What damper are you using with the Smashpot?
How's the MoCo performing? Can you actually notice any changes you make to it?
Fucking finally, made up my mind after weeks of going back and fourth, ordered a e 180 rs.
Taking delivery in a week plus, LBS re-routing the shifter cable inside the BB.
Am beside myself with excitement!
Would you post up a pic of the rerouted cable please?
Any chance you could take a bigger picture showing a bit more of your bike to give me a better idea of your routing please mate, looks good, I might copy your idea ?yeah the speed sensor follows blue to meet up with the break hose. The shifter cable routing pokes out of a little hole drilled in the plastic and follows orange, it is really out of the way.
What Tribey said ?
I didn’t remove mine, the plastic cover does for over the crank arm if you rotate it round a bit.
Hoping to get a 600lb spring this week, should sit the bike a bit higher up in its travel ?
I’m really glad I didn’t treat myself to the hope cranks, mine are completely battered now.
here you go, from 49 seconds
Hiya chaps.
If you want to go belt and braces, I guess you could remove the brake hose entirely and feed both through a new grommet. I’m not that fussed, a blob of black sealant does the job. I’m of the camp that bikes are for using not for looking at ?
Sean there’s no clips in the way, it makes total sense when you get the cover off and see for yourself, obvs removing the battery makes it easier.
Good luck! Got to love a bit of bike tinkering with a beer ?
