesn’t hit the frame, giving a really nice 152mm travel.
Thx for the followup. The tunes likely shouldn't be the same, but I'd be shocked (no pun intended) if they weren't. But maybe someone has some insider knowledge?... does one assume the tunes are the same across all sizes? ... that's on a 9.8 XT size M!
Would have been my first choice also, such a great shock. Bummed.Sadly mara pro doesn't fit, otherwise that would have been my first choice even if it doesn't feature a hbo.
mine didnt have HBO.How can you tell if a RockShox SD Select+ has the HBO?
(do all Select+ fitted to EXe's have the HBO?)
what stroke length did you opt for 60 or 62.5?Too late! I've got a Super Deluxe Coil Select (with hydraulic bottom-out) on the way. If I find I need a flashier model I should be able to resell the Select unit at minimal loss. Let's see how it goes....
62.5mm - see post #125 for clearance. Running a 340-380lb adjustable Sprindex coil, which is very nice, but not perfect.what stroke length did you opt for 60 or 62.5?
Apparently so... Fuel EXe - Official Trek Fuel EXe Megathread!Do we know if the new RS Vivid will fit the EXe?
Did you mess with the flip chip(s) when you did this? If so how?Yes I put a 160 air shaft in.
Has anyone confirmed the need for a second kit to complete the upgrade?I read the below on another forum. What do you guys think? For those of you who have done this mod, are you sure you’re getting some adjustability?
So I was lucky enough to run into some folks who run a local Suspension-rebuilding business in Quebec. Well known, highly respected. The Topic of my planned Float X upgrades came up, and how hilariously simple it was to seemingly upgrade a Float X Performance to the Performance Elite...
They were telling me that despite what I might have thought, there is a second part required to turn the Performance Float X into the Performance Elite.
Not only do you need the Dial (FX-808-17-470-KIT, Eyelet Sub Assy: LSC,2022 FLOAT X & DHX), but you also need something called the Base Valve (FX-808-17-475-KIT Base Valve, 2022 FLOAT X & DHX). I was obviously surprised by this because I can see there's plenty of folks who have simply installed the $35 dial and claim to have added the LSC functionality.
So can anyone comment on validity of this? I'm curious if there is actually some truth to the Base Valve, which is $88, needing to be changed as well. They told me they could do it for the cost of the parts during a standard Rebuild of the shock, so I'm definitely considering that...
Thanks!
These RS deluxe/superdeluxe shocks have the option of a progressive or linear air can, if the shock came from an exe it will have the progressive air can fitted by default, you could swap it to the linear air can, but I wouldnt recommend it, it makes it far too linear - I have tried both air cans.I have a RS Ultimate Select+. I'm only using about 80% of travel, I have opened the shock and there are no volume spacers within it. I bought it from eBay, it was listed as coming off an EXe, so I can only assume it is the correct tune.
I have it at about 28% sag.
Suggestions on what I can do to get more travel out of it? (other than send it harder ! )
How did you crack your rim? Do you have the carbon or alum variety?Just for the sake of documenting my experience
I finished out the season with a dead remote, cracked rim and a blown rear shock. The shock saga was interesting- basically I could feel the damping in the Ohlins TTx1 fading, so I bought a $150 used Marzocchi Bomber CR which i planned to use as a back-up while the Ohlins was getting rebuilt. A quick test fit showed the bomber reservoir did not clear the frame, so I sent it off to Avalanche to have the reservoir shortened & converted it to their SSD tuned for the EXe. Meanwhile the Ohlins became unridable, so I sent that off too, along with the cracked wheel. All in, my EXe was out of commission for 13 weeks, during which I was back on my Chromag. An unplanned challenge to go back to a hardtail with no motor and shitty G2 brakes!
I got both shocks and the new rear wheel back over the holidays. The bomber is great so far, very supple on small stuff, but it doesn't go deep into travel easily as the Ohlins. At 190lbs I am running a 500# SLS spring. I ran about 200psi in the Ohlins with their largest volume spacer. Both are now 65mm stroke.
I would really recommend keeping a spare shock around. The 50hr service intervals recommended by most suspension companies goes by fast on eBikes, and lead times for rebuilds aren't quick (13 weeks for the avalanche and 6 weeks for the Ohlins, which was 9 months old).
View attachment 132107 View attachment 132108
It was a Nobl TR37 carbon rear rim, which came off my previous bike so had two seasons of use. My TQ remote had failed, when I took the bike into my local trek shop they found the crack. Looked like just a scratch so I wasn't fussed about it. Contacted Nobl and they advised I replace it immediately, no cost, no questions. Unfortunately, we had a bit of a mix-up and they sent a 29" rather than 27.5", so I ended up keeping both. TQ remote was also replaced no fuss, just took a few days.How did you crack your rim? Do you have the carbon or alum variety?
FYI for anyone not aware, you can set your display button to control ride modes via the TQ app. This can be done trailside in a pinch, or if you want less clutter in the cockpit area.My TQ remote had failed
That’s a great tip. Of course what happened was the up/walk button failed, so I did a restart which stuck me in 0 mode with no way to change modes. It was all DH to the end, but your tip would have gotten me another day of riding.You pair to your phone, go to s down to 1,
^ What does this have to do with suspension modifications?^ What does this have to do with suspension modifications?![]()
Yes M3x8 works fine.Hi, I'm planning to remove two of the 2,5mm spacers from my Fox Float X (Fuel Exe 9.7, Large). Can anybody tell me which shorter screws I need then? M3x8, or even shorter? Thanks
