Reign E+ 2022
Quick post now that my build is pretty much complete!
180mm Zeb, Kryptotals 2.6 front and back, DT swiss ex1700, 45mm stem, 38mm rise Title bars, 180mm oneup dropper, GX 11s drivetrain with an X01 cassette, 150mm miranda cranks. Just waiting (not so patiently) for my 800Wh battery for this to be close to my dream bike.
Can highly recommend the milkit Hassle'off toolkit, has everything you need and fits neatly underneath the bottle mount. Just received my YT fidlock bottle, it's a 600ml bottle that fits in the same space as the 450ml from fidlock, but be warned the bottle doesn't come with the magnet kit on the bottle (some cheek if you ask me).
View attachment 120107View attachment 120109
lovely build
Hi everyone.
I have a 2022 Reign e+1 which I bought in April of 2023. I'm having numerous issues with the electronics ranging from overheating in power levels 3,4 and 5, random power downs mid ride, the bike mysteriously will not turn on from time to time and my odometer on the app isn't anywhere near accurate.
All of my overheating problems have happened during mild temperatures.
My bike shop has been supportive but they have found no solutions to the problems. I've been told that Giant is working on a solution but it seems to be dragging on forever.
These seem to be known issues so has anyone found a solution? I love this bike and how it rides but I paid a lot of money for something that hasn't worked properly out of the gate. Wondering if I should demand a new one??
if i were you, i would demand either a new, perfectly functioning bike or a refund of the purchase price, if necessary with legal support. Been trough this with the 2020 Reign e+ before, but still like the charasteristics of these bikes and hence and hence on my fith Giant E-MTB 🤭
Hi everyone.
I would demand a refund or replacement. That's just ridiculous.
had an interesting thing happen. had done about 6 miles of typical riding nothing crazy, had just climbed back to the top of a hill. no problems until then, all of a sudden i heard a faint grinding noise as I pedaled. stopped and checked it out for while going back and forth and pedaling. definitely heard the noise. i also noticed that the power indicator had one orange led on top and 3 white on bottom. didn't even know it does that. that did go away as i played with the power level including turning it on and off.
i turned the motor off and rolled down about 900ft. pretty soon after that i turned the motor back on and it seemed to be back to normal. but i'm little spooked, and can't really find any info on it.
Overheating security, normal since last updates.
Usually happens while climbing in high level modes. Motor steps down to lower levels.
Well, my E+2 just started having the charging problem… Running the diagnostics comes all green ok, yet I have to plug-unplug a few times to get to 100% charge. Running flawless for over 2,000 km… Anyone found a fix to this? Thanks.
thanks. makes sense, it was hovering around 90 yesterday and i was on turbo climbing.
Well, I already have another problem in my REING 2022. Yesterday when I got home after traveling 36 km, the odometer showed me exactly the kilometers traveled yesterday.... 36 km.
The main odometer has reset to zero and mysteriously now my ebike officially has 36 kilometers, last week it was about 4100.
I have not updated to the latest update and the selected support parameters have not changed.
It has just been reset to 0 without touching anything at all.
Don't even take out the battery in time.
anyone else with this problem?
Does anyone know if there is a way to roll back to an earlier version of the software? I will be selling my reign as soon as I get it out of storage in a couple of weeks due to an injury that will keep me off the bike for the rest of the year. There was a point in time where the software side of this bike was spot on. I would say around July last year. Subsequent updates only seem to have brought issues. Would love to get it back to that cut. Unfortunately I have no record of the number.
After double checking with Giant, LBS claims there is no way for them to roll back to another SW Version. Via App it is also not possibl.
For charging on the bike, I have noticed if I can turn on the bike while charging it charges super slow, 20% in 2+ hours.
I unplugged charger from bike and wall waited 30 secs and then plugged back in, could not turn on bike while charging and charged 30% more in under an hour.
See if that works for you guys.
It doesn't work for my two bikes. Sometimes they do not charge at all even when the green light is flashing on the charger.
I have the same problem with my 22 reign 2 , the battery stop charging at 56% the last two times . I take the battery out of the bike and charging straight to the charger and is going at 100% without any problem.
I have found that with the charging issue I have to plug my bike in and let it charge for a few hours. Then unplug it entirely from the bike and the wall. Wait thirty seconds and then plug everything back in and charge for a few hours. I have to repeat this until it’s fully charged. I’m going to eh plugging my charger into a Christmas light timer and see if that works for the charging issue.
Everyone who is experiencing the slow charging or any other issue should raise this with the shop where they've bought the bike. Only if there are enough upset people and frustrated dealers, Giant will act on this.
All these charging issues got worse from the last software update right? Do you guys purposefully update the bike, or is just you regularly use the app which auto-updates your software?
Suffered my first overheating issue last weekend, was relatively pleasantly surprised that the bike only went down the level 3 at the end of an impossible climb in direct sunlight during a 30 degree day, bike stopped the overheating protection once I got onto a paved road (still uphill). Very glad I had read a comment here last week explaining what the warning light code meant, so I didn't worry too much when it happened.
Hey guys, as already pointed out by @trailaddict, please do report the charging or overheating issues to your Giant LBS or to Giant directly, a contact email is a few posts back in the thread.
Talking about it here of course helps raise awareness, but no more than that, doubt that Giant has someone reading forums, and even if they do they won't react to it.
The more reports Giant gets trough official channels the more pressure will be on them to send out an update that hopefully should fix the issues. I talked to my Giant LBS they told me that there is a lot of reports after the last update dated 20230906, they advised not to do any new updates until September when an update should arrive that should override everything updated so far.
Regarding the questions why to update the bike, some updates bring additional functionality, some of us(me also) were expecting that the last update would fix the power readings on third-party(I.e. Garmin) devices, but unfortunately it fuc...d up the charging etc...
If you don't want to update your bike, but want to use the phone app, there is a solution, before connecting the app and bike just turn off Data/WiFi on the phone and decline the app prompt for internet connection. That's how you don't need to update and can use the app.
Also clearing the fact I read I while back about updating, the app does not automatically by it self update your bike, you need to confirm if your self.
It is also not necessary the update is for the whole system, it can be for separate parts(motor, battery, controller, smart gateway module-the brains, app,...), unfortunately Giant only(as seen by me) provides a changelog/update notes when there is an app update, but not when there are parts updates.
The lack of update notes in my opinion is a huge NO-GO as basically they are changing the state of our property and not providing information what are the changes. If the user would have update notes he could decide if he wants or doesn't want the update. Every serious company that does OTA updates provides changelogs to their customers. When/if you guys do a report please include this request also, let's force Giant to do it.
Hey guys, so I have been reading three forums where people report charging issues after the last smart gateway module update. Some reported they did the update and have no issues, then again others the opposite and also some of you had these problems before this update.
So all this made me thinking, because until this last update I had no problems whatsoever with the updates. Now don't take this for granted, it's just a theory that can be wrong.
I thought/think the culprit of the issues could possibly be a mistake in the update procedure, because the way(procedure) I did the last update was slightly different than all previous(that worked fine).
The problem is that the Giant App's instructions during the update are a bit unclear at the end. When the updating is finished it gives you a prompt where it says something like this(can't remember the exact sentence): "For finishing the update turn off and restart your bike". Also with this prompt you get a FINISH button you can press. To me it is a bit unclear what to do first, press the Finish button or the bike Off/On step.
So, the procedure I used with all previous updates(ok) was:
1. Pressed FINISH button, exit the App.
2. Turned bike Off and On.
3. Reconnected bike with App.
The procedure I used(don't know why, think I was in a hurry) with the last update( is not ok) was:
1. Turned bike Off and On.
2. Pressed FINISH button, exit the App.
I wonder if this way somehow the update doesn't finish loading properly?
How did you guys that also have charging issues do the update, and how did those that did the update and don't have issues?
Well my Reign E+ is cracked, but looks like only the rocker link is affected.
Local suspension shop last month told me my rear shock was getting marked on just one side of the stanchion, which can be typical to trunnion mount so didn't make a case of it.
Bike started making a weird cracking sound in the last 2 rides, but wasn't able to pinpoint it...even greased my dropper again.
I rode a trail with large drops today and the cracking sound was getting louder, came out that the rocker is cracked on the left side at 2 places and since I didn't catch it right away the diamater of the hole is now off, ouch!
I truly hope that Giant is not going to take forever to replace it right in the middle of summer.
Any advises for small bags to store tool, maxalami and replacement tube, which fit nicely on the reign e+ frame?
Welcome to share pictures...
Hello, today I managed to fully charge the bike battery on the first try. First I turned on the power to the bike. After that, i put the charging cable to the plug. Could be a coincidence, I'll try the same again.
Yesterday, 24.07.2023, a new Version of the RideControl App has been released for iOS and Android.
I had to manually update the App because it was not advertised automatically like other apps, but this might be related to my Phone or its settings. When connecting my bikes, an update of the SmartGateway was advertised. It is Version 20230719000.
According to GIANT Germany Support Team, the bugs of the previous version 20230609000 have been fixed with 20230719000.
did the ride app update through play store then turned on bike and did the newest bike update. We shall see. It is acting like it used, can't turn on bike when charging(last update made it possible to do so, never have been able to before)
I am charging it now for one hour, starting at 50% and will update this post after one hour of charging. I expect to be around 80% in an hour.
One hour 31% charge about normal
Will the latest version of software lock the motor if tuning is used? I have a new trance x adv e+1 (2023) that has been updated with new software and installed with Speedbox 3.1. However, the Speedbox 3.1 doesn't work and the bike is still limited to 25km/h, which is very uncomfortable. I'm not sure if Volspeed V4 can be used with the latest software on my bike.
Even before the last update users reported that GIANT is now able to identify potential tuning and locks the motor with Failure Code A06. Abd even LBS seems not to be able to remedy from it and motor needs to get swapped. This is very similar with Shimanos latest approach to prevent tuning. But this is all second hand, so don't take it for granted.
    Join 43,195
