The Official BLEvo Thread
Status
Not open for further replies.
I looked through the posts here and also in the manual but haven't found what the color of the "motor power" graph indicates (the one above the cadence gauge in the pic below). It doesn't seem to be related to the numerical value. Any pointers to what it means or where I could find that information would be appreciated.
Would the ability to change the speed settings be available on the 20/21 version please?
What speed settings? To overcome the speed limt for motor support? Surly not, Spesh had to disable the possibility for that by SW setting on the new motors (2.1), it was just to easy to overcome legal restrictions.
You would need a defeat device, mechanical e.g. Planet3 or LSS) or electrical (e.g. Levociraptor).
I do jot recommend to do it, especially when the bike is used in non-private areas.
Reading some earlier posts about the 2021 HT it suggested the motor was still the same older version 1.2e and that would still be configurable with blevo?
I am a bit confused about the "Distance ridden" value on the Battery Monitor page in Blevo for iOS. Is it supposed to show a corrected value (depending on the wheel size/speed settings) or just the uncorrected raw value (i.e. the same as in the Mession Control app)?
I am not sure if this is the correct place to report a bug for Blevo on iOS, but I try anyway...
On the "tour summary" screen, the arrows do not navigate to the previous/next tour directly, instead they are showing an "empty" tour upon click. I always have to click the arrows a second time to reach the previous/next tour. This happens for any ride no matter where I am in the history of rides... Anyone else experiencing that?
It seems that there is something weird going on with ascent reading (20kms)... :unsure:
Sometimes the Levo makes me fly ?
I've noticed this as well, but it is the first time this happened. I'll have a look in the tracking data tonight. Maybe it happened because I had to reboot the iPhone during the ride.
On my customised display I've selected the 'km to end' field. However, I cannot get any data to display for it even when I'm following a route. How do I get it to show how far I have left to go?
You have to select a GPX before start the ride.. after that you will se the value.. BLEvo needs to know your planned ride
The color of "motor power" is not documented sorry but it is:
- Green when the motor power is lower than biker power
- Orange when the motor power is between biker power and the double of biker power
- Red when the motor power is over the double of biker power..
If it is not present the TCU, you should be able to unlock the speed with this model of bike..
It is the distance stored in the motor..
So if your wheel size is fake, also this value will be fake..
There was a bug in the version 3.6.1 where I added the use of the barometer.. The new version should solve the issue..
@PaoloBLEvo , still having same problem (see here- The Official BLEvo Thread - EMTB Forums) with the app transferring wrong total ascend data to strava, (1000m climb recorded in the BLEvo app, showing 1500m in STRAVA).
Android v.3.7.5.
I do enjoy the admiration on my strava followers for big climbs, but still - better to have this fixed :)
Hi Paolo,
the battery temperature is only displayed on my screen from 14°C (Android v3.7.5). There is only a gray screen underneath. Is it correct?
First of all THANK you for this awesome app. In an earlier post someone wrote a problem with
that the font is displayed too large. I have the same . Have a look at the attached picture.
I own an LG G6 like it was prefered here.
And I set the font size on the LG to small anyway.
But it is still to big.
An idea what I can do to solve this?
Kind regards
Kind regards
Which BLEvo version you have? I have the same LG G6 and this is my screenshot...
One thing that I'm frustrated with, using an Iphone, is that when in the mode where the map is visible on the top half of the screen, my current location is below the visible portion of the map... is there a way to adjust it so I can see current location without having to physically swipe up?
In the GPX import menu..
Please check the documentation available on the app..
Hi Paolo,
If I select the GPX that I've imported then I don't get a 'miles to go' reading. But if I use the 're-ride this ride' feature then it works perfectly.
Could you send a screenshot?
Hi Paolo,
Could you send the GPX to [email protected] and I will check it?
Please specify the issue in the email..
Paolo kindly showed me that my GPXs lacked elevation data, and suggested that I upload them to AllTrails and then download them from there. This has solved the issue and means I can create better GPXs for the app. Thank you Paolo for your help.
@PaoloBLEvo - Samsung Galaxy S8 (SM-G950F).
I now see this problem started in BLEvo v.3.7.3.
See below a typical difference - both recordings of the same ride, upper recorded by strava, lower with BLEvo.
Sorry but the issue is in Strava o BLEvo..
Also BLEvo says so different descent values?
What is the right value?
Status
    Join 43,210
