beutelfuchs
But not steel, right?
Given the weight of the Arma (and Storia they are fairly light for coil) it's likely aluminum. Hence the much larger diameter too.
At any rate the discussion is moot. EXT has already stated they support the Levo.
I wasn't talking about the e-Storia, that's why I said Arma and Storia.Its not an aluminum shaft….lol
It’s Chromemoly steel.
That's literally why the e-Storia exists...why would EXT use different materials for different shock shafts?
I think it’s fault safe to assume they all use the same shafts.
I'm not asking a questionjust because the e-storia exists with a shim stack and valving for eBike use doesn’t mean if would have a different shaft material. Look at the weight of the e-storia, its an eBike shock and it’s not really any heavier that the other two models.
I’m sure you could easily contact EXT and ask them directly. Just from a manufacturing standpoint I couldn’t see there being a reason for all of their MTB shocks to not run the exact same 14mm shafts.
I'm not asking a question![]()
Sorry I'll be more clear:
The e-Storia doesn't exist because it has a different shim stack and valving. *Every* EXT shock comes with a custom tuning, it's part of the service when you order it and one reason why they have such a thorough order form.
The e-Storia a different platform. Different body, different reservoir, different spring plates and, yes, a steel shaft.
So "just from a manfacturing standpoint"...it's a totally different product![]()
Sorry, not true. I ordered from Suspension Syndicate (now EXT USA) and they adjusted it for my weight and riding style, and bike. This is fun, right?sorry not true, if you order directly from EXT they offer custom tunes.
I live in Canada and purchased my shock through Alba, it comes with an off the shelf emtb tune from EXT. Not a custom tune specifically for me.
In case my post got lost in the drama, I'll repeat that the shaft of my Arma is not magnetic. It may be (probably is) stainless steel, but it's not "regular" steel.they are using a hardened steel shaft, I would even to say there is no one in any form of suspension manufacturing using aluminum for shock shafts.
Anyway, good luck. If you'd like to start a thread debating shock shafts, please do. That's not the point of this thread. I apologize to anyone else reading for engaging in this silliness, I should know better![]()
That's an automatically generated email because you left something in the cart. Means nothing. Why not just email Ohlins and/or Specialized and ask??I think this email from Ohlins-USA may count as an official endorsement of using their coil on our Levos. I went through the online purchase process but didn't do the credit card part.
Why did you assume I hadn't?That's an automatically generated email because you left something in the cart. Means nothing. Why not just email Ohlins and/or Specialized and ask??
It's aluminum.
Beau Gunnerson
435-764-1315
EXT-USA
FYI for those wondering about the shaft material on the EXT Arma and Storia:
I suppose what's why they call it "hard anodizing"? I mean all the air shocks are aluminum too. And dropper posts. And forks...you just wanted to say "hard rubbing" didn't you?well there we have it….lol
I don’t mind eating a little crow….lol
I’m honestly shocked about the aluminum, aluminum is a pretty soft material when it comes to stuff rubbing on it.
I suppose what's why they call it "hard anodizing"? I mean all the air shocks are aluminum too. And dropper posts. And forks...you just wanted to say "hard rubbing" didn't you?![]()
Yes, the estoria. but not the others. Pls check the context!the e-Storia has a 14mm chromemoly steel shaft.
It’s steel.
Hi Guys I can confirm a few things.
Arma & Storia V3: 14mm Anodized Aluminum Shaft
e-Storia & Arma MX: 14mm Chrome Plated Steel Shaft.
With that said we have not had any issues with any aluminum shafts breaking on the V3 shocks but I think that the steel shaft should definitely have better wear resistance in bikes that tend to side load the shock. I think the choice by EXT to go with Steel on the new chassis is more out of abundance of safety and better wear properties than anything else. Also should note that these are being spec'd on bikes like the Nicolai Eboxx-Ultra which is essentially an e-moto and weighs 65kg. So it is probably a little overbuilt for a levo but I would not consider that a bad thing, especially considering it still comes in a at very competitive weight when compared to other standard (non e-bike specific) coils on the market. Additionally the e-Storia has a new internal negative coil feature as well which helps with small bump sensitivity and to dampen top out events which works really well. A lot of us here are running this shock on our regular bikes as well now. It is a truly amazing damper.
As for tuning yes, we (EXT-USA) do custom tune (internal valving and external adjustment) the shocks before sending them out if necessary, but because the range of the adjusters has been widened quite a bit on the e-Storia many go out with the standard factory valving. Every shock we send out is still evaluated on a case by case basis(bike kinematics/riding style/ weight etc.) and light/heavy riders (under 150lbs/ over 225) are generally going to get a different tune.
No solid date but I would bet towards the end of the year.So how much longer before the EXT air shock releases?
