Bafang m820
can u take photo the remote from side, so it show how thick it is?
Display
With Best, you can change the diameter of the wheel and the speed is limited to 45 km/h. With the help of the wiring, you can change the limit to 60 km/h
WhatsApp Image 2023-03-14 at 20.51.54.jpeg WhatsApp Image 2023-03-14 at 20.52.03.jpeg
Has anybody tried riding the new motor already? If so, what are your thoughts? How does it compare to m500/m510?
Why make a heavy steel bolt for the M820? An old bolt from the M600.
LAnton
I have a stupid question. I presume M820 motor kit comes without battery charger.
So what kind of charger will be needed for 43V/410Wh battery ?
Battery BT F014 states max voltage of 49VDC so charger have to be CCS up to 48V ?
LAnton
It should be a charger for 12s battery or 50,4v
LAnton
There's just to 2 things to consider here. Charger voltage and charging port on the frame. So far most frames seem to come with a DC 5.5x2.1 female plug on the charging port. Also I can recommend you to get a universal DC lab supply where you can adjust voltage from 0-60v and current 0-5a. Very convenient, I use myself. Here's a good deal at the moment: € 50,22 53%OFF | Adjustable DC Power Supply 30V 10A 60V5A Lab Bench Power Supply Laboratory Stabilized Power Supply Voltage Regulator Switch 220V
That can be interesting at home to charge any batteries , but I would prefer a portable charger that I can carry easily if I need to charge elsewhere
I did some homework and found the bafang paper that in 43V system BMS is charging cells up to 4.1V so 4.1V *12 = 49.2Vmax. Found dedicated charger for about 60eur. Thanks
Lab psu is IMHO a very good idea.
I should add for clarity that if you don't buy the kit with the bafang battery then you need to find a charger appropraite for battery that you do buy. Just be aware that every Lithium based battery requires a Battery Management System. Sometimes the "BMS" is internal to the battery but it can also be external. But because the batteries are actually made up of many small batteries or cells. They need to be balanced. That's part of what the BMS does. So you don't want to run a dumb (no bms) charger with a dumb (no bms) battery or you can cause a fire.
