The Official BLEvo Thread
Status
Not open for further replies.
Fantastic, Paolo! (y) (that's supposed to be a "two thumbs up" emoji)
Coming soon for iOS, I hope!
@PaoloBLEvo
I noticed my speed was set at 24.5, so I thought I’d just use the +- to set it at 25.
It jumped to 25.5 and I got the message and clicked no thanks. Then when trying to set at 25 or 24.5, I had it jump back to 23.3, tried to set as close to 25 as I could but it kept jumping back to strange numbers like 24.1, 22.4, 23.2 ect. Tried lots of things to bring it back to 24.5 or 25 and I think it’s now at 24.4.
Is there a bug ?
2018 Levo
@PaoloBLEvo
Is there a bug ?
2018 Levo
Which version? IOS or Android?
Firmware versione?
When you did the change, the battery was connected to the motor?
Ok, now it decides it wants to work.
I have set it to 25kmh.
I had to use the - and it went 24.4, 23.2 & 22 on each press. Then the + 22, 23, 24, 25 with each press.
Restarted bike and it seems happy at 25.
Restarted app and bike several times and still happy at 25.
All good.
Hopefully for TCU Version 2.025 ;).
There are some rumors that Specs is going to 2100 mm Wheelsize in the MC App. Does anybody know something about that ?
That is ridiculous if they do..... what if people are running a different tire/rim combination - the fact that you cannot select your specific rim/tire size in mission control render it absolutely useless.
Karsten
In order to do this from MC, Specy needs to update also the TCU version, because the version 2.025 doesn't send to the motor the message to change the wheel size. This message is sent only if the TCU version is 2.019.
Sorry if this has been covered already, I just picked up my 19 Levo last week (I did install Blevo before I got my bike!) and can not find the smart tuning modes mentioned in the manual and on this thread, all the preset modes are just adjustments that you could make in Mission Control, My TCU also shows (Speed locked). Is the fnctionality limited on the 19 Levo?
No consumed KCalc in monitor of BLEvo for Android. It is in BLEvo for ios. Is it possibility @PaoloBLEvo to add this feature to android’s version of BLEvo?
Sorry but I don't understand your question. If the TCU is the version 2.025 the speed limit cannot be changed.
The Smart settings are able also in the Levo 2019. They are under Configuration->Smart Configuration.
Could you explain better your problem?
One thing I really do like about Mission Control is the map feature.
Will you implement maps in BLEvo?
In the Android version the maps are already present
In the future I will add also in iOS.
On iTunes it is available the version 3.1.4 of BLEvo for iOS.
These are the news:
- Added autonomy in audio messages
- Bugfix: Configuration of Speed and Wheel Size values
- Bugfix: Filtered invalid cadence values
Download it from iTunes.
‎BLEvo - For Smart Turbo Levo
Enjoy your ride.
What I do not see are the other tuning options mentioned on the manual like Zeus and Z-works. This is a screen shot.
Thank you!
Thank you!
Sorry, but which manual? You have the new Levo 2019, the Zeus settings are old and available on old firmware x.22 (2 versions ago)
Sorry someone is using successfully Blevo Smartpower with 2019? I have Fw versions 6.0.0 of motor, and 13.a for TCU, still not able to using Smartpower
Why not? What is the problem?
Android or iOS?
Android or iOS?
Android, running TCU version 13.a, Hw A.1.0. I think Smartpower is reading random values as biker power...just for test, I only touch the pedals and bike monitors reads from 0 to 500W, therefore I think everything not working properly. From bike monitor, TCU is 2.019
Very strange because I tested the functionality on Levo 2019 with TCU 2.019 and it works..
Did you update the App?
Could you send to me via email the CSV file?
If you try Mission Control, do you see correct values as biker power?
Paolo, thanks for the reply.
The app is updated to the latest version.
I will send you the file via email.
In MC where can I read the biker power?
In MC you need to start a tour and setup a field with the biker power..
Let me know
Status
