there were rave reviews over the 46.6 in terms of torque delivery and less brutal and battery range was better than the 46.6. Maybe it's worth a comparison.No, do you think it's worth a try?
But Luna FW14.6 is old more one year...![]()
the 46.7 is just too brutal in the ramp up and too much torque for PAS1/2. I have to pull the brakes everytime I press the pedal in between stop and start. Very annoying when riding in technical trails.I agree. I know that not every software needs to be an improvement for everyone. That's why we try with @mgx the most suitable for our ride. And that probably appears FW46.7 ...
I believe it's this one:can somebody share link to Luna 14.6 fw?
Bafang_M500_M600/Firmwares/Official/Motor/m600/CRX10NC4818i132014.6-20191126.bin at main · OpenSourceEBike/Bafang_M500_M600
Contribute to OpenSourceEBike/Bafang_M500_M600 development by creating an account on GitHub.github.com
Though equally it could be this:
Bafang_M500_M600/Firmwares/Custom/Motor/m600/luna_x1_firmware__74963.bin at main · OpenSourceEBike/Bafang_M500_M600
Looks like the 14.6 is really suited for technical terrains. Only issue is whether the ramp up will reach 10A (which means brutal) and the battery range.Today I added comparison with Luna 14.6 firmware:
My observations:
- PAS1 is very nice, exactly what I needed. Current is not over 5A, usually I see 3-4A.
- Instant drivetrain stop when you stop pedaling like bafang 46.7. Like it
- Overall, i feel like less powerfull then 46.7 (maybe like 46.6?), mild and not kicky. It will be good to compare with 46.6.
Values/numbers are below. For future tests i must:
- change wheel size to match 1:1
- track range only on PAS1, or PAS0, as every fw is calculating range differently (and differently on each PAS level).
There is a need for calibration after firmware change? Never did that…Try different firmware for M500 between CRX10NC4813i142015.8-28-2230-20210805.bin and CRX10NC4810i142050.6-22-1768-20201109.bin , i think CRX10NC4810i142050.6-22-1768-20201109.bin is better and more natural for me. the power is enough and also more battery save. Dont forget to calibrate after change firmware.
No such need. Never did. I only needed to do calibration when i changed the controller.There is a need for calibration after firmware change? Never did that…
Isn't the CRX10NC4810i142050.6-22-1768-20201109.bin a bit too weak? I mean the pre-installed orginal firmware was giving loads of battery life but the motor felt way too weak for steep uphills (this was also stated by Rob in his video with the comparison of the m500 and the bosch motor). Unfortunately Rob never did a new review with the stronger firmware untill now. Many of us changed firmware to the CRX10NC4813i142015.8-28-2230-20210805 that gives good power and still good battery life.Try different firmware for M500 between CRX10NC4813i142015.8-28-2230-20210805.bin and CRX10NC4810i142050.6-22-1768-20201109.bin , i think CRX10NC4810i142050.6-22-1768-20201109.bin is better and more natural for me. the power is enough and also more battery save. Dont forget to calibrate after change firmware.
Yes, its for M500.Am i right in saying this is only for M500? I am looking to down tune my M600 in its assists 1-4
Use 14.6..its very smooth and half the power or 46.7Am i right in saying this is only for M500? I am looking to down tune my M600 in its assists 1-4
How is this compared to 14.6?Yes, its for M500.
For M600 there is detuned 15A 48V firmware:
Bafang_M500_M600/Firmwares/Official/Motor/m600/CRX10NC4815i132020.8-20210924.bin at main · OpenSourceEBike/Bafang_M500_M600
On what firmware on M600 are you?
Do not know, never used.How is this compared to 14.6?
Stock or whatever I had on it when I got the M600. I was looking into hooking up the BESST tool later this week when I get to it.Yes, its for M500.
