Reign E+ 2022
i also have these big Galfers and it's fine. i think they are slightly quieter in general, but it does depend somewhat on the moisture and dirt spray, speed, etc. sometimes at slower speed the first bite can still produce noise and vibration during wet rides. one thing to keep in mind is that huge rotors like this take longer to heat up before they have big power. slow speed riding in the wet (which is where i live, with no spring in sight yet, but that's another very grumpy story....) has no real advantage. but when i get a sustained descent where speeds increase and i'm on the brakes more, they are awesome. i'm also a larger rider at about 230 pounds fully outfitted to ride with pack. this bike excels at this kind of riding with it's suspension horsepower, geo and big brakes. love it.
Perfect Thanks. I like to go fast and brake late...so need the power 😜👍
Hey folks, any idea what kind of mech hangers the Reign uses, is it the new SRAM UDH? Need to get a spare.
This is the sound that bothers me in the engine. I think this is really heavy to tread when I go past the speed limit.
Edit:
I found a similar problem on youtube. The Bike Seller said he had never heard of a problem like this in a giant.
Driving uphill in low gear with full boost, the grant went off completely. The bike had to be turned off after which it started working.
1000 miles on my reign now. Only thing original in the bike is the frame, motor, and battery 🤣 loving it. No issues at all. Done 8 or 9 park days and loads of trail riding. Broken my hand two ago so 4 weeks off the bike 😩
How tall are you guys to run such high rise bars and which benefits are you getting on the trails ?
I'm about to swap my stem/bar combo and I was wondering if I would like switching to a 35mm rise bar up from the 20mm original Giant.
So many people are runing high rise, but I fear that I will let go some front wheel traction because of that.
XL stack is 650mm which is pretty good.
I have 4 x 5mm Spachers and a bar with 30mm Rise. No issue on flats or uphill, but more relaxed on steep decents.
Don't worry and give it a try 😉
I was running riser bars on my previous Trance which had a much lower stack, my riding position was way forward (like an XC bike) and it helped cure back pain on longer rides.
I run my 2022 Reign E+2 with stock handlebar, shorter stem (35mm) and it is fine so far.
Risers (IMHO) make sense if you have long legs and short torso (relatively speaking) thus helping with a more upright riding position with the side effect of reducing the load on the front wheel. My 2 cents…
I also have a cavitation sound, already new. I think there is too little oil.
I found the noise went away after a few cycles, now it’s really bad. I think it’s air in the dampener oil and when there is a little bit it emulsifies after a few pumps. Now mine need a full rebuild.
I've had that on 2 out of 3 fox X2... always sent over to tunner changed seals put an appropriate oil and good to go. just ashame fox does nothing about it.
Did you investigate a fix under warranty?
One reason I won't use fox suspension. Works well for a short time and constantly needs servicing. Or it just breaks.
Not had any issues with the 40s, 32s or 38s I have owned. Yes you have to look after them but they’ve never broken.
Sorry, was more on about rear shocks. I don't knock anyone that hasn't had issues with them. Also can't service yourself like rockshox.
Ah fair enough. I had a DHX5 on my old DH sled that I abused for 10 yrs without a service and it never missed a beat. My old Float Air shock also only had its first service a few weeks ago after 13 years of riding.
To be honest I have limited experience with Rockshox kit but I can only say good things about Fox and Marzocchi.
My bike (E+0) has started turning off on its own. When it comes back on it resets the button mapping which is kind of weird.
Shop is looking at it, hopefully it's a simple fix! I went for a ride on my non-e bike and it felt like I was stuck in molasses (lol). Too spoiled.
6’6 with a 38” inseam - 4 spacers 60mm rise Spank Vibrocore. Transformed the bike for me - love it.
Has anyone managed to get the circumference of the rear wheel changed in the software yet so this thing can actually achieve a true 25kph?
I have been riding my Trek Rail more than the Giant lately. When I jumped back on the Giant yesterday its really noticeable how quickly that limit arrives and how abruptly it cuts out in comparison.
I have once done that the assistant did not work. I restarted the bike software and the engine started normal again.
I rode my Reign E+ a lot in the last few days, lots of intense riding with drops & jumps.
The frame or something inside the frame near the headtube is now creaking extremely loudly when seated & bouncing on the suspension. The creak is now unbearable during a climb...sounds like I'm riding an old bike about to fall apart.
It's not creaking when load is applied to the pedals only which is pretty strange.
I noticed that the top of the battery was really dusty, so dust could've made it's way on a bolt/plastic or whatever causing the sound.
I wasn't able to find the source myself so I'll bring it to the bike shop tomorrow & report back.
I had a creak after a week sounded like head, stripped and greased head bearings and all suspension but still there turned out to be the seat post creaking the sound rang all way up the top tube, grab the seat and twist from side to side if its the same issue a little grease lower down the post fixed mine.
New to the forum, and to eMTB not to giant though my first Giant was a 1998 ATX-970 which i still own :), Had the Reign E+3 about 2 weeks now, had some of the normal issues, dented a rim, loose bolts, low power numbers between it and my garmin (which is how i found this thread) but love the bike I have come from a much shorter and livelier bike to this monster and love it. Only change the cockpit the brake levers were swapped out for some old 1 finger deore which work really well, the bars have changed for a 39mm rise nukeproof cut down to 750 the above was to get rid of some hand/thump pain i was getting which is now hopefully sorted.
Had some good rides so far, best one was this weekend, my first peaks ride with a couple of other eBs, still had 25% battery left so should be able to get 1500m plus if im careful.
I
I have a fox dhx 2 coil factory edition.
Exactly same measurement as original shock.
I do not experience a lot of pedal strike in low position as described in this forum on many occasions so suspect it makes bike sit higher in its travel... Either that or the fact I've come from downhill bikes that are low anyway...
I was browsing the thread today looking for information about a coil shock and saw this post, this frame seems to have the same crack from this thread today Giant reign 2022 frame cracking - EMTB Forums
Is this an ongoing problem on this bike?
Anyone have installed a bash guard? Can’t get my head around how one should be mounted.
    Join 43,250
